    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 763.0k Views 27 Watching
    • bheplerB
      bhepler Module Developer @majik655
      • bheplerB
        @majik655 said in Hello-Lucy:
        I was speaking about getting in the mail soon my new microphone that is 3.5mm connector so I can plug it into the raspberry pi’s “headphone” jack (am I wrong it being a 3.5?)
        Hrm. Looking at the specs, it’s a 3.5mm four-pole headphone and composite video jack. Four-pole suggests that it’s designed for headsets with a microphone. I’d want to try that to be sure, but… theoretically you could make it work if you have the right adapter. You’ll need something that will bypass the audio channels and connect to the mic contact.
        The fact that it is a video out as well is still blowing my mind a bit.
        S M 2 Replies Last reply
          sdetweil @bhepler
          @bhepler I think it’s speaker/headphone and video. 4 wires signal and ground for both…
          no mic
            majik655 @bhepler
            @bhepler said in Hello-Lucy:
            @sdetweil said in Hello-Lucy:
            no mic
            Well great, lol guess I will be sending that one back hahaha
            I must have miss understood … guess everyone that was talking about the lag using usb mic was using a computer rather than a PI . ugh.
            Well no matter the video camera is gonna stay as it is working well.
            Thank you guys for the reply. Now if I can only figure out how to change the text lucy puts on the screen and maybe hide lucy when first booting up MM.
            Mykle1M 1 Reply Last reply
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @majik655
              No, and yes.
              USB introduces lag in both the Pi and a pc board. I’ve tested this on an Quad Core i7 with a USB mic. The lag is awful. However, any board with a 3.5mm mic jack works exceptionally well. Near zero lag on any laptop board I’ve ever used, even 12 year old laptop boards with minimal specs. I believe USB has trouble processing audio. The use of a 3.5mm mic jack goes direct to the sound card. No extra processing by USB needed.
              Anyway it is working beautifully and there is no lag
              Whatever setup you are using that has no lag, I would stick with that, short of moving to a pc or laptop board.
              Is there any way to not show lucy on any pages.
              I assume you mean, “Say, Hello Lucy” and the microphone icon. I’ll take a look at that for you.
              • Mykle1M
                I think that using Remote-Control with Lucy can cause problems because they are both controlling HIDE/SHOW commands. If you disable Remote-Control temporarily does Hello Lucy still exhibit the issues you mentioned? The config entries for each page are how you set up your pages. Spellings and cases must be precise. The slightest error could drive you nuts.
                • Mykle1M
                  So, if you don’t want the module to show at all you can add this to your custom.css file"
                  .Hello-Lucy {
                    display: none;
                  However, you will no longer have any visual confirmation (ex. pulsing mic icon).
                    majik655 @Mykle1
                    @Mykle1 said in Hello-Lucy:
                    .Hello-Lucy {
                      display: none;
                    Oh Thank you for the css code! and I do understand about the no visual acknowledgment (which I have now found to be very useful).
                    For whatever reason when I moved my magic mirror from my garage where I have been configuring it to the living room… there is now a very long lag. For what ever reason I know it sounds crazy but in the garage there isn’t a lag. I have two theories for this… either its because wifi is stronger in garage (I dont see why this would matter at all)…or because there is more noise in the living room (which is more likely the reason)…
                    As for remote control I do have remote control as a module … in any of my process I have had the module installed.
                    I don’t feel that has anything to do with it but I will surely test this out very soon.
                    I have been thinking the issue lies with MMM-NewPIR since that is simply a module that instead of turning off power or going to stanby to “hide modules” it “covers” it. Well from what they said they made it sound like they just put up a black screen.
                    But the more I think about it they must do more because no matter what when the mirror goes to “sleep” because of no motion… when it comes back on because of motion ALL MODULES are shown.
                    So right now my Lucy config is below… and when MM first boots up … with this config Lucy is the only one showing on page 1 (page 2 works fine) if I switch to page to then back to page 1 Lucy does not show.
                    If I turn off MMM-NewPIR I have the same result… so I will try disabling MMM-Remote (as you suggested) and see if that works.
                    I guess I want to confirm from this config… when the mirror starts up, nothing should show on first page not even Lucy …correct?
                                           disabled: false,
                                           module: "Hello-Lucy",
                                           position: "bottom_left",
                                                           keyword: 'HELLO LUCY',
                                                           timeout: 10,
                                                           standByMethod: 'HIDE',
                                                           microphone: "2,0",
                                                           sounds: [""],
                                                           confirmationSound: "ding.mp3",
                                                           startHideAll: true,
                                                           pageOneModules: [],
                                                          pageTwoModules: ["MMM-Reddit","MMM-Screencast","MMM-EARTH-Live","clock"], }
                      majik655 @Mykle1
                      Well I have commented out everything in my config file except for “clock” module and Lucy.
                      For Lucy I have the config file like in my last post but I even have nothing in the second page.
                      When MM boots , Lucy shows bottom left corner. I suppose this is normal because why would you want her not there? I was wanting it that way because she was working really well with no lag… but for whatever reason not the case in a different room…crazy!
                      • Mykle1M
                        Your config entry is correct. I also see that Lucy is shown in this case. Changing pages and going back to page 1 and Lucy is gone. Odd. Use the css .
                        • 11
                        • 12
                        • 13
                        • 14
                        • 15
                        • 15 / 15
