    raspberry-pi alternatives
    39 Posts 13 Posters 39.8k Views 14 Watching
      papak69
      maybe a lame question, but i am not a coder or have that much linux experience, so I would like to know if it is possible to use any stronger alternative to raspberry-pi? If so, what do I have to be careful about and how whould I go about setting it up?
      thank you for your help.
      My computer once beat me at chess but it was no match for me at kickboxing.
      • T Offline
        Toast
        Think most of it isnt Raspberry Pi specific so an alternative like Udoo or Hummingboard shouldnt be impossible.
        The most you need is Debian and NodeJS
        Please correct me if im wrong :)
        • Y Offline
          yawns Moderator
          That kind of depends what you intend to do. Basically you can use every box (spare laptop, full workstation, small devices like raspberry, …) running Windows, Linux or MacOS.
          However the raspberry is strong enough for most users, so I’m curious why you are asking for a stronger alternative.
          Don’t be to anxious about Linux, once you setup your magicmirror you don’t have to twiddle around with Linux all day long.
            papak69
            well i need it to display images and videos, but it has to be smooth … now when display full-hd video on rpi-3 it gets laggy …
              papak69
              and thanks for your answers … i was actually looking at a few options:
              • intel nuc (maybe a bit too strong)
              • banana-pi
              one thing also that i did not mention was an option to connect a wifi antenna for better signal, since the rpi 3 is boxed aluminium frame and so the wifi signal is compromised.
              • T Offline
                Toast
                banana-pi kinda allergic towards Allwinner SoC would rather choose the nuc saves a person from alot of headaches when it comes to OpenGL and Hardware Acceleration.
                  bhepler Module Developer @papak69
                  @papak69 An easy solution to the WiFi signal is to buy a USB extension or flush-mount kit. You can mount the extension to the outside of your frame and plug the WiFi adapter in there, where it will be unencumbered by the aluminum.
                  • T Offline
                    tajno
                    Edit: wtf - again it posts on a wrong thread…
                    Edit2: To say something constructive: I’ve also expierenced some performance issues, I have an ISS livestream on my mirror, also one of the SERENE and a live windprofile of european temp&wind conditions. Sometimes its a little bit laggy - in background there are wheater forecast, wheater now, wunderlist with 1 list as to do and one included in calendar, calendar himself use 7 different links, 4 newsfeeds and last but not least my traffic forecast. So I’m not wondering about that :) - most of the time its no problem, just have a look if its swapping - than a reload of the mirror will help (pm2 reload mm).
                      papak69
                      thanks guys, I will investigate a bit more … udoo looks promising.
                      @bhepler what do you mean with flush mount kit? any link for that?
                      @tajno true … i have 2 calendars, weather + forecast, stocks, random image & newsflash + the rpi camera motion sensor … but would hate to remove any of it for sake of more speed …
                      T B 2 Replies Last reply Reply Quote 0
                      • T Offline
                        tajno @papak69
                        @papak69
                        Another way would be to use the servermode - Than add a chromecast to your mirror/screen and open it in a browser with F11 as fullscreen.
                        Works pretty nice, I’m thinking about to made a hosting on my root servers and provide it over this way to my friends with limited technical knowledge (GIT & Puppet). Is my next project - but first I have to end this one, I’m building a new frame :).
                          @papak69 Follow the link in my last post. It should be what you’re looking for.
                            alexyak
                            Here’s the alternative that you can use:
                            https://www.amazon.com/MINIX-Fanless-Windows-Dual-Band-Ethernet/dp/B01M1LA8MB/ref=sr_1_15?ie=UTF8&qid=1479087997&sr=8-15&keywords=Minix
                            • cowboysdudeC Offline
                              cowboysdude Module Developer @yawns
                              @yawns said in raspberry-pi alternatives:
                              I am also looking for a much stronger or should I say powerful board for the mirror. I’m going to be building a 40" mirror that I want to do many things with … the Pi just doesn’t have enough power to handle some of the things I’d like it to do… Also the voice control module works so much better with a more powerful board… I know, I’ve tested it :)
                                bhepler Module Developer @cowboysdude
                                @cowboysdude Possibly something like the Zotac Zbox? It’s probably overkill. And at that price… it’s more expensive than the rest of your hardware.
                                A cowboysdudeC 2 Replies Last reply Reply Quote 1
                                  alexyak @bhepler
                                  @bhepler it is an overkill. Atom based quad SoC with 4GB RAM should be enough.
                                  johnnyboyJ 1 Reply Last reply Reply Quote 0
                                    cowboysdude Module Developer @bhepler
                                    @bhepler said in raspberry-pi alternatives:
                                    I have been looking at that exact box!!! Great minds think alike :)
                                    Was also looking very strongly at this:
                                    http://www.newegg.com/Product/Product.aspx?Item=N82E16856173128
                                      A Former User @alexyak
                                      @alexyak Only under Windows… It bricks on trying to install Raspbian… I know because it happened to me…
                                      • T Offline
                                        tajno
                                        Actually I got the problem that the RAM is filled and the system starts to swap - which made the mirror, obviously very slow.
                                        Does anyone have similiar issues?
                                        A pm2 reload does not really work - The only way is to kill electron and start the mirror again - than it works fine for like 12 hours. I don’t really get what the RAM is filling - Maybe its the iFrame Module? A clean installation will probably not have those problems, think it must be a module…
                                          alexyak @Guest
                                          @wjdw87 of course it wouldn’t run Raspbian because it’s built specifically for RPI. I’d stay with Windows.
                                            @alexyak sorry, i was not clear. No Linux Distros will install. . they also have android out of the box version and you can change over.
                                            The problem is their jerry rigged bios.
                                            Their android or windows packages at specific to the boxes, no installing of USB/other for they are not built for the boxes
                                            Further the windows is only 32 bit, and the android does have 64 bit, admittedly
