    raspberry-pi alternatives
    39 Posts 13 Posters 37.6k Views 14 Watching
    • papak69P Offline
      papak69
      and thanks for your answers … i was actually looking at a few options:
      • intel nuc (maybe a bit too strong)
      • banana-pi
      one thing also that i did not mention was an option to connect a wifi antenna for better signal, since the rpi 3 is boxed aluminium frame and so the wifi signal is compromised.
      My computer once beat me at chess but it was no match for me at kickboxing.
      • ToastT Offline
        Toast
        banana-pi kinda allergic towards Allwinner SoC would rather choose the nuc saves a person from alot of headaches when it comes to OpenGL and Hardware Acceleration.
        • bheplerB Offline
          bhepler Module Developer @papak69
          @papak69 An easy solution to the WiFi signal is to buy a USB extension or flush-mount kit. You can mount the extension to the outside of your frame and plug the WiFi adapter in there, where it will be unencumbered by the aluminum.
          • T Offline
            tajno
            Edit: wtf - again it posts on a wrong thread…
            Edit2: To say something constructive: I’ve also expierenced some performance issues, I have an ISS livestream on my mirror, also one of the SERENE and a live windprofile of european temp&wind conditions. Sometimes its a little bit laggy - in background there are wheater forecast, wheater now, wunderlist with 1 list as to do and one included in calendar, calendar himself use 7 different links, 4 newsfeeds and last but not least my traffic forecast. So I’m not wondering about that :) - most of the time its no problem, just have a look if its swapping - than a reload of the mirror will help (pm2 reload mm).
            • papak69P Offline
              papak69
              thanks guys, I will investigate a bit more … udoo looks promising.
              @bhepler what do you mean with flush mount kit? any link for that?
              @tajno true … i have 2 calendars, weather + forecast, stocks, random image & newsflash + the rpi camera motion sensor … but would hate to remove any of it for sake of more speed …
              T bheplerB 2 Replies Last reply Reply Quote 0
              • T Offline
                tajno @papak69
                @papak69
                Another way would be to use the servermode - Than add a chromecast to your mirror/screen and open it in a browser with F11 as fullscreen.
                Works pretty nice, I’m thinking about to made a hosting on my root servers and provide it over this way to my friends with limited technical knowledge (GIT & Puppet). Is my next project - but first I have to end this one, I’m building a new frame :).
                • bheplerB Offline
                  @papak69 Follow the link in my last post. It should be what you’re looking for.
                    alexyak
                    Here’s the alternative that you can use:
                    https://www.amazon.com/MINIX-Fanless-Windows-Dual-Band-Ethernet/dp/B01M1LA8MB/ref=sr_1_15?ie=UTF8&qid=1479087997&sr=8-15&keywords=Minix
                    • cowboysdudeC Offline
                      cowboysdude Module Developer @yawns
                      @yawns said in raspberry-pi alternatives:
                      That kind of depends what you intend to do. Basically you can use every box (spare laptop, full workstation, small devices like raspberry, …) running Windows, Linux or MacOS.
                      However the raspberry is strong enough for most users, so I’m curious why you are asking for a stronger alternative.
                      Don’t be to anxious about Linux, once you setup your magicmirror you don’t have to twiddle around with Linux all day long.
                      I am also looking for a much stronger or should I say powerful board for the mirror. I’m going to be building a 40" mirror that I want to do many things with … the Pi just doesn’t have enough power to handle some of the things I’d like it to do… Also the voice control module works so much better with a more powerful board… I know, I’ve tested it :)
                      bheplerB 1 Reply Last reply Reply Quote 1
                      • bheplerB Offline
                        bhepler Module Developer @cowboysdude
                        @cowboysdude Possibly something like the Zotac Zbox? It’s probably overkill. And at that price… it’s more expensive than the rest of your hardware.
                        A cowboysdudeC 2 Replies Last reply Reply Quote 1
                        • 1 / 4
