    raspberry-pi alternatives
    39 Posts 13 Posters 37.6k Views 14 Watching
    • yawnsY Offline
      yawns Moderator
      That kind of depends what you intend to do. Basically you can use every box (spare laptop, full workstation, small devices like raspberry, …) running Windows, Linux or MacOS.
      However the raspberry is strong enough for most users, so I’m curious why you are asking for a stronger alternative.
      Don’t be to anxious about Linux, once you setup your magicmirror you don’t have to twiddle around with Linux all day long.
      • papak69P Offline
        papak69
        well i need it to display images and videos, but it has to be smooth … now when display full-hd video on rpi-3 it gets laggy …
        My computer once beat me at chess but it was no match for me at kickboxing.
        • papak69P Offline
          papak69
          and thanks for your answers … i was actually looking at a few options:
          • intel nuc (maybe a bit too strong)
          • banana-pi
          one thing also that i did not mention was an option to connect a wifi antenna for better signal, since the rpi 3 is boxed aluminium frame and so the wifi signal is compromised.
          • ToastT Offline
            Toast
            banana-pi kinda allergic towards Allwinner SoC would rather choose the nuc saves a person from alot of headaches when it comes to OpenGL and Hardware Acceleration.
            • bheplerB Offline
              bhepler Module Developer @papak69
              @papak69 An easy solution to the WiFi signal is to buy a USB extension or flush-mount kit. You can mount the extension to the outside of your frame and plug the WiFi adapter in there, where it will be unencumbered by the aluminum.
              • T Offline
                tajno
                Edit: wtf - again it posts on a wrong thread…
                Edit2: To say something constructive: I’ve also expierenced some performance issues, I have an ISS livestream on my mirror, also one of the SERENE and a live windprofile of european temp&wind conditions. Sometimes its a little bit laggy - in background there are wheater forecast, wheater now, wunderlist with 1 list as to do and one included in calendar, calendar himself use 7 different links, 4 newsfeeds and last but not least my traffic forecast. So I’m not wondering about that :) - most of the time its no problem, just have a look if its swapping - than a reload of the mirror will help (pm2 reload mm).
                • papak69P Offline
                  papak69
                  thanks guys, I will investigate a bit more … udoo looks promising.
                  @bhepler what do you mean with flush mount kit? any link for that?
                  @tajno true … i have 2 calendars, weather + forecast, stocks, random image & newsflash + the rpi camera motion sensor … but would hate to remove any of it for sake of more speed …
                  T bheplerB 2 Replies Last reply Reply Quote 0
                  • T Offline
                    tajno @papak69
                    @papak69
                    Another way would be to use the servermode - Than add a chromecast to your mirror/screen and open it in a browser with F11 as fullscreen.
                    Works pretty nice, I’m thinking about to made a hosting on my root servers and provide it over this way to my friends with limited technical knowledge (GIT & Puppet). Is my next project - but first I have to end this one, I’m building a new frame :).
                    • bheplerB Offline
                      @papak69 Follow the link in my last post. It should be what you’re looking for.
                        alexyak
                        Here’s the alternative that you can use:
                        https://www.amazon.com/MINIX-Fanless-Windows-Dual-Band-Ethernet/dp/B01M1LA8MB/ref=sr_1_15?ie=UTF8&qid=1479087997&sr=8-15&keywords=Minix
                        • 1 / 4
