    raspberry-pi alternatives
    39 Posts 13 Posters 41.6k Views 14 Watching
      papak69
      and thanks for your answers … i was actually looking at a few options:
      • intel nuc (maybe a bit too strong)
      • banana-pi
      one thing also that i did not mention was an option to connect a wifi antenna for better signal, since the rpi 3 is boxed aluminium frame and so the wifi signal is compromised.
      My computer once beat me at chess but it was no match for me at kickboxing.
      • T
        Toast
        banana-pi kinda allergic towards Allwinner SoC would rather choose the nuc saves a person from alot of headaches when it comes to OpenGL and Hardware Acceleration.
          bhepler Module Developer @papak69
          @papak69 An easy solution to the WiFi signal is to buy a USB extension or flush-mount kit. You can mount the extension to the outside of your frame and plug the WiFi adapter in there, where it will be unencumbered by the aluminum.
          • T
            tajno
            Edit: wtf - again it posts on a wrong thread…
            Edit2: To say something constructive: I’ve also expierenced some performance issues, I have an ISS livestream on my mirror, also one of the SERENE and a live windprofile of european temp&wind conditions. Sometimes its a little bit laggy - in background there are wheater forecast, wheater now, wunderlist with 1 list as to do and one included in calendar, calendar himself use 7 different links, 4 newsfeeds and last but not least my traffic forecast. So I’m not wondering about that :) - most of the time its no problem, just have a look if its swapping - than a reload of the mirror will help (pm2 reload mm).
              papak69
              thanks guys, I will investigate a bit more … udoo looks promising.
              @bhepler what do you mean with flush mount kit? any link for that?
              @tajno true … i have 2 calendars, weather + forecast, stocks, random image & newsflash + the rpi camera motion sensor … but would hate to remove any of it for sake of more speed …
              T B 2 Replies Last reply Reply Quote 0
              • T
                tajno @papak69
                @papak69
                Another way would be to use the servermode - Than add a chromecast to your mirror/screen and open it in a browser with F11 as fullscreen.
                Works pretty nice, I’m thinking about to made a hosting on my root servers and provide it over this way to my friends with limited technical knowledge (GIT & Puppet). Is my next project - but first I have to end this one, I’m building a new frame :).
                  @papak69 Follow the link in my last post. It should be what you’re looking for.
                  • A
                    alexyak
                    Here’s the alternative that you can use:
                    https://www.amazon.com/MINIX-Fanless-Windows-Dual-Band-Ethernet/dp/B01M1LA8MB/ref=sr_1_15?ie=UTF8&qid=1479087997&sr=8-15&keywords=Minix
                    • cowboysdudeC
                      cowboysdude Module Developer @yawns
                      @yawns said in raspberry-pi alternatives:
                      That kind of depends what you intend to do. Basically you can use every box (spare laptop, full workstation, small devices like raspberry, …) running Windows, Linux or MacOS.
                      However the raspberry is strong enough for most users, so I’m curious why you are asking for a stronger alternative.
                      Don’t be to anxious about Linux, once you setup your magicmirror you don’t have to twiddle around with Linux all day long.
                      I am also looking for a much stronger or should I say powerful board for the mirror. I’m going to be building a 40" mirror that I want to do many things with … the Pi just doesn’t have enough power to handle some of the things I’d like it to do… Also the voice control module works so much better with a more powerful board… I know, I’ve tested it :)
                        bhepler Module Developer @cowboysdude
                        @cowboysdude Possibly something like the Zotac Zbox? It’s probably overkill. And at that price… it’s more expensive than the rest of your hardware.
                        A cowboysdudeC 2 Replies Last reply Reply Quote 1
                        • A
                          alexyak @bhepler
                          @bhepler it is an overkill. Atom based quad SoC with 4GB RAM should be enough.
                          johnnyboyJ 1 Reply Last reply Reply Quote 0
                          • cowboysdudeC
                            cowboysdude Module Developer @bhepler
                            @bhepler said in raspberry-pi alternatives:
                            I have been looking at that exact box!!! Great minds think alike :)
                            Was also looking very strongly at this:
                            http://www.newegg.com/Product/Product.aspx?Item=N82E16856173128
                              A Former User @alexyak
                              @alexyak Only under Windows… It bricks on trying to install Raspbian… I know because it happened to me…
                              • T
                                tajno
                                Actually I got the problem that the RAM is filled and the system starts to swap - which made the mirror, obviously very slow.
                                Does anyone have similiar issues?
                                A pm2 reload does not really work - The only way is to kill electron and start the mirror again - than it works fine for like 12 hours. I don’t really get what the RAM is filling - Maybe its the iFrame Module? A clean installation will probably not have those problems, think it must be a module…
                                • A
                                  alexyak @Guest
                                  @wjdw87 of course it wouldn’t run Raspbian because it’s built specifically for RPI. I’d stay with Windows.
                                    @alexyak sorry, i was not clear. No Linux Distros will install. . they also have android out of the box version and you can change over.
                                    The problem is their jerry rigged bios.
                                    Their android or windows packages at specific to the boxes, no installing of USB/other for they are not built for the boxes
                                    Further the windows is only 32 bit, and the android does have 64 bit, admittedly
                                    • cowboysdudeC
                                      Or go with another Linux distro… I installed it on a computer and installed the mirror on it… worked pretty good and MUCH faster :)
                                      • L
                                        lolobyte @tajno
                                        @tajno
                                        do a cron job to restart your raspi every night!
                                        • A
                                          amanzimdwini @cowboysdude
                                          @cowboysdude
                                          • any SHORT intro on how to put a MM onto an old laptop with Ubuntu running on it?
                                            I have it on two Pis (2 and 3); managed to get it onto a Win10 box - Ubuntu is next :)
                                          • cowboysdudeC
                                            cowboysdude Module Developer @amanzimdwini
                                            @amanzimdwini Installing MM is easy on Unbuntu.
                                            I downloaded it and unpacked it into MagicMirror folder then in a terminal window:
                                            npm install
                                            npm start
                                            Starts right up no issues :)
                                            Pretty much everything works just as it did on a Pi except it’s a lot faster :)
                                            A Mykle1M 2 Replies Last reply Reply Quote 1
