    How to add modules. For absolute beginners.
    91 Posts 16 Posters 161.4k Views 24 Watching
      sdetweil @TheSij
      @TheSij said in How to add modules. For absolute beginners.:
      [2020-07-27 22:56:11.690] [ERROR] Error: Cannot find module ‘async’
      i suspect you did not do the required install in the
      MagicMirror/modules/MMM-PrayerTime folder
      per the instructions
      Installation
      Navigate into your MagicMirror's modules folder
      execute git clone https://github.com/slametps/MMM-PrayerTime.git
      **if this module does not run correctly,** try npm install async
      T S Mykle1M 3 Replies Last reply Reply Quote 0
      • T Offline
        TheSij @sdetweil
        @sdetweil said in How to add modules. For absolute beginners.:
        I am 110% sure I installed the module in the right directory. I always check before I execute it. I’ve just checked the directory, and the module repository is in the right place. I’m executing the ‘npm install async’ command now. Fingers crossed!
          sdetweil @TheSij
          what does that mean?
            I opened an issue on the MMM-PrayerTime module github, for him to create a package.json file for this async dependency and let the system handle it
            https://github.com/slametps/MMM-PrayerTime/issues/43
            • T Offline
              TheSij @sdetweil
              @sdetweil - as in, the files for that module is in the MM modules folder. Sorry if I’m using the wrong terminology.
              So, after running the ‘npm install async’, it found three low vulnerabilities, which I’ve asked for them to be fixed.
              • T Offline
                TheSij @sdetweil
                @sdetweil - thanks. I think I’ve got it working. The module is finally showing in the MM dashboard. Thanks very much for the guidance, and @Mykle1.
                  sdetweil @TheSij
                  @TheSij ignore the vulnerabilities, more trouble than its worth
                  • T Offline
                    TheSij @sdetweil
                    @sdetweil - too late. Sorry, I went ahead before getting this advice. I’ll remember for next time.
                      sdetweil @TheSij
                      @TheSij many times the ‘fixes’ force new code, which breaks old code, so you fix one problem, but the system is dead.
                      more times than not fixing adds new issues to the list, different than u started with. almost NEVER does the list go away.
                      and some of the vulnerabilities matter IF you have your pi connected to the internet where others are interacting with it (logon, save money, messages, …) MM is just pulling update notices. not allowing unsolicited inbound connections…
                      • T Offline
                        TheSij @sdetweil
                        @sdetweil - understood. Thanks!
                          Mykle1 Project Sponsor Module Developer @TheSij
                          Ahh, see? Well done. Don’t sweat it. We’ve all experienced these problems. I promise, it gets easier. The more you learn the easier it becomes. Have fun!
                            For the record, I did not have to install dependencies.
                              sdetweil @Mykle1
                              @Mykle1 because some other module already had. npm install would have resolved that, if he had provided the package. json
                                :thumbsup:
                                • ebolisaE Offline
                                  ebolisa
                                  What if no errors are generated and yet the widget is not shown on the screen? Where do we start troubleshooting?
                                  TIA
                                  Mykle1M S 2 Replies Last reply Reply Quote 0
                                    Mykle1 Project Sponsor Module Developer @ebolisa
                                    @ebolisa said in How to add modules. For absolute beginners.:
                                    It would help if you named the widget (I assume you mean module) and posted your config entry for that module. Please post in a code block.
                                    EDIT:
                                    And everything @sdetweil says. :-)
                                      sdetweil @ebolisa
                                      @ebolisa do you have a position defined? must be else MM doesn’t know where to put the content…
                                      next, look in the window where npm start was done, or in the logs if pm2, using pm2 logs --lines=??? ??? is a number 15 default…
                                      also look in the developers window
                                      ctrl-shift-i, select the tab labeled console, and scroll up… u can also filter by module, add some of the unique part of the module name to the filter field
                                      • F Offline
                                        fsne04
                                        Hi Mykle1. Thank you for doing this. I am trying to build a MagicMirror for my daughter for Christmas and have had a hard time with a few things. Absolute noobie, but have learned a bunch in the past 2 weeks of this journey.
                                        First question: I installed the Kevinatown MMM-Screencast module and after some trial and error, I did get the module to start, BUT as I am starting the casting from my phone, the Screencast window opens and then freezes stating “loading…” without ever actually starting the video/cast. I assume the config entry is correct, because the screencast opens, but maybe I am missing a step?
                                        Your help would be greatly appreciated! ![1_1608396591977_2020-12-19-103618_1024x768_scrot.png](Uploading 100%) ![0_1608396591974_2020-12-19-103955_1024x768_scrot.png](Uploading 100%)
                                        I guess the screenshots did not work. How do I send a screenshot?
                                          sdetweil @fsne04
                                          @fsne04 said in How to add modules. For absolute beginners.:
                                          click the button above the editor that looks like the sun over the mountain, with top right corner folded over
                                          • F Offline
                                            fsne04
                                            • 3 / 5
