    How to add modules. For absolute beginners.
    91 Posts 16 Posters 164.7k Views 24 Watching
      I opened an issue on the MMM-PrayerTime module github, for him to create a package.json file for this async dependency and let the system handle it
      https://github.com/slametps/MMM-PrayerTime/issues/43
      • T
        TheSij @sdetweil
        @sdetweil - as in, the files for that module is in the MM modules folder. Sorry if I’m using the wrong terminology.
        So, after running the ‘npm install async’, it found three low vulnerabilities, which I’ve asked for them to be fixed.
        • T
          TheSij @sdetweil
          @sdetweil - thanks. I think I’ve got it working. The module is finally showing in the MM dashboard. Thanks very much for the guidance, and @Mykle1.
            sdetweil @TheSij
            @TheSij ignore the vulnerabilities, more trouble than its worth
            • T
              TheSij @sdetweil
              @sdetweil - too late. Sorry, I went ahead before getting this advice. I’ll remember for next time.
                sdetweil @TheSij
                @TheSij many times the ‘fixes’ force new code, which breaks old code, so you fix one problem, but the system is dead.
                more times than not fixing adds new issues to the list, different than u started with. almost NEVER does the list go away.
                and some of the vulnerabilities matter IF you have your pi connected to the internet where others are interacting with it (logon, save money, messages, …) MM is just pulling update notices. not allowing unsolicited inbound connections…
                • T
                  TheSij @sdetweil
                  @sdetweil - understood. Thanks!
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @TheSij
                    @TheSij said in How to add modules. For absolute beginners.:
                    Ahh, see? Well done. Don’t sweat it. We’ve all experienced these problems. I promise, it gets easier. The more you learn the easier it becomes. Have fun!
                    • Mykle1M
                      @sdetweil said in How to add modules. For absolute beginners.:
                      i suspect you did not do the required install
                      For the record, I did not have to install dependencies.
                        sdetweil @Mykle1
                        @Mykle1 because some other module already had. npm install would have resolved that, if he had provided the package. json
                        • Mykle1M
                          :thumbsup:
                          • ebolisaE
                            ebolisa
                            What if no errors are generated and yet the widget is not shown on the screen? Where do we start troubleshooting?
                            TIA
                            Mykle1M S 2 Replies Last reply Reply Quote 0
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @ebolisa
                              @ebolisa said in How to add modules. For absolute beginners.:
                              It would help if you named the widget (I assume you mean module) and posted your config entry for that module. Please post in a code block.
                              EDIT:
                              And everything @sdetweil says. :-)
                                sdetweil @ebolisa
                                @ebolisa do you have a position defined? must be else MM doesn’t know where to put the content…
                                next, look in the window where npm start was done, or in the logs if pm2, using pm2 logs --lines=??? ??? is a number 15 default…
                                also look in the developers window
                                ctrl-shift-i, select the tab labeled console, and scroll up… u can also filter by module, add some of the unique part of the module name to the filter field
                                • F
                                  fsne04
                                  Hi Mykle1. Thank you for doing this. I am trying to build a MagicMirror for my daughter for Christmas and have had a hard time with a few things. Absolute noobie, but have learned a bunch in the past 2 weeks of this journey.
                                  First question: I installed the Kevinatown MMM-Screencast module and after some trial and error, I did get the module to start, BUT as I am starting the casting from my phone, the Screencast window opens and then freezes stating “loading…” without ever actually starting the video/cast. I assume the config entry is correct, because the screencast opens, but maybe I am missing a step?
                                  Your help would be greatly appreciated! ![1_1608396591977_2020-12-19-103618_1024x768_scrot.png](Uploading 100%) ![0_1608396591974_2020-12-19-103955_1024x768_scrot.png](Uploading 100%)
                                  I guess the screenshots did not work. How do I send a screenshot?
                                    sdetweil @fsne04
                                    @fsne04 said in How to add modules. For absolute beginners.:
                                    click the button above the editor that looks like the sun over the mountain, with top right corner folded over
                                    • F
                                      fsne04
                                        sdetweil @fsne04
                                        @fsne04 open the developers window, ctrl-shift-i on the keyboard, select the tab labeled ‘console’ and scroll up…
                                        u can also filter messages by module, by placing a unique part of the module name (cast) in the filter field
                                        • F
                                          fsne04 @sdetweil
                                          @sdetweil Hi Sam,
                                          Thank you for the response, but I am not sure what you are asking me to do. Ctl + Shift+i on the Pi4 or on my Mac (where I am writing this)? Also, I don’t know what palancing is, or the last 4 words of your post. Sorry…
                                          Actually, just figured out the last 4… in the filter field (duh)… but which filter field?
                                          Oh and I tried Ctl Shift i on both Pi and Mac, neither one did something. Again sorry about the ignorance…
                                            sdetweil @fsne04
                                            @fsne04 pi of course, where MM is, all keys at the same time
                                            and the ‘filter’ field is the field labeled ‘filter’ in the debug screen
                                            • 3 / 5
