    How to add modules. For absolute beginners.
    91 Posts 16 Posters 164.7k Views 24 Watching
    • T
      TheSij @Mykle1
      @Mykle1 thanks to you and @sdetweil for helping me with this. It’s much appreciated. Deep down I’m reluctant to give up, because I don’t like quitting. I’ve literally just copied your config entry, and simply adding my own lat/lon figures. But now the MagicMirror shows up as a blank black screen and the window is named ‘Electron’, rather than ‘MagicMirror2’.
      I’m checking, double-checking and triple-checking and I can’t see where the discrepancy is compared to your entry. Could having too many modules be an issue? Can I also check - both of you have commented that the ‘timezone’ is causing an error, but your config entry doesn’t show that it’s commented out…?
        sdetweil @TheSij
        @TheSij how do you start MM? npm start, or pm2 start ?
        if npm start, look at the messages shown in the terminal window after the npm start, or better yet, redirect the messages to a file, so you can look at them later
        npm start >somefile 2>&1
        (same as on windows)
        if pm2, then pm2 logs --lines=100 should display the messages…
        black screen,m typically means some library required by a module is not loaded, usually because of a missed install step for the module…
        the area u read on github, is the same as the file README.md after the git clone, so you can look at the instructions
        git clone
        cd modulename
        npm install
        • T
          TheSij @sdetweil
          @sdetweil - this is the log when I started MM just now…
          1 verbose cli [ '/usr/bin/node', '/usr/local/bin/npm', 'start' ]
          2 info using npm@6.14.7
          3 info using node@v10.19.0
          4 verbose stack Error: missing script: start
          4 verbose stack     at run (/usr/local/lib/node_modules/npm/lib/run-script.js:155:19)
          4 verbose stack     at /usr/local/lib/node_modules/npm/lib/run-script.js:63:5
          4 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/read-package-json/read-json.js:116:5
          4 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/read-package-json/read-json.js:436:5
          4 verbose stack     at checkBinReferences_ (/usr/local/lib/node_modules/npm/node_modules/read-package-json/read-json.js:391:45)
          4 verbose stack     at final (/usr/local/lib/node_modules/npm/node_modules/read-package-json/read-json.js:434:3)
          4 verbose stack     at then (/usr/local/lib/node_modules/npm/node_modules/read-package-json/read-json.js:161:5)
          4 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/read-package-json/read-json.js:382:12
          4 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:123:16
          4 verbose stack     at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3)
          5 verbose cwd /home/pi/MagicMirror/modules/MMM-soccer
          6 verbose Linux 4.19.118-v7l+
          7 verbose argv "/usr/bin/node" "/usr/local/bin/npm" "start"
          8 verbose node v10.19.0
          9 verbose npm  v6.14.7
          10 error missing script: start
          11 verbose exit [ 1, true ]
            sdetweil @TheSij
            @TheSij said in How to add modules. For absolute beginners.:
            what did you type?
            the command is
            npm start
            to run MM, you must start from the MagicMirror folder… not a module folder, not the users home folder…
            if you use pm2, it will issue the right commands from the right place
            • T
              TheSij @sdetweil
              @sdetweil - apologies, I was in the wrong directory. This is the terminal response…
              > magicmirror@2.12.0 start /home/pi/MagicMirror
              [2020-07-27 22:56:11.226] [LOG]    Starting MagicMirror: v2.12.0
              [2020-07-27 22:56:11.233] [LOG]    Loading config ...
              [2020-07-27 22:56:11.238] [LOG]    Loading module helpers ...
              [2020-07-27 22:56:11.240] [LOG]    No helper found for module: alert.
              [2020-07-27 22:56:11.290] [LOG]    Initializing new module helper ...
              [2020-07-27 22:56:11.291] [LOG]    Module helper loaded: updatenotification
              [2020-07-27 22:56:11.291] [LOG]    No helper found for module: clock.
              [2020-07-27 22:56:11.643] [LOG]    Initializing new module helper ...
              [2020-07-27 22:56:11.644] [LOG]    Module helper loaded: calendar
              [2020-07-27 22:56:11.645] [LOG]    No helper found for module: currentweather.
              [2020-07-27 22:56:11.646] [LOG]    No helper found for module: weatherforecast.
              [2020-07-27 22:56:11.678] [LOG]    Initializing new module helper ...
              [2020-07-27 22:56:11.678] [LOG]    Module helper loaded: newsfeed
              [2020-07-27 22:56:11.679] [LOG]    No helper found for module: MMM-TFL.
              [2020-07-27 22:56:11.681] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'async'
              Require stack:
              - /home/pi/MagicMirror/modules/MMM-PrayerTime/node_helper.js
              [2020-07-27 22:56:11.682] [LOG]    Loading module helpers ...
              [2020-07-27 22:56:11.683] [LOG]    No helper found for module: alert.
              [2020-07-27 22:56:11.683] [LOG]    Initializing new module helper ...
              [2020-07-27 22:56:11.684] [LOG]    Module helper loaded: updatenotification
              [2020-07-27 22:56:11.684] [LOG]    No helper found for module: clock.
              [2020-07-27 22:56:11.685] [LOG]    Initializing new module helper ...
              [2020-07-27 22:56:11.685] [LOG]    Module helper loaded: calendar
              [2020-07-27 22:56:11.685] [LOG]    No helper found for module: currentweather.
              [2020-07-27 22:56:11.686] [LOG]    No helper found for module: weatherforecast.
              [2020-07-27 22:56:11.686] [LOG]    Initializing new module helper ...
              [2020-07-27 22:56:11.686] [LOG]    Module helper loaded: newsfeed
              [2020-07-27 22:56:11.687] [LOG]    No helper found for module: MMM-TFL.
              [2020-07-27 22:56:11.688] [ERROR]  App threw an error during load
              [2020-07-27 22:56:11.689] [ERROR]  Error: Cannot find module 'async'
              Require stack:
                  at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                  at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                  at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                  at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                  at Module.require (internal/modules/cjs/loader.js:685:19)
                  at require (internal/modules/cjs/helpers.js:16:16)
                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PrayerTime/node_helper.js:9:13)
                  at Module._compile (internal/modules/cjs/loader.js:786:30)
                  at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                  at Module.load (internal/modules/cjs/loader.js:645:32)
              [2020-07-27 22:56:11.690] [ERROR]  Whoops! There was an uncaught exception...
              [2020-07-27 22:56:11.690] [ERROR]  Error: Cannot find module 'async'
              Require stack:
                  at Module.load (internal/modules/cjs/loader.js:645:32) {
                code: 'MODULE_NOT_FOUND',
                requireStack: [
                  '/home/pi/MagicMirror/modules/MMM-PrayerTime/node_helper.js',
                  '/home/pi/MagicMirror/js/app.js',
                  '/home/pi/MagicMirror/js/electron.js',
                  '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                  undefined
              [2020-07-27 22:56:11.696] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              [2020-07-27 22:56:11.697] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              [2020-07-27 22:56:11.814] [LOG]    Launching application.
                sdetweil @TheSij
                [2020-07-27 22:56:11.690] [ERROR] Error: Cannot find module ‘async’
                i suspect you did not do the required install in the
                MagicMirror/modules/MMM-PrayerTime folder
                per the instructions
                Installation
                Navigate into your MagicMirror's modules folder
                execute git clone https://github.com/slametps/MMM-PrayerTime.git
                **if this module does not run correctly,** try npm install async
                T S Mykle1M 3 Replies Last reply Reply Quote 0
                • T
                  TheSij @sdetweil
                  @sdetweil said in How to add modules. For absolute beginners.:
                  I am 110% sure I installed the module in the right directory. I always check before I execute it. I’ve just checked the directory, and the module repository is in the right place. I’m executing the ‘npm install async’ command now. Fingers crossed!
                    sdetweil @TheSij
                    what does that mean?
                      I opened an issue on the MMM-PrayerTime module github, for him to create a package.json file for this async dependency and let the system handle it
                      https://github.com/slametps/MMM-PrayerTime/issues/43
                      • T
                        TheSij @sdetweil
                        @sdetweil - as in, the files for that module is in the MM modules folder. Sorry if I’m using the wrong terminology.
                        So, after running the ‘npm install async’, it found three low vulnerabilities, which I’ve asked for them to be fixed.
                        • T
                          TheSij @sdetweil
                          @sdetweil - thanks. I think I’ve got it working. The module is finally showing in the MM dashboard. Thanks very much for the guidance, and @Mykle1.
                            sdetweil @TheSij
                            @TheSij ignore the vulnerabilities, more trouble than its worth
                            • T
                              TheSij @sdetweil
                              @sdetweil - too late. Sorry, I went ahead before getting this advice. I’ll remember for next time.
                                sdetweil @TheSij
                                @TheSij many times the ‘fixes’ force new code, which breaks old code, so you fix one problem, but the system is dead.
                                more times than not fixing adds new issues to the list, different than u started with. almost NEVER does the list go away.
                                and some of the vulnerabilities matter IF you have your pi connected to the internet where others are interacting with it (logon, save money, messages, …) MM is just pulling update notices. not allowing unsolicited inbound connections…
                                • T
                                  TheSij @sdetweil
                                  @sdetweil - understood. Thanks!
                                  • Mykle1M
                                    Mykle1 Project Sponsor Module Developer @TheSij
                                    Ahh, see? Well done. Don’t sweat it. We’ve all experienced these problems. I promise, it gets easier. The more you learn the easier it becomes. Have fun!
                                    • Mykle1M
                                      For the record, I did not have to install dependencies.
                                        sdetweil @Mykle1
                                        @Mykle1 because some other module already had. npm install would have resolved that, if he had provided the package. json
                                        • Mykle1M
                                          :thumbsup:
                                          • ebolisaE
                                            ebolisa
                                            What if no errors are generated and yet the widget is not shown on the screen? Where do we start troubleshooting?
                                            TIA
                                            Mykle1M S 2 Replies Last reply Reply Quote 0
                                            • 3 / 5
