    MMM-DWD-WarnWeather - Wetterwarnungen
    62 Posts 27 Posters 78.6k Views 28 Watching
    • O
      ostfilinchen
      now it Looks good. One Correction please. Can u Change the Headline to the Standard like calender and so on? In the pic of my post i mean the Headline “1. Bundesliga 2016/2017”.
      I have commented out line 56-60 in MMM-DWD-WarnWeather.js. And in my custom.css i add these lines:
      .MMM-DWD-WarnWeather div.displaytitle {
      text-transform: uppercase;
      font-size: 15px;
      font-family: “Roboto Condensed”;
      border-bottom: 1px solid #666;
      line-height: 15px;
      padding-bottom: 5px;
      margin-bottom: 10px;
      color: white;
      L L 2 Replies Last reply Reply Quote 0
      • L
        LukeCodewalker Module Developer @ostfilinchen
        @ostfilinchen : done =)
        • L
          So that’s how it looks now.
          • O
            ostfilinchen
            Thanks! Great job
            • L
              I made some small changes to the formatting of the date. It now looks like this:
              • T
                tajno
                Nice work and thanks for shareing!
                Does the german wheater forecast provide an API? Are those warnings for a special region or a general broadcast for your state (Bundesland)?
                I think I have look if the Swiss guys does too, usually they provide alot of datas (ch opendata) - Need those warnings too, especially for snow/icy conditions :).
                • L
                  LukeCodewalker Module Developer @tajno
                  Hey @tajno,
                  they don’t really provide an API. I did a bit of reverse engineering on their website and found that you can get a JSON file with all the warnings for Germany for a specific time.
                  This JSON contains warnings for all regions (Landkreise) of Germany.
                  If you find an API for Switzerland I can help you to implement it.
                    Jopyth Moderator @LukeCodewalker
                    @LukeCodewalker Very interesting module, will you add this to the wiki as well?
                    Also why did you make a custom header? Wouldn’t it be better to use the default header functionality?
                    • L
                      LukeCodewalker Module Developer @Jopyth
                      @Jopyth Thank you. Yes I will add it.
                      Sure I will fix it soon.
                      • L
                        @weedorbeat good idea. I’ll put that on my list.
                        • L
                          @weedorbeat hey,
                          do you have an idea, how the warnings should show for which region they are? Just making a header for each region would not be very nice in my opinion. My first idea was to put the region in brackets behind the warning. But i definitely want to keep the appearance of the module very simple/small. Another thing I want to implement is the starting altitude of the warning (like “Schneefall ab 400m”). But there i have the same problem: I don’t had an idea how to display it with keeping the module looking nice.
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @LukeCodewalker
                            @LukeCodewalker to display different things in a module, i implemented kind of caroussels in a couple of my modules to show only one part per time interval e.g. 20 seconds. this will result in a small display but can handle a lot of informations. in the develop branch is a new feature to extend the header defined by the user with custom values. you could add there the region.
                            • L
                              Ok now it looks like this:
                              It’s using the default header functionality now.
                              To have more than one region you have to put the module two times in your config like
                              	module: 'MMM-DWD-WarnWeather',
                              	position: 'bottom_left',
                              	header: 'Oberbergischer Kreis',
                              		region: 'Oberbergischer Kreis',
                              		changeColor: true,
                              		interval: 10*60*1000
                              	header: 'Kreis Deggendorf',
                              		region: 'Kreis Deggendorf',
                              		changeColor: true,
                                Matthes0815
                                Hey,
                                nice work, great addition to my setup, thank you!
                                I currently have two problems.
                                When there are two notifications, the second one is indented (can’t make a screenshot right now, sorry).
                                And on Firefox (I usually open the mm on my pc, too) the symbols are really, really large: .sprite_sturm has a size of 256x256px, this could be a little bit smaller… I guess Firefox handles the css different, on the mirror they have the right size.
                                • L
                                  LukeCodewalker Module Developer @Matthes0815
                                  @Matthes0815 Thank you.
                                  I will have a look over that, when I got some time.
                                    Matthes0815
                                    You’re welcome… take your time, it’s not really a problem.
                                    Here now a photo of the indented warnings:
                                    • T
                                      thk
                                      @LukeCodewalker
                                      Great module, thanks a lot!
                                      Having the same issue on Firefox with the icon size as Matthes0815.
                                      Also the warnings are shown twice.
                                      I´ve setup the config to poll DWD warnings for my region (Landkreis), any idea why this happens?
                                      • L
                                        Ok. Firefox bug should be fixed now.
                                        Maybe you see the warning twice because DWD is having it twice on their website?
                                        For further issues please use the new Trubleshooting thread. Thank you.
                                        • L
                                          @Matthes0815 said in MMM-DWD-WarnWeather - Wetterwarnungen:
                                          Are you using the latest version of this module? I could not reproduce this bug.
                                          Are you
                                            Matthes0815
                                            It was the latest version when I took the photo. Sadly the weather here is nice and friendly, no warnings at the moment…
                                            Where are the autumn storms when you need them?
                                            • 1 / 4
