    MMM-DWD-WarnWeather - Wetterwarnungen
    62 Posts 27 Posters 78.6k Views 28 Watching
    • L
      LukeCodewalker Module Developer
      Hey,
      i did no debugging yet.
      I will Check that soon and will inform you when its fixed.
      Maybe you can Start an issue.
      • L
        LukeCodewalker Module Developer @ostfilinchen
        Hey @ostfilinchen,
        css should be fixed now.
        Can you please check it?
        • O
          ostfilinchen @LukeCodewalker
          @LukeCodewalker: it’s better but always the width is to great.
          And now, no warnings would be loaded. It stops with “Warnungen werden geladen”. It must Display “keine Warnungen”, because there’re no warnings.
          • L
            @ostfilinchen : ok, now everything should be fine.
            could you please check that?
            Thanks for your help =)
            • O
              ostfilinchen
              now it Looks good. One Correction please. Can u Change the Headline to the Standard like calender and so on? In the pic of my post i mean the Headline “1. Bundesliga 2016/2017”.
              I have commented out line 56-60 in MMM-DWD-WarnWeather.js. And in my custom.css i add these lines:
              .MMM-DWD-WarnWeather div.displaytitle {
              text-transform: uppercase;
              font-size: 15px;
              font-family: “Roboto Condensed”;
              border-bottom: 1px solid #666;
              line-height: 15px;
              padding-bottom: 5px;
              margin-bottom: 10px;
              color: white;
              L L 2 Replies Last reply Reply Quote 0
              • L
                @ostfilinchen : done =)
                • L
                  So that’s how it looks now.
                  • O
                    ostfilinchen
                    Thanks! Great job
                    • L
                      I made some small changes to the formatting of the date. It now looks like this:
                      • T
                        tajno
                        Nice work and thanks for shareing!
                        Does the german wheater forecast provide an API? Are those warnings for a special region or a general broadcast for your state (Bundesland)?
                        I think I have look if the Swiss guys does too, usually they provide alot of datas (ch opendata) - Need those warnings too, especially for snow/icy conditions :).
                        • L
                          LukeCodewalker Module Developer @tajno
                          Hey @tajno,
                          they don’t really provide an API. I did a bit of reverse engineering on their website and found that you can get a JSON file with all the warnings for Germany for a specific time.
                          This JSON contains warnings for all regions (Landkreise) of Germany.
                          If you find an API for Switzerland I can help you to implement it.
                            Jopyth Moderator @LukeCodewalker
                            @LukeCodewalker Very interesting module, will you add this to the wiki as well?
                            Also why did you make a custom header? Wouldn’t it be better to use the default header functionality?
                            • L
                              LukeCodewalker Module Developer @Jopyth
                              @Jopyth Thank you. Yes I will add it.
                              Sure I will fix it soon.
                              • L
                                @weedorbeat good idea. I’ll put that on my list.
                                • L
                                  @weedorbeat hey,
                                  do you have an idea, how the warnings should show for which region they are? Just making a header for each region would not be very nice in my opinion. My first idea was to put the region in brackets behind the warning. But i definitely want to keep the appearance of the module very simple/small. Another thing I want to implement is the starting altitude of the warning (like “Schneefall ab 400m”). But there i have the same problem: I don’t had an idea how to display it with keeping the module looking nice.
                                  • strawberry 3.141S
                                    strawberry 3.141 Project Sponsor Module Developer @LukeCodewalker
                                    @LukeCodewalker to display different things in a module, i implemented kind of caroussels in a couple of my modules to show only one part per time interval e.g. 20 seconds. this will result in a small display but can handle a lot of informations. in the develop branch is a new feature to extend the header defined by the user with custom values. you could add there the region.
                                    • L
                                      Ok now it looks like this:
                                      It’s using the default header functionality now.
                                      To have more than one region you have to put the module two times in your config like
                                      	module: 'MMM-DWD-WarnWeather',
                                      	position: 'bottom_left',
                                      	header: 'Oberbergischer Kreis',
                                      		region: 'Oberbergischer Kreis',
                                      		changeColor: true,
                                      		interval: 10*60*1000
                                      	header: 'Kreis Deggendorf',
                                      		region: 'Kreis Deggendorf',
                                      		changeColor: true,
                                        Matthes0815
                                        Hey,
                                        nice work, great addition to my setup, thank you!
                                        I currently have two problems.
                                        When there are two notifications, the second one is indented (can’t make a screenshot right now, sorry).
                                        And on Firefox (I usually open the mm on my pc, too) the symbols are really, really large: .sprite_sturm has a size of 256x256px, this could be a little bit smaller… I guess Firefox handles the css different, on the mirror they have the right size.
                                        • L
                                          LukeCodewalker Module Developer @Matthes0815
                                          @Matthes0815 Thank you.
                                          I will have a look over that, when I got some time.
                                            Matthes0815
                                            You’re welcome… take your time, it’s not really a problem.
                                            Here now a photo of the indented warnings:
                                            • 1 / 4
