    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 954.3k Views 77 Watching
    • Mr.MeeseeksM
      Mr.Meeseeks
      @Jopyth would it be ok to add module specific functionality/backend only if that module was installed? Thoughts?
      CAAAAN DOO!👍
      J 1 Reply Last reply
        Jopyth Moderator @Mr.Meeseeks
        @Mr.Meeseeks What do you mean? Like offer alert sending in the menu only if an alert module is running? Are there any other things which depend on installed modules?
        Mr.MeeseeksM 1 Reply Last reply
        • Mr.MeeseeksM
          Mr.Meeseeks @Jopyth
          @Jopyth like support a backend/menu for say a gallery module, but only if it’s installed. It would be very beneficial but might add bloat and future compatibility issues. Alert is fine because it’s a default.
          CAAAAN DOO!👍
            @Mr.Meeseeks Its installed by default, but not neccesarily in the config and on the mirror. :)
            That is something I also wanted, but I was not clear on the specification of it. My first draft.
            The actions must definitely be offered by the modules themselves.
            • Mr.MeeseeksM
              Mr.Meeseeks
              Right, ya, or have yet another module directory inside remote to inject menu definitions node/remote/module code for module’s remote backend, like magic mirror… Damn getting complex, ha. But your right maybe for now needs to hide alert menu if not installed.
              CAAAAN DOO!👍
              • ManmachineM
                Manmachine
                Hi Jopyth,
                First, thanks for a great module that I have a lot of benefit of. Super well done!
                However, I have an idea that I would inquire if you could possibly help with.
                It concerns that I have a Smart Home Controller (Zipato Tile) where it is possible to send http get / post / put / delete.
                At this sitting blah. Z-Wave PIR Sensor, which is in the same room as my Magic Mirror, which through rule in Zipato Tile could send http post to your module and for example, “Turn Monitor ON”
                Will this be possible? If so, how would the syntax look like? (I’m definitely not strong in coding javascript)
                I would think it must be something along the: http://[Magic Mirror IP]/remote?Action= MONITORON
                Or am I way off?
                Thanks in advance
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @Manmachine
                  @Manmachine action should be lowercase and dont forget to add the port specified in the config behind the ip
                  https://github.com/Jopyth/MMM-Remote-Control#examples
                  ManmachineM 2 Replies Last reply
                  • ManmachineM
                    Manmachine @strawberry 3.141
                    Super! thanks i’ll give it a change.
                    Will return soon with an update within the next few days =)
                    • ManmachineM
                      @strawberry-3.141
                      DOH! - it has indeed been in the documentation all the time! (How the heck could I miss it?)
                      there I sat and tried to find out how the code worked!
                      how stupid of me!
                      • lolobyteL
                        lolobyte
                        Hi, that’s great what u have done.
                        Why it doesn’t work on PC Browser? http://192.168.xxx.xx:8080/
                        On my HDMI monitor all thinks ok.
                          Jopyth Moderator @lolobyte
                          @lolobyte It should work with any browser. Did you replace the 192.168.xxx.xxx with the IP of your raspberry pi? If you set a position for the module, you should also be able to see the URL on your mirror, for example the following should show the URL to the remote inf the bottom left:
                              module: 'MMM-Remote-Control',
                              position: 'bottom_left'
                          lolobyteL 1 Reply Last reply
                          • lolobyteL
                            lolobyte @Jopyth
                            @Jopyth
                            OK, now it works. Was a browser problem with Maxthon. Thank u, but the modules MagicMirror-Netatmo-Module and MMM-Fuel are not shown in the Browser!
                            At the monitor the are visible.
                              @lolobyte This is not related to the Remote Control, is it? Please make a a post in the troubleshooting section possibly with the configurations of your netatmo and Fuel modules, maybe something is wrong in your config.js.
                                MagicMirrorPi
                                That is a very nice module - thanks!
                                I have one question. In which way you control this module or your mirror? Do you have a keyboard or mouse on it? I didn’t find a way to control this module on the magic mirror.
                                yawnsY 1 Reply Last reply
                                • yawnsY
                                  yawns Moderator @MagicMirrorPi
                                  @MagicMirrorPi
                                  Are you talking about MMM-Remote-Control?
                                  It is called remote because you use it to remote manage the mirror. So you can use it on your laptop, smartphone, tablet, … without having to attach mouse/keyboard to the mirror itself
                                  Reply Quote 3
                                    MagicMirrorPi
                                    Thanks. That answered my question. I was wondering, how to control the mirror without hardware :)
                                    Another nice implementation is the Skywriter i think with gestures.
                                    • lolobyteL
                                      lolobyte
                                      Hello, i made the MM2 update and now i can’t access the remote.
                                      I can’t insert my ip from my laptop.
                                      I want to access MagicMirror from laptop with Remote Control, but it’s not possible now with this update.
                                      Where i have to insert my ip address in the white-list?
                                      How to insert a range?
                                      • A
                                        AAPS
                                        I am having the same problem. Does @Jopyth just need to update or is there a bigger issue?
                                        • lolobyteL
                                          lolobyte
                                          Hi all,
                                          it works.
                                          That is my part of config with the ipwhitelist.
                                              ipWhitelist: [
                                                              "127.0.0.1",
                                                              "::ffff:127.0.0.1",
                                                              "::1",
                                                              "::ffff:192.168.1.1/24",
                                          hope it will help all other user.
                                          • A
                                            AAPS
                                            I know I probably sound dumb, but what is ipWhitelist, and will mine look different than yours?
                                            Thanks anyway.
                                            • 13
                                            • 14
                                            • 5 / 14
