    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 246.8k Views 38 Watching
      shavesophere
      great module! I’m curious to know how to configure it for “small”… i can’t find any clue in the documentation apart from trying to fiddle around with the .css. thanks!
      D 1 Reply Last reply
        dmcinnes Module Developer @shavesophere
        @shavesophere thanks! You can add the ‘small’ class to the module’s classes in the config.js.
          I’ve just pushed an update to the module. Previously if there was a network error the module would get “stuck” and no longer update. This is now fixed!
          [card:dmcinnes/MMM-forecast-io]
            shavesophere @dmcinnes
            @dmcinnes forgive me I’m a noob when it comes to classes in javascript… you you be so kind as to post the code that needs altering?
              @shavesophere sorry I wasn’t too descriptive!
              Here’s the example from the repo with the added ‘small’ class, forth line from the top:
                  module: 'MMM-forecast-io',
                  position: 'top_right',  // This can be any of the regions.
                  classes: 'small',
                    apiKey: 'abcde12345abcde12345abcde12345ab', // Dark Sky API key.
                    // Only required if geolocation doesn't work:
                    latitude:   16.77532,
                    longitude: -3.008265
              Hope that helps!
                @dmcinnes ah i see! much obliged. keep up the good work!
                  Rian9771
                  Hello, has something changed to this module? I have clones the repo twice but i still don’t see the graph being displayed. Did ‘git checkout weather-forecast’ as mentioned but still a no go. I can see everything else but the graph. I am on debian, node serveronly, Firefox.
                    dmcinnes Module Developer @Rian9771
                    Hi @Rian9771 the rain graph only appears when there’s rain happening in the next hour.
                      phrazelle
                      Hello! Thanks for your time with this module!
                      I would like to customize the weather icons. I am able to change the overall color of the icons with CSS, but taking that a step further, is there a way to alter sections of the icons instead of the icon as a whole?
                      I.e. wi-day-cloudy with an orange sun poking out from a grey cloud.
                      I see that the icons are pulled from the erikflowers github repository, but I don’t see where they are pulling from within the module. Based on most of these weather modules using the same iconset, I’m guessing they’re being pulled from that repo directly.
                      My initial thought was to extract from the module, recolor with Photoshop and then replace the icons in the module. Is that possible? Would I just make a whole new set, store locally and change the path somewhere in the JS?
                      • strawberry 3.141S
                        strawberry 3.141 Project Sponsor Module Developer @phrazelle
                        @phrazelle the css is located in the magicmirror vendor folder
                        P 1 Reply Last reply
                          phrazelle @strawberry 3.141
                          @strawberry-3.141 Thanks for the info!
                          After looking through there, it looks like the module pulls the icons as a font file. I believe that would mean that CCS customization would be overall to each displayed character. So there would be no way to color segments of each character (like an orange sun poking out from a grey cloud) because the stylization would apply to the character as a whole.
                          Am I assessing at that correctly?
                          • ooom416354O
                            ooom416354
                            Great module!! One question, is there anyway to make the length of the temperature bars a bit smaller? I suppose because the NY weather is so erratic right now it is making the bars wider but was just curious if I can shrink them a bit to save some space. thanks!
                            • ooom416354O
                              ooom416354
                              also it could just be me but I keep seeing the rain icon next to the temperature even though there’s no rain in the forecast for today (the small icon by the days of the week shows nothing but sun). Anything I can do to check that icon to see if it is an issue?
                                bminer1
                                Im getting the below when i try to install:
                                pi@raspberrypi:~/MagicMirror/modules $ git pull https://github.com/dmcinnes/MMM-forecast-io.git
                                From https://github.com/dmcinnes/MMM-forecast-io
                                 * branch            HEAD       -> FETCH_HEAD
                                *** Please tell me who you are.
                                Run
                                  git config --global user.email "you@example.com"
                                  git config --global user.name "Your Name"
                                to set your account's default identity.
                                Omit --global to set the identity only in this repository.
                                fatal: empty ident name (for <pi@raspberrypi.(none)>) not allowed
                                How do i fix this in order to install?
                                morozgrafixM 1 Reply Last reply
                                • morozgrafixM
                                  morozgrafix Moderator @bminer1
                                  @bminer1 it seems that you are trying to pull instead of clone (and git is not globally configured on your system and doesn’t recognize you)
                                  try running this command instead: git clone https://github.com/dmcinnes/MMM-forecast-io.git
                                    bminer1
                                    noob mistake. Installed now. Thanks!!
                                    I feel like an idiot. This machine will not beat me!!
                                      bminer1
                                      I’m not getting any graph for precipitation. Will it only be there if there is rain/snow in the next x amount of hours?
                                      • morozgrafixM
                                        @bminer1 I believe that default setting is not to show precipitation graph, unless there is a prediction for rain or snow in next hour. I think it takes data from minutely weather forecast supplied by DarkSky.
                                        • FlatPepsiF
                                          FlatPepsi
                                          I love the simplicity of MMM-Forecast.io, and yet wanted more from the graph. The default graph seems to be aimed at minutely weather for the near future.
                                          Earlier in this thread there was a graph example from dmcinnes’s mirror:
                                          https://github.com/jangellx/MagicMirror#important-installation-note
                                          Sadly, the code from that mirror’s graph is a totally different approach than the main branch of forecast.io. Stealing code was not an option, so I had to write a bunch from scratch.
                                          For my own use, I’ve rewritten a lot of the graph- and added in a few goodies, like:
                                          -Graph now shows 36 hours of forecast
                                          -Day/night shading in graph
                                          -Temperature line in graph with labels
                                          -Precip intensity graph is now blue.
                                          -Graph has freezing blue line, and hot 80 degree line.
                                          -Wind speed is an option to turn on/off
                                          -Sunrise/Sunset is an option to turn on/off
                                          -Included notes for easy color icons, via “Color-icons.md”
                                          my new weather graph
                                          Feel free to play with my branch:
                                          https://github.com/FlatPepsi17/MMM-forecast-io/tree/FlatPepsi17-GraphUpgrade
                                          Known limitation: non-Fahrenheit units will probably look funny, as the graph scaling & hot/cold lines are not unit aware.
                                            dmcinnes Module Developer @ooom416354
                                            @ooom416354 sorry about taking so long to reply! You can shrink the module a bit by using the MagicMirror’s size classes. I normally have mine set as “small”.
                                              classes: 'small'
                                            • 2 / 7
