    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 246.8k Views 38 Watching
      Claymobil
      @ianperrin Thanks a lot !
      Works perfectly fine now :-)
      D 1 Reply Last reply
        dmcinnes Module Developer @Claymobil
        @Claymobil glad it works! Sorry about that, that missing comma is in the example config. I’ve updated it.
          darrene
          Hi @dmcinnes, thank you for sharing an awesome module. It’s fantastic - the first one I installed and I think it must be the only one I haven’t swapped out since :)
          Is there any chance of having a precipitation/temperature graph like the one from Jangellx’s variant of @MichMich’s MagicMirror1, which could be swapped out for the current precipitation graph?
          The bulk of the javascript looks to be in the bottom half of this code: GitHub, uses d3 and d3min but it’s completely beyond me how to Frankenstein the code together…
          It’d give a superb optional look to a lovely module!
            plumcraft
            @paulocarrasco
            Have you done your forecast module by any chance ?
              dmcinnes Module Developer @darrene
              @darrene glad you like the module! That would be cool to have but I’m working on another project right now so I’m not interested in taking that on. If anyone else wants to take a try at doing it, please be my guest and send a PR!
              The original module used SVG, but I used HTML5 canvas to avoid external libraries (plus I prefer canvas anyway).
                shavesophere
                great module! I’m curious to know how to configure it for “small”… i can’t find any clue in the documentation apart from trying to fiddle around with the .css. thanks!
                  dmcinnes Module Developer @shavesophere
                  @shavesophere thanks! You can add the ‘small’ class to the module’s classes in the config.js.
                    I’ve just pushed an update to the module. Previously if there was a network error the module would get “stuck” and no longer update. This is now fixed!
                    [card:dmcinnes/MMM-forecast-io]
                      shavesophere @dmcinnes
                      @dmcinnes forgive me I’m a noob when it comes to classes in javascript… you you be so kind as to post the code that needs altering?
                        @shavesophere sorry I wasn’t too descriptive!
                        Here’s the example from the repo with the added ‘small’ class, forth line from the top:
                            module: 'MMM-forecast-io',
                            position: 'top_right',  // This can be any of the regions.
                            classes: 'small',
                              apiKey: 'abcde12345abcde12345abcde12345ab', // Dark Sky API key.
                              // Only required if geolocation doesn't work:
                              latitude:   16.77532,
                              longitude: -3.008265
                        Hope that helps!
                          @dmcinnes ah i see! much obliged. keep up the good work!
                            Rian9771
                            Hello, has something changed to this module? I have clones the repo twice but i still don’t see the graph being displayed. Did ‘git checkout weather-forecast’ as mentioned but still a no go. I can see everything else but the graph. I am on debian, node serveronly, Firefox.
                              dmcinnes Module Developer @Rian9771
                              Hi @Rian9771 the rain graph only appears when there’s rain happening in the next hour.
                                phrazelle
                                Hello! Thanks for your time with this module!
                                I would like to customize the weather icons. I am able to change the overall color of the icons with CSS, but taking that a step further, is there a way to alter sections of the icons instead of the icon as a whole?
                                I.e. wi-day-cloudy with an orange sun poking out from a grey cloud.
                                I see that the icons are pulled from the erikflowers github repository, but I don’t see where they are pulling from within the module. Based on most of these weather modules using the same iconset, I’m guessing they’re being pulled from that repo directly.
                                My initial thought was to extract from the module, recolor with Photoshop and then replace the icons in the module. Is that possible? Would I just make a whole new set, store locally and change the path somewhere in the JS?
                                • strawberry 3.141S
                                  strawberry 3.141 Project Sponsor Module Developer @phrazelle
                                  @phrazelle the css is located in the magicmirror vendor folder
                                  P 1 Reply Last reply
                                    phrazelle @strawberry 3.141
                                    @strawberry-3.141 Thanks for the info!
                                    After looking through there, it looks like the module pulls the icons as a font file. I believe that would mean that CCS customization would be overall to each displayed character. So there would be no way to color segments of each character (like an orange sun poking out from a grey cloud) because the stylization would apply to the character as a whole.
                                    Am I assessing at that correctly?
                                    • ooom416354O
                                      ooom416354
                                      Great module!! One question, is there anyway to make the length of the temperature bars a bit smaller? I suppose because the NY weather is so erratic right now it is making the bars wider but was just curious if I can shrink them a bit to save some space. thanks!
                                      • ooom416354O
                                        ooom416354
                                        also it could just be me but I keep seeing the rain icon next to the temperature even though there’s no rain in the forecast for today (the small icon by the days of the week shows nothing but sun). Anything I can do to check that icon to see if it is an issue?
                                          bminer1
                                          Im getting the below when i try to install:
                                          pi@raspberrypi:~/MagicMirror/modules $ git pull https://github.com/dmcinnes/MMM-forecast-io.git
                                          From https://github.com/dmcinnes/MMM-forecast-io
                                           * branch            HEAD       -> FETCH_HEAD
                                          *** Please tell me who you are.
                                          Run
                                            git config --global user.email "you@example.com"
                                            git config --global user.name "Your Name"
                                          to set your account's default identity.
                                          Omit --global to set the identity only in this repository.
                                          fatal: empty ident name (for <pi@raspberrypi.(none)>) not allowed
                                          How do i fix this in order to install?
                                          morozgrafixM 1 Reply Last reply
                                          • morozgrafixM
                                            morozgrafix Moderator @bminer1
                                            @bminer1 it seems that you are trying to pull instead of clone (and git is not globally configured on your system and doesn’t recognize you)
                                            try running this command instead: git clone https://github.com/dmcinnes/MMM-forecast-io.git
                                            • 2 / 7
