    "No Signal" message when PIR sensor is triggered
    16 Posts 7 Posters 7.0k Views 6 Watching
      steverichab
      The MMM-PIRSensor is working perfectly. Unfortunately when the sensor times out due to no presents detected I get a blue screen with “No Signal” on my monitor/screen. Here’s my config:
      		module: 'MMM-PIR-Sensor',
      		position: "top_center", // Remove this line to avoid having an visible indicator
      			sensorPin: 22,
      			powerSaving: true,
      			powerSavingDelay: 10, // Turn HDMI OFF after 60 seconds of no motion, until motion is detected again
      			preventHDMITimeout: 1, // Turn HDMI ON and OFF again every 4 minutes when power saving, to avoid LCD/TV timeout
      			supportCEC: true,
      			presenceIndicator: "fa-eye", // Customizing the indicator
      			presenceOffIndicator: "fa-eye", // Customizing the indicator
      			presenceIndicatorColor: "#f51d16", // Customizing the indicator
      			presenceOffIndicatorColor: "#2b271c" // Customizing the indicator
      I have enabled HDMI CEC on my monitor. I just want it to go dark. any suggestions?
      Thanks in advance!!
      S lavolp3L 3 Replies Last reply Reply Quote 0
        sdetweil @steverichab
        @steverichab don’t know the answer, but when u paste config or code, please use the code block,
        after pasting the text, select it, and hit the </> button above the editor to wrap the text
          @steverichab oh, and my TV does the same… the HDMI is turned off at the PI, so the tv shows no input
            steverichab
            Thanks Sam, As you can tell I’m a newbie but I really appreciate the coaching!
            Is there a way to simple trigger a black screen saver via the PIRSensor module? really anything but a blue “No Signal” message.
            SergeS 1 Reply Last reply Reply Quote 0
            • SergeS
              Serge @steverichab
              @steverichab with mmm-remotecontrol you can “hide” all modules. So you will get a clear black screen without “no signal” message.
                steverichab @Serge
                @Serge said in "No Signal" message when PIR sensor is triggered:
                mmm-remotecontrol
                Thank You Serge, not sure how to hide when the PIR sensor module is triggered. I will start to work on it.
                  steverichab @steverichab
                  @steverichab Wow Serg, My head exploded while trying to get the the MMM-Remote-Control module to “hide” just the calendar module when triggered by the MMM-PIRSensor module. Could you show or point me to an example of these two modules getting rid of this “no signal” problem.
                  Thanks!
                  • lavolp3L
                    lavolp3 Module Developer @steverichab
                    @steverichab said in "No Signal" message when PIR sensor is triggered:
                    			sensorPin: 22,
                    			powerSaving: true,
                    			supportCEC: true,
                    Thanks in advance!!
                    I have the same issue, and I am sure there was a time I got the monitor turned off directly with another module.
                    I think there are different ways of turning the monitor off, at least for more recent Raspberry Pis and this module might be using the wrong one for us.
                    I wanted to look into this more, you motivated me again :-).
                    How to troubleshoot modules
                    MMM-soccer v2, MMM-AVStock
                      steverichab @lavolp3
                      @lavolp3 Thanks, I hope you come up with something. As I said the frame is functioning perfectly except for the “no signal” problem. The MMM-Remote-Control module is tempting but I was not able to figure out how to “hide” everything when the PIR sensor triggered.
                      wishmaster270W lavolp3L 2 Replies Last reply Reply Quote 0
                      • wishmaster270W
                        wishmaster270 Module Developer @steverichab
                        @steverichab Hi, there are other PIR modules that support hiding out of the box like MMM-NewPIR or mine MMM-Screen-Powersave-Notification.
                        My module needs my GPIO module to get triggered. You ca find a complete example here
                        • uros76U
                          uros76
                          Are you on Pi 4 perhaps? I also got the same problem with the module mentioned above.
                          Then I switched to this one and it works https://github.com/bugsounet/MMM-NewPIR
                          • lavolp3L
                            @steverichab there are two different ways to turn off the hdmi monitor.
                            vcgencmd display_power 0 turns of the hdmi controller. The monitor will go into standby mode after that.
                            tvservice -o is another option. It probably does the same but I’m not sure. MIght work better and send the monitor directly into sleep.
                            Both commands are bash commands and can be tried from an ssh shell.
                            if you try out the tvservice command you might need a more complex command to get the mirror GUI back.
                            /opt/vc/bin/tvservice -p; sudo /bin/chvt 6; sudo /bin/chvt 7
                              @lavolp3 the real issue here is, can I blank and restore the MagicMirror modules using the PIR module in MM2?
                              Would either of these two options work from within the PIR module?
                              I keep trying to find a hide or show all(modules) command that I could trigger from within the PIR module similar to the “powerSaving” command that turns off the HDMI port but unfortunately causes the “no Signal” message to appear.
                              Thanks Again
                                steverichab @uros76
                                @uros76 I am using a 3B+ and I have tried the MMM-NewPIR module and it appears to behave the same with my monitor. As soon as I turn off the HDMI port via the PIR module I get “No Signal”
                                  @steverichab right, u need to turn off the monitor, not the HDMI signal… some monitors support that. some don’t (none of mine do)…
                                  • cruunnerrC
                                    cruunnerr
                                    Long time ago I visited this forum, so I don’t know if this will help. but the MMM-ModuleScheduler can hide all modules per notifications. So maybe you can trigger the module with your pir-module.
                                    Or take a look at point 6 in this tutorial
                                    https://forum.magicmirror.builders/topic/6291/howto-turn-on-off-your-monitor-time-based-pir-button-app/2
