    MMM-NOAA
    68 Posts 15 Posters 59.1k Views 13 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @evroom
      @evroom
      Ok, my bad on my previous answer. My apologies. :-/
      At the risk of answering in error again, I will say that the module determines your location (geo-location or some such)
      • cowboysdudeC
        cowboysdude Module Developer @evroom
        @evroom It automatically gets the latitude and longitude and uses that :)
        • evroomE
          evroom
          Okay, I see it uses http://ip-api.com/json to determine latitude and longitude.
          It is depending on the proxy server in use.
          I am at work now (in Germany) and I see my proxy server is located in Paris, France right now.
          Will try it at home to see for which location the weather is presented on my MM.
          MagicMirror version: 2.37.0
          • evroomE
            evroom
            It appears to use the data from the proxy provider.
            In my case the latitude and longitude are 67 kilometres away from my real location.
            Also the “city” does not correspond with the “lat” and “lon” when I look them up in Google Maps.
            Probably the “city” is from my provider and the “lat” and “lon” from the proxy server of that provider.
            Therefore I decided to give MMM-YrThen a try, which looks nice.
            Sorry to the persons that put so much efford in MMM-NOAA.
            • strawberry 3.141S
              there should be the possibility to set the lat and lon yourself, maybe someone is also interested in a weather at a different location. Only if no lat lon was provided you should try to get it via this ip api provider
              • bheplerB
                bhepler Module Developer
                I’ve been trying to get this module to work and for the life of me I can’t get it to show up. I’ve gone as minimalist as I can and it’s still not appearing.
                Here’s my config:
                     module: "MMM-NOAA",
                          apiKey: "debxxxxxx",
                          airKey: "Fpyyyyy"
                Here’s the error that I see in the web browser:
                TypeError: "allDay is undefined"
                getDomhttp://10.0.0.10:8080/modules/MMM-NOAA//MMM-NOAA.js:344:2
                updateDomhttp://10.0.0.10:8080/js/main.js:110:28
                updateDomhttp://10.0.0.10:8080/js/main.js:109:10
                createDomObjectshttp://10.0.0.10:8080/js/main.js:53:29
                createDomObjectshttp://10.0.0.10:8080/js/main.js:24:3
                modulesStartedhttp://10.0.0.10:8080/js/main.js:471:4
                startModuleshttp://10.0.0.10:8080/js/loader.js:59:3
                loadNextModulehttp://10.0.0.10:8080/js/loader.js:40:6
                onloadhttp://10.0.0.10:8080/js/loader.js:203:42
                And I keep seeing this in the pm2 logs:
                0|MagicMir | libGL error: MESA-LOADER: failed to retrieve device information
                0|MagicMir | MESA-LOADER: failed to retrieve device information
                Hein-JanH 1 Reply Last reply
                • Hein-JanH
                  Hein-Jan @bhepler
                  @bhepler
                  As far as I can tell the
                  Is due to the Open GL driver. I am using the Fake KMS and these are mine errors. I am not using NOAA.
                    rickelmund
                    @evroom said in MMM-NOAA:
                    Well. Stumbled on this just now and same thing for me. But I don’t understand as https://www.abstractapi.com/ip-geolocation-api returns Sweden for me… How is that even possible
                    Mykle1M 1 Reply Last reply
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @rickelmund
                      @rickelmund
                      You don’t have to use geolocation at all. I use my latitude and longitude and it fires right up. The module does error in the terminal, but only once. Then it performs as expected with no further errors.
                      R 1 Reply Last reply
                        rickelmund @Mykle1
                        @Mykle1 Interesting! Thank you. Let me try that out.
                        • H
                          harney
                          My question is a little different. After trying so many weather modules and looking for one that works accurately he in West Aus, NOAA was the firrst to actually work with some accuracy. Most of the others the API’s are now defunct. I use my MagicMirror on a 7inch Raspberry screen manly as an information screen of the weather and some server stats. At the moment I am trying to get this moduel to fit on the screen as the screen resolution is fixed.
                          My question is which file holds the code for the section headings. I figure if I take them out and just have the date and icons, the module will fit perfectly on the small screen, then I can desing the other modules to fit in the space left.
                          Thanks in Advance
                          • 4 / 4
