    How to add modules. For absolute beginners.
    91 Posts 16 Posters 166.6k Views 24 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @TheSij
      @TheSij said in How to add modules. For absolute beginners.:
      The module is finally showing in the MM dashboard.
      Ahh, see? Well done. Don’t sweat it. We’ve all experienced these problems. I promise, it gets easier. The more you learn the easier it becomes. Have fun!
      • Mykle1M
        @sdetweil said in How to add modules. For absolute beginners.:
        i suspect you did not do the required install
        For the record, I did not have to install dependencies.
          sdetweil @Mykle1
          @Mykle1 because some other module already had. npm install would have resolved that, if he had provided the package. json
          Mykle1M 1 Reply Last reply
          • Mykle1M
            :thumbsup:
            • ebolisaE
              ebolisa
              What if no errors are generated and yet the widget is not shown on the screen? Where do we start troubleshooting?
              TIA
              Mykle1M S 2 Replies Last reply
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @ebolisa
                @ebolisa said in How to add modules. For absolute beginners.:
                It would help if you named the widget (I assume you mean module) and posted your config entry for that module. Please post in a code block.
                EDIT:
                And everything @sdetweil says. :-)
                  sdetweil @ebolisa
                  @ebolisa do you have a position defined? must be else MM doesn’t know where to put the content…
                  next, look in the window where npm start was done, or in the logs if pm2, using pm2 logs --lines=??? ??? is a number 15 default…
                  also look in the developers window
                  ctrl-shift-i, select the tab labeled console, and scroll up… u can also filter by module, add some of the unique part of the module name to the filter field
                  • F
                    fsne04
                    Hi Mykle1. Thank you for doing this. I am trying to build a MagicMirror for my daughter for Christmas and have had a hard time with a few things. Absolute noobie, but have learned a bunch in the past 2 weeks of this journey.
                    First question: I installed the Kevinatown MMM-Screencast module and after some trial and error, I did get the module to start, BUT as I am starting the casting from my phone, the Screencast window opens and then freezes stating “loading…” without ever actually starting the video/cast. I assume the config entry is correct, because the screencast opens, but maybe I am missing a step?
                    Your help would be greatly appreciated! ![1_1608396591977_2020-12-19-103618_1024x768_scrot.png](Uploading 100%) ![0_1608396591974_2020-12-19-103955_1024x768_scrot.png](Uploading 100%)
                    I guess the screenshots did not work. How do I send a screenshot?
                      sdetweil @fsne04
                      @fsne04 said in How to add modules. For absolute beginners.:
                      click the button above the editor that looks like the sun over the mountain, with top right corner folded over
                      • F
                        fsne04
                          sdetweil @fsne04
                          @fsne04 open the developers window, ctrl-shift-i on the keyboard, select the tab labeled ‘console’ and scroll up…
                          u can also filter messages by module, by placing a unique part of the module name (cast) in the filter field
                          F 1 Reply Last reply
                          • F
                            fsne04 @sdetweil
                            @sdetweil Hi Sam,
                            Thank you for the response, but I am not sure what you are asking me to do. Ctl + Shift+i on the Pi4 or on my Mac (where I am writing this)? Also, I don’t know what palancing is, or the last 4 words of your post. Sorry…
                            Actually, just figured out the last 4… in the filter field (duh)… but which filter field?
                            Oh and I tried Ctl Shift i on both Pi and Mac, neither one did something. Again sorry about the ignorance…
                              sdetweil @fsne04
                              @fsne04 pi of course, where MM is, all keys at the same time
                              and the ‘filter’ field is the field labeled ‘filter’ in the debug screen
                                you should open a different topic as this one is about installing modules
                                • F
                                  fsne04 @sdetweil
                                  This is my first time in a forum like this and I don’t actually know how to start a new topic…
                                  I tried ctl+shft+i on the Raspbian desktop, in the MM config file, in the File Manager and in Chromium, all without any response. I can’t get to the place you have in your screenshot.
                                    sdetweil @fsne04
                                    @fsne04 mm screen currently selected on the pi monitor, ctrl-shift-i (lower case I, not L)
                                      sdetweil @fsne04
                                      this is my first time in a forum like this and I don’t actually know how to start a new topic…
                                      click the button that says ‘new topic’
                                      • F
                                        fsne04 @sdetweil
                                        Yeah, got there. so the Elements window is open now
                                          sdetweil @fsne04
                                          @fsne04 click the tab labeled ‘console’…
                                          • F
                                            fsne04 @sdetweil
                                            Ok, in Console. There is an “Electron” Security Warning in yellow about using insecure protocols, could that be it?
                                            • 4 / 5
