Black Screen on Localhost...
19 Posts 6 Posters 12.2k Views 6 Watching
  • L Offline
    Leotrap
    Hi…i have installed node and the MM2 to test in a Pc before starting with Pi and entering to localhost:8080 the screen is black…no text…no nothing :(
    The config.js is already in 8080 too what could be happening? Thanks
    B 1 Reply Last reply Dec 1, 2016, 1:16 AM Reply Quote 0
      bhepler Module Developer @Leotrap
      @Leotrap Usually a black screen means that there is an error in the config.js file. First, I would start the mirror in dev mode via npm start dev. It should show you the browser console so you can see if there are any error messages.
      • L Offline
        Leotrap
        Thanks @bhepler this is what I got 0_1480555648940_upload-426cb398-ef76-48cd-ae45-6ecd5b1b7aec
        B 1 Reply Last reply Dec 1, 2016, 2:33 AM Reply Quote 0
          @Leotrap Hrm. That’s really weird. It’s like it wasn’t expecting the very first character of the index.html file. Let’s try without the dev tag. First, remove the debug log at C:\Users\usario\Downloads\MagicMirror-master\MagicMirror-Master\npm-debug.log if it exists. Run the mirror normally with npm start from within the MagicMirror-Master\MagicMirror-Master folder. If you still get a black screen, stop your npm process and then see if that log file has been recreated.
          If it has, copy it in here using the markdown features and we’ll take a look at it.
          • L Offline
            Leotrap
            Hi @bhepler I did what you told and exactly the same is happening but withouts the DEV after the index.html. I Attach capture and the debug created… Thanks man
            0_1480623461551_dev.jpg [0_1480623474461_npm-debug.log](Uploading 100%)
            • L Offline
              Leotrap
              • L Offline
                Leotrap
                1 verbose cli [ ‘C:\Program Files\nodejs\node.exe’,
                1 verbose cli ‘C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js’,
                1 verbose cli ‘start’ ]
                2 info using npm@3.10.8
                3 info using node@v6.9.1
                4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                5 info lifecycle magicmirror@2.0.0~prestart: magicmirror@2.0.0
                6 silly lifecycle magicmirror@2.0.0~prestart: no script for prestart, continuing
                7 info lifecycle magicmirror@2.0.0~start: magicmirror@2.0.0
                8 verbose lifecycle magicmirror@2.0.0~start: unsafe-perm in lifecycle true
                9 verbose lifecycle magicmirror@2.0.0~start: PATH: C:\Program Files\nodejs\node_modules\npm\bin\node-gyp-bin;C:\Users\usuario\Downloads\MagicMirror-master\MagicMirror-master\node_modules.bin;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\HP SimplePass;C:\Program Files (x86)\Intel\iCLS Client;C:\Program Files\Intel\iCLS Client;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files (x86)\Intel\OpenCL SDK\3.0\bin\x86;C:\Program Files (x86)\Intel\OpenCL SDK\3.0\bin\x64;C:\Program Files\Intel\Intel® Management Engine Components\DAL;C:\Program Files\Intel\Intel® Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel® Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel® Management Engine Components\IPT;C:\Program Files\Intel\WiFi\bin;C:\Program Files\Common Files\Intel\WirelessCommon;C:\Program Files (x86)\QuickTime\QTSystem;C:\Program Files\Common Files\Autodesk Shared;C:\Program Files (x86)\Autodesk\Backburner;C:\Program Files\OpenNI\Bin64;C:\Program Files\PrimeSense\NITE\bin64;C:\Program Files (x86)\Skype\Phone;C:\Program Files\nodejs;C:\Users\usuario\AppData\Local\Microsoft\WindowsApps;C:\Users\usuario\AppData\Roaming\npm
                10 verbose lifecycle magicmirror@2.0.0~start: CWD: C:\Users\usuario\Downloads\MagicMirror-master\MagicMirror-master
                11 silly lifecycle magicmirror@2.0.0~start: Args: [ ‘/d /s /c’, ‘node index.html’ ]
                12 silly lifecycle magicmirror@2.0.0~start: Returned: code: 1 signal: null
                13 info lifecycle magicmirror@2.0.0~start: Failed to exec start script
                14 verbose stack Error: magicmirror@2.0.0 start: node index.html
                14 verbose stack Exit status 1
                14 verbose stack at EventEmitter. (C:\Program Files\nodejs\node_modules\npm\lib\utils\lifecycle.js:255:16)
                14 verbose stack at emitTwo (events.js:106:13)
                14 verbose stack at EventEmitter.emit (events.js:191:7)
                14 verbose stack at ChildProcess. (C:\Program Files\nodejs\node_modules\npm\lib\utils\spawn.js:40:14)
                14 verbose stack at ChildProcess.emit (events.js:191:7)
                14 verbose stack at maybeClose (internal/child_process.js:877:16)
                14 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
                15 verbose pkgid magicmirror@2.0.0
                16 verbose cwd C:\Users\usuario\Downloads\MagicMirror-master\MagicMirror-master
                17 error Windows_NT 10.0.14393
                18 error argv “C:\Program Files\nodejs\node.exe” “C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js” “start”
                19 error node v6.9.1
                20 error npm v3.10.8
                21 error code ELIFECYCLE
                22 error magicmirror@2.0.0 start: node index.html
                22 error Exit status 1
                23 error Failed at the magicmirror@2.0.0 start script ‘node index.html’.
                23 error Make sure you have the latest version of node.js and npm installed.
                23 error If you do, this is most likely a problem with the magicmirror package,
                23 error not with npm itself.
                23 error Tell the author that this fails on your system:
                23 error node index.html
                23 error You can get information on how to open an issue for this project with:
                23 error npm bugs magicmirror
                23 error Or if that isn’t available, you can get their info via:
                23 error npm owner ls magicmirror
                23 error There is likely additional logging output above.
                24 verbose exit [ 1, true ]
                • Y Offline
                  yawns Moderator
                  What happens, if you run node serveronly instead?
                    jeremytripp
                    Might be a silly question, but did you run npm install on the mirror root folder to install dependencies? And you made sure node.js is installed on your machine before you got started?
                    • L Offline
                      Leotrap
                      Hi guys! From the Cmd I have this… (Attached Image.) The root is fine @jeremytripp and @yawns the problem persist from node trying the nose serveronly too :( In the last inage youl’ss that if i enter to localhost everything will be fine… the dark screen appears…that’s goo… but the probles is that modules are not showned…
                      B 1 Reply Last reply Dec 2, 2016, 2:29 AM Reply Quote 0
