Black Screen on Localhost...
Hi…i have installed node and the MM2 to test in a Pc before starting with Pi and entering to localhost:8080 the screen is black…no text…no nothing :(
The config.js is already in 8080 too what could be happening? Thanks -
@Leotrap Usually a black screen means that there is an error in the
config.jsfile. First, I would start the mirror in dev mode vianpm start dev. It should show you the browser console so you can see if there are any error messages. -
Thanks @bhepler this is what I got
@Leotrap Hrm. That’s really weird. It’s like it wasn’t expecting the very first character of the
index.htmlfile. Let’s try without the dev tag. First, remove the debug log atC:\Users\usario\Downloads\MagicMirror-master\MagicMirror-Master\npm-debug.logif it exists. Run the mirror normally withnpm startfrom within theMagicMirror-Master\MagicMirror-Masterfolder. If you still get a black screen, stop your npm process and then see if that log file has been recreated.If it has, copy it in here using the markdown features and we’ll take a look at it.
Hi @bhepler I did what you told and exactly the same is happening but withouts the DEV after the index.html. I Attach capture and the debug created… Thanks man
[0_1480623474461_npm-debug.log](Uploading 100%) -
This post is deleted! -
1 verbose cli [ ‘C:\Program Files\nodejs\node.exe’,
1 verbose cli ‘C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js’,
1 verbose cli ‘start’ ]
2 info using npm@3.10.8
3 info using node@v6.9.1
4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
5 info lifecycle magicmirror@2.0.0~prestart: magicmirror@2.0.0
6 silly lifecycle magicmirror@2.0.0~prestart: no script for prestart, continuing
7 info lifecycle magicmirror@2.0.0~start: magicmirror@2.0.0
8 verbose lifecycle magicmirror@2.0.0~start: unsafe-perm in lifecycle true
9 verbose lifecycle magicmirror@2.0.0~start: PATH: C:\Program Files\nodejs\node_modules\npm\bin\node-gyp-bin;C:\Users\usuario\Downloads\MagicMirror-master\MagicMirror-master\node_modules.bin;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\HP SimplePass;C:\Program Files (x86)\Intel\iCLS Client;C:\Program Files\Intel\iCLS Client;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files (x86)\Intel\OpenCL SDK\3.0\bin\x86;C:\Program Files (x86)\Intel\OpenCL SDK\3.0\bin\x64;C:\Program Files\Intel\Intel® Management Engine Components\DAL;C:\Program Files\Intel\Intel® Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel® Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel® Management Engine Components\IPT;C:\Program Files\Intel\WiFi\bin;C:\Program Files\Common Files\Intel\WirelessCommon;C:\Program Files (x86)\QuickTime\QTSystem;C:\Program Files\Common Files\Autodesk Shared;C:\Program Files (x86)\Autodesk\Backburner;C:\Program Files\OpenNI\Bin64;C:\Program Files\PrimeSense\NITE\bin64;C:\Program Files (x86)\Skype\Phone;C:\Program Files\nodejs;C:\Users\usuario\AppData\Local\Microsoft\WindowsApps;C:\Users\usuario\AppData\Roaming\npm
10 verbose lifecycle magicmirror@2.0.0~start: CWD: C:\Users\usuario\Downloads\MagicMirror-master\MagicMirror-master
11 silly lifecycle magicmirror@2.0.0~start: Args: [ ‘/d /s /c’, ‘node index.html’ ]
12 silly lifecycle magicmirror@2.0.0~start: Returned: code: 1 signal: null
13 info lifecycle magicmirror@2.0.0~start: Failed to exec start script
14 verbose stack Error: magicmirror@2.0.0 start:node index.html
14 verbose stack Exit status 1
14 verbose stack at EventEmitter. (C:\Program Files\nodejs\node_modules\npm\lib\utils\lifecycle.js:255:16)
14 verbose stack at emitTwo (events.js:106:13)
14 verbose stack at EventEmitter.emit (events.js:191:7)
14 verbose stack at ChildProcess. (C:\Program Files\nodejs\node_modules\npm\lib\utils\spawn.js:40:14)
14 verbose stack at ChildProcess.emit (events.js:191:7)
14 verbose stack at maybeClose (internal/child_process.js:877:16)
14 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
15 verbose pkgid magicmirror@2.0.0
16 verbose cwd C:\Users\usuario\Downloads\MagicMirror-master\MagicMirror-master
17 error Windows_NT 10.0.14393
18 error argv “C:\Program Files\nodejs\node.exe” “C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js” “start”
19 error node v6.9.1
20 error npm v3.10.8
21 error code ELIFECYCLE
22 error magicmirror@2.0.0 start:node index.html
22 error Exit status 1
23 error Failed at the magicmirror@2.0.0 start script ‘node index.html’.
23 error Make sure you have the latest version of node.js and npm installed.
23 error If you do, this is most likely a problem with the magicmirror package,
23 error not with npm itself.
23 error Tell the author that this fails on your system:
23 error node index.html
23 error You can get information on how to open an issue for this project with:
23 error npm bugs magicmirror
23 error Or if that isn’t available, you can get their info via:
23 error npm owner ls magicmirror
23 error There is likely additional logging output above.
24 verbose exit [ 1, true ] -
What happens, if you run
node serveronlyinstead? -
Might be a silly question, but did you run
npm installon the mirror root folder to install dependencies? And you made sure node.js is installed on your machine before you got started? -
Hi guys! From the Cmd I have this… (Attached Image.) The root is fine @jeremytripp and @yawns the problem persist from node trying the nose serveronly too :( In the last inage youl’ss that if i enter to localhost everything will be fine… the dark screen appears…that’s goo… but the probles is that modules are not showned…
@Leotrap This sounds like progress. Please copy your
config.jsfile and let us see it. Please remember to remove any API keys and preface it with triple back-ticks.If you’re getting the interface but no modules, that sounds like a configuration error. -
So positive @bhepler it really encourage to go on with this instead this is not my native language… here the config.js… Thanks man! [0_1480680561947_config.js](Uploading 100%)
Here it a copy paste because the Forum says that I have no such permission to upload this…
/* Magic Mirror Config Sample
*- By Michael Teeuw http://michaelteeuw.nl
- MIT Licensed.
var config = {
port: 8080,language: 'en', timeFormat: 24, units: 'metric', modules: [ { module: 'alert', }, { module: 'clock', position: 'top_left' }, { module: 'calendar', header: 'US Holidays', position: 'top_left', config: { calendars: [ { symbol: 'calendar-check-o ', url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics' } ] } }, { module: 'compliments', position: 'lower_third' }, { module: 'currentweather', position: 'top_right', config: { location: 'New York', locationID: '', //ID from http://www.openweathermap.org appid: 'YOUR_OPENWEATHER_API_KEY' } }, { module: 'weatherforecast', position: 'top_right', header: 'Weather Forecast', config: { location: 'New York', locationID: '5128581', //ID from http://www.openweathermap.org appid: 'YOUR_OPENWEATHER_API_KEY' } }, { module: 'newsfeed', position: 'bottom_bar', config: { feeds: [ { title: "New York Times", url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" } ], showSourceTitle: true, showPublishDate: true } }, ]};
if (typeof module !== ‘undefined’) {module.exports = config;} -
Please Help… in this… I’ll start to cry… lol!
I kept getting a blank screen too. Basically I commented out all of the modules and uncommented them back one by one. In the end, the calendar and newsfeed modules are not working and that’s what is giving me the black screen. I had to remove the following from the config file:
module: ‘calendar’,
header: ‘US Holidays’,
position: ‘top_left’,
url: ‘webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics’
},and
module: ‘newsfeed’,
position: ‘bottom_bar’,
feeds: [
title: “New York Times”,
url: “http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml”
Whenever i get an error when im trying sth i open the mirror-page in Firefox or chrome and open the console with a right click and the last item (examine or sth like this). Maybe this will hell you to know where sth could be wrong.
@chrisyy and @memjr thanks for the responses… I have tried this and seems to not work… very strange I think that I should buy the raspberry to do this…seems to have problems in PC at least I never could see anything else that a black screen… what a pity…really
Can u enable port forwarding (8080) to ur Pi/PC for the MagicMirror and PM me an IP?
Maybe I can take a look with the console. When there’s an error, maybe we can find out more. -
Thanks @chrisyy i’ll try… .that could work. Thanks!.
