Black Screen on Localhost...
19 Posts 6 Posters 13.1k Views 6 Watching
    bhepler Module Developer @Leotrap
    @Leotrap Hrm. That’s really weird. It’s like it wasn’t expecting the very first character of the index.html file. Let’s try without the dev tag. First, remove the debug log at C:\Users\usario\Downloads\MagicMirror-master\MagicMirror-Master\npm-debug.log if it exists. Run the mirror normally with npm start from within the MagicMirror-Master\MagicMirror-Master folder. If you still get a black screen, stop your npm process and then see if that log file has been recreated.
    If it has, copy it in here using the markdown features and we’ll take a look at it.
    • L Offline
      Leotrap
      Hi @bhepler I did what you told and exactly the same is happening but withouts the DEV after the index.html. I Attach capture and the debug created… Thanks man
      0_1480623461551_dev.jpg [0_1480623474461_npm-debug.log](Uploading 100%)
      • L Offline
        Leotrap
        • L Offline
          Leotrap
          1 verbose cli [ ‘C:\Program Files\nodejs\node.exe’,
          1 verbose cli ‘C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js’,
          1 verbose cli ‘start’ ]
          2 info using npm@3.10.8
          3 info using node@v6.9.1
          4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
          5 info lifecycle magicmirror@2.0.0~prestart: magicmirror@2.0.0
          6 silly lifecycle magicmirror@2.0.0~prestart: no script for prestart, continuing
          7 info lifecycle magicmirror@2.0.0~start: magicmirror@2.0.0
          8 verbose lifecycle magicmirror@2.0.0~start: unsafe-perm in lifecycle true
          9 verbose lifecycle magicmirror@2.0.0~start: PATH: C:\Program Files\nodejs\node_modules\npm\bin\node-gyp-bin;C:\Users\usuario\Downloads\MagicMirror-master\MagicMirror-master\node_modules.bin;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\HP SimplePass;C:\Program Files (x86)\Intel\iCLS Client;C:\Program Files\Intel\iCLS Client;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files (x86)\Intel\OpenCL SDK\3.0\bin\x86;C:\Program Files (x86)\Intel\OpenCL SDK\3.0\bin\x64;C:\Program Files\Intel\Intel® Management Engine Components\DAL;C:\Program Files\Intel\Intel® Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel® Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel® Management Engine Components\IPT;C:\Program Files\Intel\WiFi\bin;C:\Program Files\Common Files\Intel\WirelessCommon;C:\Program Files (x86)\QuickTime\QTSystem;C:\Program Files\Common Files\Autodesk Shared;C:\Program Files (x86)\Autodesk\Backburner;C:\Program Files\OpenNI\Bin64;C:\Program Files\PrimeSense\NITE\bin64;C:\Program Files (x86)\Skype\Phone;C:\Program Files\nodejs;C:\Users\usuario\AppData\Local\Microsoft\WindowsApps;C:\Users\usuario\AppData\Roaming\npm
          10 verbose lifecycle magicmirror@2.0.0~start: CWD: C:\Users\usuario\Downloads\MagicMirror-master\MagicMirror-master
          11 silly lifecycle magicmirror@2.0.0~start: Args: [ ‘/d /s /c’, ‘node index.html’ ]
          12 silly lifecycle magicmirror@2.0.0~start: Returned: code: 1 signal: null
          13 info lifecycle magicmirror@2.0.0~start: Failed to exec start script
          14 verbose stack Error: magicmirror@2.0.0 start: node index.html
          14 verbose stack Exit status 1
          14 verbose stack at EventEmitter. (C:\Program Files\nodejs\node_modules\npm\lib\utils\lifecycle.js:255:16)
          14 verbose stack at emitTwo (events.js:106:13)
          14 verbose stack at EventEmitter.emit (events.js:191:7)
          14 verbose stack at ChildProcess. (C:\Program Files\nodejs\node_modules\npm\lib\utils\spawn.js:40:14)
          14 verbose stack at ChildProcess.emit (events.js:191:7)
          14 verbose stack at maybeClose (internal/child_process.js:877:16)
          14 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
          15 verbose pkgid magicmirror@2.0.0
          16 verbose cwd C:\Users\usuario\Downloads\MagicMirror-master\MagicMirror-master
          17 error Windows_NT 10.0.14393
          18 error argv “C:\Program Files\nodejs\node.exe” “C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js” “start”
          19 error node v6.9.1
          20 error npm v3.10.8
          21 error code ELIFECYCLE
          22 error magicmirror@2.0.0 start: node index.html
          22 error Exit status 1
          23 error Failed at the magicmirror@2.0.0 start script ‘node index.html’.
          23 error Make sure you have the latest version of node.js and npm installed.
          23 error If you do, this is most likely a problem with the magicmirror package,
          23 error not with npm itself.
          23 error Tell the author that this fails on your system:
          23 error node index.html
          23 error You can get information on how to open an issue for this project with:
          23 error npm bugs magicmirror
          23 error Or if that isn’t available, you can get their info via:
          23 error npm owner ls magicmirror
          23 error There is likely additional logging output above.
          24 verbose exit [ 1, true ]
          • Y Offline
            yawns Moderator
            What happens, if you run node serveronly instead?
              jeremytripp
              Might be a silly question, but did you run npm install on the mirror root folder to install dependencies? And you made sure node.js is installed on your machine before you got started?
              • L Offline
                Leotrap
                Hi guys! From the Cmd I have this… (Attached Image.) The root is fine @jeremytripp and @yawns the problem persist from node trying the nose serveronly too :( In the last inage youl’ss that if i enter to localhost everything will be fine… the dark screen appears…that’s goo… but the probles is that modules are not showned…
                B 1 Reply Last reply Dec 2, 2016, 2:29 AM Reply Quote 0
                  @Leotrap This sounds like progress. Please copy your config.js file and let us see it. Please remember to remove any API keys and preface it with triple back-ticks.If you’re getting the interface but no modules, that sounds like a configuration error.
                  • L Offline
                    Leotrap
                    So positive @bhepler it really encourage to go on with this instead this is not my native language… here the config.js… Thanks man! [0_1480680561947_config.js](Uploading 100%)
                    • L Offline
                      Leotrap
                      Here it a copy paste because the Forum says that I have no such permission to upload this…
                      /* Magic Mirror Config Sample
                      • MIT Licensed.
                      var config = {
                      port: 8080,
                      language: 'en',
                      timeFormat: 24,
                      units: 'metric',
                      		module: 'alert',
                      		module: 'clock',
                      		position: 'top_left'
                      		module: 'calendar',
                      		header: 'US Holidays',
                      		position: 'top_left',
                      					symbol: 'calendar-check-o ',
                      		module: 'compliments',
                      		position: 'lower_third'
                      		module: 'currentweather',
                      		position: 'top_right',
                      			locationID: '',  //ID from http://www.openweathermap.org
                      			appid: 'YOUR_OPENWEATHER_API_KEY'
                      		module: 'weatherforecast',
                      		header: 'Weather Forecast',
                      			locationID: '5128581',  //ID from http://www.openweathermap.org
                      		module: 'newsfeed',
                      		position: 'bottom_bar',
                      			feeds: [
                      					title: "New York Times",
                      			showSourceTitle: true,
                      			showPublishDate: true
                      if (typeof module !== ‘undefined’) {module.exports = config;}
