    [ORDER CLOSED] Two way mirror order in Germany
    Scheduled Pinned Locked Moved Solved Hardware
    558 Posts 80 Posters 2.8m Views 60 Watching
    • CatoC Offline
      Cato Module Developer @Goldjunge_Chriz
      @Goldjunge_Chriz Sorry, my bad! I just partly recalled an earlier discussion above about this mirror doesn’t have the foil inside like most one way mirrors of glas do. I wrongly assumed it was acrylic which is very normal for less scratch resistant mirrors with the “foil” on the outside.
      • G Offline
        Goldjunge_Chriz
        No problem ;) it is real glass. As I said in a post above it is a really special combination between spy mirror and sun protection glass, that makes this glass so fantastic.
        CatoC 1 Reply Last reply Reply Quote 0
        • CatoC Offline
          @Goldjunge_Chriz I owe you a second apology, because I calculated your price for my size of my existing mirror wrongly the first time (price pr m² divided by actual m², when I should have multiplied). Rookie mistake!
          I paid 1300 for my mirror. You’re price would have been kr 1320. Soooo close! ☺
          • yawnsY Offline
            yawns Moderator @Goldjunge_Chriz
            @Goldjunge_Chriz said in Two way mirror order in Germany:
            @yawns @gustav1976 @lolobyte @Jeff @cpramhofer
            Please tell me what you think about that. Do you want to order the next days or do you want to wait?
            Still interested, but not in a hurry
            • lolobyteL Offline
              lolobyte
              @yawns @gustav1976 @Jeff @cpramhofer @yawns
              I’m a bit confused what to do next.
              The mirror price is actually 100% more expensive than my already bought mirror with the same dimensions.
              I’m waiting too like yawns!
              • CFennerC Offline
                CFenner
                Hi there, my mirror is in the bathroom and I use plexiglas with a foil from amazon right now. Unfortunately the WAF is not very great because the mirror is too dark. How is the reflexion compared to the mirror foil?
                best regards
                Christopher
                G lolobyteL 2 Replies Last reply Reply Quote 0
                • G Offline
                  Goldjunge_Chriz @lolobyte
                  You mean the glass from your first Post here right? The glass from me isn’t 100 % more expensive than this one ? It is only about 35 % more. Or did I misunderstand something?
                  As I said the problem is, that 8mm glass is realy heavy. Almost three times heavier than my glass. The next thing is that thicker glass is a way darker and the transmission is not so good. That´s normal, because the thicker the glass, the lesser is the transmisson. That is also a normal behavior of normal Float glass. But it is your decision whether the price difference is worth for you :)
                  @lolobyte said in Two way mirror order in Germany:
                  Servus, danke für den hinweis! ich bin auch schon lange auf der Suchs nach einem vernünftigen Spiegel.
                  Bis heute nur im Ausland etwaige exemplare gefunden.
                  Hätte schon interesse an ein zwei oder drei Stück.
                  Hab einen bei ebay gekauft:
                  http://www.ebay.de/itm/SPIONSPIEGEL-VENEZIANISCHER-SPIEGEL-POLIZEISPIEGEL-HALBDURCHLASSIGER-SPIEGEL-/371488577874?var=&hash=item567e71d952:m:mv0rzJCHI7w1Ttkpyu7qnKw
                  8mm glas, 232,50€ /m²,freier Versand, lieferung durch eigenen Fahrer des verkäufers.
                  English.
                  Hello, thank u very much for this info. I’m searchin for a very long time such a good quality of an two way mirror. The only one that i found was in the Netherlands, USA and GB.
                  I’ intresting in one. two ore more.
                  i have buy one from ebay
                  8mm glass, 232,50€ /m², free shipping by sellers own driver.
                  lolobyteL 1 Reply Last reply Reply Quote 0
                  • G Offline
                    Goldjunge_Chriz @CFenner
                    @CFenner said in Two way mirror order in Germany:
                    best regards
                    Christopher
                    Please see my pictures in the first Post. I think pictures can say more than words. The quality is not nearly comparable with a simple foil.
                    • lolobyteL Offline
                      lolobyte @Goldjunge_Chriz
                      @Goldjunge_Chriz
                      Sorry, shure. Was a mistake from me.
                      • lolobyteL Offline
                        lolobyte @CFenner
                        @CFenner
                        I also use at first a Foil. The result was very poor.
                        I dont’ want to recommend this kind of mirror.
                        Acrylglas
                        https://www.amazon.de/gp/product/B00SJADTWY/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
                        and Foil
                        https://www.amazon.de/gp/product/B00IC3EJ2M/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
                        • 10
                        • 55
                        • 56
                        • 8 / 56
