    [ORDER CLOSED] Two way mirror order in Germany
    Scheduled Pinned Locked Moved Solved Hardware
    558 Posts 80 Posters 2.9m Views 60 Watching
    • G Offline
      Goldjunge_Chriz
      It is glass. Why do you assume that it is not?
        Cato Module Developer @Goldjunge_Chriz
        @Goldjunge_Chriz Sorry, my bad! I just partly recalled an earlier discussion above about this mirror doesn’t have the foil inside like most one way mirrors of glas do. I wrongly assumed it was acrylic which is very normal for less scratch resistant mirrors with the “foil” on the outside.
        • G Offline
          Goldjunge_Chriz
          No problem ;) it is real glass. As I said in a post above it is a really special combination between spy mirror and sun protection glass, that makes this glass so fantastic.
            @Goldjunge_Chriz I owe you a second apology, because I calculated your price for my size of my existing mirror wrongly the first time (price pr m² divided by actual m², when I should have multiplied). Rookie mistake!
            I paid 1300 for my mirror. You’re price would have been kr 1320. Soooo close! ☺
            • Y Offline
              yawns Moderator @Goldjunge_Chriz
              @Goldjunge_Chriz said in Two way mirror order in Germany:
              @yawns @gustav1976 @lolobyte @Jeff @cpramhofer
              Please tell me what you think about that. Do you want to order the next days or do you want to wait?
              Still interested, but not in a hurry
              • L Offline
                lolobyte
                @yawns @gustav1976 @Jeff @cpramhofer @yawns
                I’m a bit confused what to do next.
                The mirror price is actually 100% more expensive than my already bought mirror with the same dimensions.
                I’m waiting too like yawns!
                  CFenner
                  Hi there, my mirror is in the bathroom and I use plexiglas with a foil from amazon right now. Unfortunately the WAF is not very great because the mirror is too dark. How is the reflexion compared to the mirror foil?
                  best regards
                  Christopher
                  G L 2 Replies Last reply Reply Quote 0
                  • G Offline
                    Goldjunge_Chriz @lolobyte
                    You mean the glass from your first Post here right? The glass from me isn’t 100 % more expensive than this one ? It is only about 35 % more. Or did I misunderstand something?
                    As I said the problem is, that 8mm glass is realy heavy. Almost three times heavier than my glass. The next thing is that thicker glass is a way darker and the transmission is not so good. That´s normal, because the thicker the glass, the lesser is the transmisson. That is also a normal behavior of normal Float glass. But it is your decision whether the price difference is worth for you :)
                    @lolobyte said in Two way mirror order in Germany:
                    Servus, danke für den hinweis! ich bin auch schon lange auf der Suchs nach einem vernünftigen Spiegel.
                    Bis heute nur im Ausland etwaige exemplare gefunden.
                    Hätte schon interesse an ein zwei oder drei Stück.
                    Hab einen bei ebay gekauft:
                    http://www.ebay.de/itm/SPIONSPIEGEL-VENEZIANISCHER-SPIEGEL-POLIZEISPIEGEL-HALBDURCHLASSIGER-SPIEGEL-/371488577874?var=&hash=item567e71d952:m:mv0rzJCHI7w1Ttkpyu7qnKw
                    8mm glas, 232,50€ /m²,freier Versand, lieferung durch eigenen Fahrer des verkäufers.
                    English.
                    Hello, thank u very much for this info. I’m searchin for a very long time such a good quality of an two way mirror. The only one that i found was in the Netherlands, USA and GB.
                    I’ intresting in one. two ore more.
                    i have buy one from ebay
                    8mm glass, 232,50€ /m², free shipping by sellers own driver.
                    • G Offline
                      Goldjunge_Chriz @CFenner
                      @CFenner said in Two way mirror order in Germany:
                      best regards
                      Christopher
                      Please see my pictures in the first Post. I think pictures can say more than words. The quality is not nearly comparable with a simple foil.
                      • L Offline
                        lolobyte @Goldjunge_Chriz
                        @Goldjunge_Chriz
                        Sorry, shure. Was a mistake from me.
                        • L Offline
                          lolobyte @CFenner
                          @CFenner
                          I also use at first a Foil. The result was very poor.
                          I dont’ want to recommend this kind of mirror.
                          Acrylglas
                          https://www.amazon.de/gp/product/B00SJADTWY/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
                          and Foil
                          https://www.amazon.de/gp/product/B00IC3EJ2M/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
                            CFenner
                            Then I guess I’m in :)
                            # username sizes (m) area (m²) location additional comments pickup/delivery
                            01 yawns ~ 0.8 * 0.8 ~ 0.64 Germany, Cologne polished edges delivery
                            02 gustav1976 0.6 * 1.8 1.08 Germany, Koblenz polished edges delivery
                            03 gustav1976 1.0 * 1.2 1.20 Germany, Koblenz polished edges delivery
                            04 gustav1976 1.4 * 0.8 1.12 Germany, Koblenz polished edges delivery
                            05 lolobyte 0.8*0.6 0,48 Germany, Heilbronn polished edges pickup
                            06 Jeff 1,0 * 0,6 0,6 Germany, Karlsruhe polished edges pickup
                            07 Ashidian 0,69 * 0,435 0,3 (pay 0,4) Germany, Rostock polished edges delivery
                            08 cpramhofer 0,476 * 0,82 0,39 (possible??) Austria, Vienna polished edges delivery (cost??)
                            09 mcg 0,5 * 1,0 0,5 Germany, Ludwigshafen polished edges delivery
                            10 cfenner 0,667*0,667 0,45 Germany, Mannheim polished edges delivery, (maybe package with mcg)
                            11
                            Total 6,87
                              Patrick
                              I also would like to order a mirror glas. As i’m living also in schweinfurt, i would pick it up by my own. When I have my needed size i will make a additional comment.
                                sero
                                I’m in too. I have to measure once again, but it’ll be a bit more than 0.2m² (~0.4m * 0.5m). So I’ll pay 0.4m².
                                  Jeff
                                  Sorry for my late response.
                                  I was out of country for business and couldn’t really use the board with my cell phone.
                                  I’m in, too.
                                  BUT I need it before x-mas, otherwise I have to use a different mirror and have to think about my order…
                                  Thanks for the effort!
                                  • G Offline
                                    Goldjunge_Chriz
                                    @CFenner @mcg
                                    Maybe you can join up with @Jeff or @lolobyte. Both live in your area and pick up the glass. Or you all find a common solution together. :)
                                    @Patrick
                                    Oh great. Another MagicMirrorBuilder here in this area. Nice to hear from you.
                                    @sero
                                    Please join the List when you know your size.
                                    @Jeff
                                    Before xmas It will probably not work, I’m sorry. As I said in my first post the production and delivery time from the glass producer to me is about three weeks. Unfortunately we have no more three weeks until christmas.
                                    • L Offline
                                      @Goldjunge_Chriz @CFenner @mcg @Jeff
                                      No problem to take some mirrors to Heilbronn for other guys here.
                                      I’m owner of a big AUDI.
                                      • H Offline
                                        Head-Tec @Goldjunge_Chriz
                                        @Goldjunge_Chriz thanks for your efforts!
                                        As I see it we gathered around 7 qm in about 2 weeks. Maybe at the end of the year we will have enough to get the next cheaper price level as most of us can wait(?).
                                        My problem actually is that building a mirror with a 24" doesn’t give me enough ‘required’ area for 0,4qm…
                                        What size of a monitor would you recommend?
                                        • G Offline
                                          Goldjunge_Chriz
                                          @lolobyte You are sympathetic, I Love Audi. I think it is the best car manufacturer in the world. I also drive an Audi, but without any trunk (the Motor need some Space there) and with only 2 seats 😃
                                          Thanks for your effort. It would be very nice if you can pick up some mirrors for other guys here.
                                          @Head-Tec
                                          It depends on the others. Everyone must agree. It does not matter to me, and I am heading for you.
                                          The size of the monitor depends on the personal preferences. There are people who also use a 60 inch TV 😃
                                            mcg
                                            Alright, lets do it right.
                                            To everyone who’s still interested: Please enter your latest order date:
                                            (after the order it takes at least another 3 weeks to @Goldjunge_Chriz + shipping to everyone of us.)
                                            # username sizes (m) area (m²) location additional comments pickup/delivery latest date of order
                                            09 mcg 0,5 * 1,0 0,5 Germany, Ludwigshafen polished edges delivery, insured mid of January
                                            11
                                            Total 6,87
                                            @yawns @gustav1976 @lolobyte @Jeff @Ashidian @cpramhofer @CFenner @Goldjunge_Chriz
                                            • 27
                                            • 28
                                            • 4 / 28
