    [ORDER CLOSED] Two way mirror order in Germany
    Scheduled Pinned Locked Moved Solved Hardware
    558 Posts 80 Posters 3.0m Views 60 Watching
    • mcgM
      mcg @yawns
      @Goldjunge_Chriz I’m in as well! Really appreciate your efforts! The opportunity sounds great!
      Just measured what I’m going to need. (Just did a proof of concept with the RasPi 1 so far ;-) )
      I didn’t read all of the post but I guess I’m am right with 321€/qm + shipping at the moment, no?
      @Goldjunge_Chriz said in Two way mirror order in Germany:
      @yawns @gustav1976 @lolobyte @Jeff @cpramhofer
      Please tell me what you think about that. Do you want to order the next days or do you want to wait?
      I’m not in a hurry, I could wait longer to see if there are some other folks around who are interested like @sakuwa.
      # username sizes (m) area (m²) location additional comments pickup/delivery
      01 yawns ~ 0.8 * 0.8 ~ 0.64 Germany, Cologne polished edges delivery
      02 gustav1976 0.6 * 1.8 1.08 Germany, Koblenz polished edges delivery
      03 gustav1976 1.0 * 1.2 1.20 Germany, Koblenz polished edges delivery
      04 gustav1976 1.4 * 0.8 1.12 Germany, Koblenz polished edges delivery
      05 lolobyte 0.8*0.6 0,48 Germany, Heilbronn polished edges pickup
      06 Jeff 1,0 * 0,6 0,6 Germany, Karlsruhe polished edges pickup
      07 Ashidian 0,69 * 0,435 0,3 (pay 0,4) Germany, Rostock polished edges delivery
      08 cpramhofer 0,476 * 0,82 0,39 (possible??) Austria, Vienna polished edges delivery (cost??)
      09 mcg 0,5 * 1,0 0,5 Germany, Ludwigshafen polished edges delivery
      10
      11
      Total 6,42
      Cheers!
      • G
        Goldjunge_Chriz
        @mcg you are almost right ;) With your order the new acutal price is 319,36 € / qm. The more users order the less the price. Over 15 qm you can get the cheapest price of 296 € / qm.
        CatoC 1 Reply Last reply
        • CatoC
          Cato Module Developer @Goldjunge_Chriz
          @Goldjunge_Chriz What is “qm”?
          • G
            Goldjunge_Chriz
            @Cato I’m sorry. It means square meter.
            • CatoC
              Isn’t €319 for 1 m² expensive when it’s not glass?
              • G
                Goldjunge_Chriz
                It is glass. Why do you assume that it is not?
                • CatoC
                  @Goldjunge_Chriz Sorry, my bad! I just partly recalled an earlier discussion above about this mirror doesn’t have the foil inside like most one way mirrors of glas do. I wrongly assumed it was acrylic which is very normal for less scratch resistant mirrors with the “foil” on the outside.
                  • G
                    Goldjunge_Chriz
                    No problem ;) it is real glass. As I said in a post above it is a really special combination between spy mirror and sun protection glass, that makes this glass so fantastic.
                    • CatoC
                      @Goldjunge_Chriz I owe you a second apology, because I calculated your price for my size of my existing mirror wrongly the first time (price pr m² divided by actual m², when I should have multiplied). Rookie mistake!
                      I paid 1300 for my mirror. You’re price would have been kr 1320. Soooo close! ☺
                      • yawnsY
                        yawns Moderator @Goldjunge_Chriz
                        Still interested, but not in a hurry
                        • lolobyteL
                          lolobyte
                          @yawns @gustav1976 @Jeff @cpramhofer @yawns
                          I’m a bit confused what to do next.
                          The mirror price is actually 100% more expensive than my already bought mirror with the same dimensions.
                          I’m waiting too like yawns!
                          • CFennerC
                            CFenner
                            Hi there, my mirror is in the bathroom and I use plexiglas with a foil from amazon right now. Unfortunately the WAF is not very great because the mirror is too dark. How is the reflexion compared to the mirror foil?
                            best regards
                            Christopher
                            G lolobyteL 2 Replies Last reply
                            • G
                              Goldjunge_Chriz @lolobyte
                              You mean the glass from your first Post here right? The glass from me isn’t 100 % more expensive than this one ? It is only about 35 % more. Or did I misunderstand something?
                              As I said the problem is, that 8mm glass is realy heavy. Almost three times heavier than my glass. The next thing is that thicker glass is a way darker and the transmission is not so good. That´s normal, because the thicker the glass, the lesser is the transmisson. That is also a normal behavior of normal Float glass. But it is your decision whether the price difference is worth for you :)
                              @lolobyte said in Two way mirror order in Germany:
                              Servus, danke für den hinweis! ich bin auch schon lange auf der Suchs nach einem vernünftigen Spiegel.
                              Bis heute nur im Ausland etwaige exemplare gefunden.
                              Hätte schon interesse an ein zwei oder drei Stück.
                              Hab einen bei ebay gekauft:
                              http://www.ebay.de/itm/SPIONSPIEGEL-VENEZIANISCHER-SPIEGEL-POLIZEISPIEGEL-HALBDURCHLASSIGER-SPIEGEL-/371488577874?var=&hash=item567e71d952:m:mv0rzJCHI7w1Ttkpyu7qnKw
                              8mm glas, 232,50€ /m²,freier Versand, lieferung durch eigenen Fahrer des verkäufers.
                              English.
                              Hello, thank u very much for this info. I’m searchin for a very long time such a good quality of an two way mirror. The only one that i found was in the Netherlands, USA and GB.
                              I’ intresting in one. two ore more.
                              i have buy one from ebay
                              8mm glass, 232,50€ /m², free shipping by sellers own driver.
                              lolobyteL 1 Reply Last reply
                              • G
                                Goldjunge_Chriz @CFenner
                                @CFenner said in Two way mirror order in Germany:
                                best regards
                                Christopher
                                Please see my pictures in the first Post. I think pictures can say more than words. The quality is not nearly comparable with a simple foil.
                                • lolobyteL
                                  lolobyte @Goldjunge_Chriz
                                  @Goldjunge_Chriz
                                  Sorry, shure. Was a mistake from me.
                                  • lolobyteL
                                    lolobyte @CFenner
                                    @CFenner
                                    I also use at first a Foil. The result was very poor.
                                    I dont’ want to recommend this kind of mirror.
                                    Acrylglas
                                    https://www.amazon.de/gp/product/B00SJADTWY/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
                                    and Foil
                                    https://www.amazon.de/gp/product/B00IC3EJ2M/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
                                    • CFennerC
                                      CFenner
                                      Then I guess I’m in :)
                                      10 cfenner 0,667*0,667 0,45 Germany, Mannheim polished edges delivery, (maybe package with mcg)
                                      11
                                      Total 6,87
                                        Patrick
                                        I also would like to order a mirror glas. As i’m living also in schweinfurt, i would pick it up by my own. When I have my needed size i will make a additional comment.
                                          sero
                                          I’m in too. I have to measure once again, but it’ll be a bit more than 0.2m² (~0.4m * 0.5m). So I’ll pay 0.4m².
                                            Jeff
                                            Sorry for my late response.
                                            I was out of country for business and couldn’t really use the board with my cell phone.
                                            I’m in, too.
                                            BUT I need it before x-mas, otherwise I have to use a different mirror and have to think about my order…
                                            Thanks for the effort!
                                            • 27
                                            • 28
                                            • 4 / 28
