    [ORDER CLOSED] Two way mirror order in Germany
    Scheduled Pinned Locked Moved Solved Hardware
    558 Posts 80 Posters 2.9m Views 60 Watching
      Cato Module Developer @Goldjunge_Chriz
      @Goldjunge_Chriz What is “qm”?
      • G Offline
        Goldjunge_Chriz
        @Cato I’m sorry. It means square meter.
          Isn’t €319 for 1 m² expensive when it’s not glass?
          • G Offline
            Goldjunge_Chriz
            It is glass. Why do you assume that it is not?
              @Goldjunge_Chriz Sorry, my bad! I just partly recalled an earlier discussion above about this mirror doesn’t have the foil inside like most one way mirrors of glas do. I wrongly assumed it was acrylic which is very normal for less scratch resistant mirrors with the “foil” on the outside.
              • G Offline
                Goldjunge_Chriz
                No problem ;) it is real glass. As I said in a post above it is a really special combination between spy mirror and sun protection glass, that makes this glass so fantastic.
                  @Goldjunge_Chriz I owe you a second apology, because I calculated your price for my size of my existing mirror wrongly the first time (price pr m² divided by actual m², when I should have multiplied). Rookie mistake!
                  I paid 1300 for my mirror. You’re price would have been kr 1320. Soooo close! ☺
                  • Y Offline
                    yawns Moderator @Goldjunge_Chriz
                    @Goldjunge_Chriz said in Two way mirror order in Germany:
                    @yawns @gustav1976 @lolobyte @Jeff @cpramhofer
                    Please tell me what you think about that. Do you want to order the next days or do you want to wait?
                    Still interested, but not in a hurry
                    • L Offline
                      lolobyte
                      @yawns @gustav1976 @Jeff @cpramhofer @yawns
                      I’m a bit confused what to do next.
                      The mirror price is actually 100% more expensive than my already bought mirror with the same dimensions.
                      I’m waiting too like yawns!
                        CFenner
                        Hi there, my mirror is in the bathroom and I use plexiglas with a foil from amazon right now. Unfortunately the WAF is not very great because the mirror is too dark. How is the reflexion compared to the mirror foil?
                        best regards
                        Christopher
                        G L 2 Replies Last reply Reply Quote 0
                        • G Offline
                          Goldjunge_Chriz @lolobyte
                          You mean the glass from your first Post here right? The glass from me isn’t 100 % more expensive than this one ? It is only about 35 % more. Or did I misunderstand something?
                          As I said the problem is, that 8mm glass is realy heavy. Almost three times heavier than my glass. The next thing is that thicker glass is a way darker and the transmission is not so good. That´s normal, because the thicker the glass, the lesser is the transmisson. That is also a normal behavior of normal Float glass. But it is your decision whether the price difference is worth for you :)
                          @lolobyte said in Two way mirror order in Germany:
                          Servus, danke für den hinweis! ich bin auch schon lange auf der Suchs nach einem vernünftigen Spiegel.
                          Bis heute nur im Ausland etwaige exemplare gefunden.
                          Hätte schon interesse an ein zwei oder drei Stück.
                          Hab einen bei ebay gekauft:
                          http://www.ebay.de/itm/SPIONSPIEGEL-VENEZIANISCHER-SPIEGEL-POLIZEISPIEGEL-HALBDURCHLASSIGER-SPIEGEL-/371488577874?var=&hash=item567e71d952:m:mv0rzJCHI7w1Ttkpyu7qnKw
                          8mm glas, 232,50€ /m²,freier Versand, lieferung durch eigenen Fahrer des verkäufers.
                          English.
                          Hello, thank u very much for this info. I’m searchin for a very long time such a good quality of an two way mirror. The only one that i found was in the Netherlands, USA and GB.
                          I’ intresting in one. two ore more.
                          i have buy one from ebay
                          8mm glass, 232,50€ /m², free shipping by sellers own driver.
                          • G Offline
                            Goldjunge_Chriz @CFenner
                            @CFenner said in Two way mirror order in Germany:
                            best regards
                            Christopher
                            Please see my pictures in the first Post. I think pictures can say more than words. The quality is not nearly comparable with a simple foil.
                            • L Offline
                              lolobyte @Goldjunge_Chriz
                              @Goldjunge_Chriz
                              Sorry, shure. Was a mistake from me.
                              • L Offline
                                lolobyte @CFenner
                                @CFenner
                                I also use at first a Foil. The result was very poor.
                                I dont’ want to recommend this kind of mirror.
                                Acrylglas
                                https://www.amazon.de/gp/product/B00SJADTWY/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
                                and Foil
                                https://www.amazon.de/gp/product/B00IC3EJ2M/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
                                  CFenner
                                  Then I guess I’m in :)
                                  # username sizes (m) area (m²) location additional comments pickup/delivery
                                  01 yawns ~ 0.8 * 0.8 ~ 0.64 Germany, Cologne polished edges delivery
                                  02 gustav1976 0.6 * 1.8 1.08 Germany, Koblenz polished edges delivery
                                  03 gustav1976 1.0 * 1.2 1.20 Germany, Koblenz polished edges delivery
                                  04 gustav1976 1.4 * 0.8 1.12 Germany, Koblenz polished edges delivery
                                  05 lolobyte 0.8*0.6 0,48 Germany, Heilbronn polished edges pickup
                                  06 Jeff 1,0 * 0,6 0,6 Germany, Karlsruhe polished edges pickup
                                  07 Ashidian 0,69 * 0,435 0,3 (pay 0,4) Germany, Rostock polished edges delivery
                                  08 cpramhofer 0,476 * 0,82 0,39 (possible??) Austria, Vienna polished edges delivery (cost??)
                                  09 mcg 0,5 * 1,0 0,5 Germany, Ludwigshafen polished edges delivery
                                  10 cfenner 0,667*0,667 0,45 Germany, Mannheim polished edges delivery, (maybe package with mcg)
                                  11
                                  Total 6,87
                                    Patrick
                                    I also would like to order a mirror glas. As i’m living also in schweinfurt, i would pick it up by my own. When I have my needed size i will make a additional comment.
                                      sero
                                      I’m in too. I have to measure once again, but it’ll be a bit more than 0.2m² (~0.4m * 0.5m). So I’ll pay 0.4m².
                                        Jeff
                                        Sorry for my late response.
                                        I was out of country for business and couldn’t really use the board with my cell phone.
                                        I’m in, too.
                                        BUT I need it before x-mas, otherwise I have to use a different mirror and have to think about my order…
                                        Thanks for the effort!
                                        • G Offline
                                          Goldjunge_Chriz
                                          @CFenner @mcg
                                          Maybe you can join up with @Jeff or @lolobyte. Both live in your area and pick up the glass. Or you all find a common solution together. :)
                                          @Patrick
                                          Oh great. Another MagicMirrorBuilder here in this area. Nice to hear from you.
                                          @sero
                                          Please join the List when you know your size.
                                          @Jeff
                                          Before xmas It will probably not work, I’m sorry. As I said in my first post the production and delivery time from the glass producer to me is about three weeks. Unfortunately we have no more three weeks until christmas.
                                          • L Offline
                                            @Goldjunge_Chriz @CFenner @mcg @Jeff
                                            No problem to take some mirrors to Heilbronn for other guys here.
                                            I’m owner of a big AUDI.
                                            • 27
                                            • 28
                                            • 4 / 28
