    Problems With Weather
    41 Posts 6 Posters 17.8k Views 6 Watching
      Mykle1 Project Sponsor Module Developer @brendan_c23
      @brendan_c23
      Something else is using port 8080. Most commonly it is because you have more than one instance of MM running at the same time. Or, there is another program on your pi using the same port.
        brendan_c23 @Mykle1
        @mykle1 Is it because I am using the same APPid for both weather modules? I have triple checked that I have the correct appid that was also working for the current weather. IMG_3983.JPG
          @brendan_c23 said in Problems With Weather:
          No, you can use the appid twice. However, MM can not share port 8080
            brendan_c23 @Mykle1
            @mykle1 How could I try fixing this?
            Mykle1M B 3 Replies Last reply Reply Quote 0
              @brendan_c23
              try running pm2 status in the terminal (I think that’s the command) and post the result here please.
              Don’t post a picture. Copy the terminal output and paste it into your reply.
              Also, do you have any other programs running on the Pi besides Magic Mirror?
                brendan_c23 @brendan_c23
                  @brendan_c23
                  output should look like this
                  pi@Pi3:~ $ pm2 status
                  │ Name │ mode │ status │ ↺ │ cpu │ memory   │
                  │ mm   │ fork │ online │ 0 │ 0%  │ 1.3 MB   │
                   Use `pm2 show <id|name>` to get more details about an app
                  pi@Pi3:~ $
                    brendan_c23 @Mykle1
                    @mykle1 pi@raspberrypi:~ $ pm2 status
                    │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
                    │ 0 │ MagicMirror │ fork │ 6 │ online │ 0% │ 2.6mb │
                    pi@raspberrypi:~ $
                      brendan_c23 @Mykle1
                      @mykle1 I should not have any other programs running besides the magic mirror as it is the only one I have installed , but not totally sure if there are any default programs already on there.
                        @brendan_c23
                        ok,. so try pm2 stop MagicMirror
                        then pm2 start MagicMirror
                          brendan_c23 @Mykle1
                          @mykle1 pi@raspberrypi:~ $ pm2 stop MagicMirror
                          [PM2] Applying action stopProcessId on app [MagicMirror](ids: 0)
                          [PM2] MagicMirror ✓
                          │ 0 │ MagicMirror │ fork │ 6 │ stopped │ 0% │ 0b │
                          pi@raspberrypi:~ $ pm2 start MagicMirror
                          [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
                          [PM2] MagicMirror ✓
                          [PM2] Process successfully started
                          │ 0 │ MagicMirror │ fork │ 6 │ online │ 0% │ 2.4mb │
                          pi@raspberrypi:~ $
                          Still no luck displaying forecast, thank you again for bearing with me this long
                            @brendan_c23
                            Were there any errors when MM launched?
                              @brendan_c23
                              MagicMirror should have launched when you issued the pm2 start MagicMirror command
                                brendan_c23 @Mykle1
                                @mykle1 No errors and yes MM launched, everything is displaying but the forecast
                                  brendan_c23 @Mykle1
                                  @mykle1 now it is displaying message: “Please set the correct openweather appid in the config for module: weatherforecast.”
                                    @brendan_c23
                                    I’m done for the night, mate. I would suggest you double check your appid at openweather. copy and paste it into your config entry for weatherforecast and make sure it is in quotes.
                                    Perhaps someone else will continue to help you tonight.
                                    Good luck
                                      brendan_c23 @Mykle1
                                      @mykle1 So I emailed Openweathermap for help and he said I should use the “One Call Api” https://openweathermap.org/api/one-call-api but I am having trouble figuring out how to incorporate the API call code into the weather forecast module?
                                        Uhhh, I’m pretty sure the default weatherforecast module DOES use the One Call API.
                                        I would try getting another api key using a different email. However, I suspect there might be something else going on there. Would you object to sending me your current openweather api key so I can test it here? If you agree, send it in a private chat message. I’ve sent you a chat. You can send your api key there if you agree.
                                          Mykle1 Project Sponsor Module Developer @Mykle1
                                          @brendan_c23
                                          weatherforecast: Your AppID does not support long term forecasts. Switching to fallback endpoint.
                                          Totally not your fault, just so you know.
                                          And I guess mine does not either, However, the module does load after a short delay but it only displays tomorrow’s weather. Same as when using my api key.
                                          This is very odd as I tested your api key in another weather module that uses open weather and it is giving all the data and NO errors. SO, I’m guessing the weatheforecast module itself has some issues.
                                          Are you dead set on using weatherforecast? There are many weather modules that provide you with forecasts and current weather. I’m fairly sure that some of them were built upon the openweather api and your current api key should work fine with them. Personally, I don’t use the default weather modules. I’ll be happy to give you a hand with them if you are willing to try them.
                                          Edit:
                                          I’ve just been informed that in the new MM release (April 1) both of those modules are being replaced by a newer version that does both current and forecast. Sheeesh
                                          W 1 Reply Last reply Reply Quote 1
                                          • W Offline
                                            Wenike @Mykle1
                                            @mykle1 I see the edit but now I’m wondering if the issue you and Brendan are experiencing are related to this old bug that was fixed last year and maybe it came back? Or that code could be a workaround until the fix next month.
                                            • 2 / 3
