    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 721.5k Views 57 Watching
    • ebolisaE
      ebolisa @j.e.f.f
      @j-e-f-f It works on P0. My bad, had an extra space in the api key. Thank you.
        j.e.f.f Project Sponsor Module Developer @anubis273
        @anubis273 This module works on 2.14 – tested that specifically myself. MagicMirror’s version numbering can get a bit confusing… 2.14 is MUCH newer than 2.2. Versioning goes 2.2, 2.3, … 2.9, 2.10, 2.11, etc.
        Double check your config settings. Maybe try with just the minimal config required for MMM-OpenWeatherForecast – apikey, latitude, and longitude – and see if the module works with just those. Also make sure you’ve run npm install in the MMM-OpenWeatherForecast directory.
        If the module runs with just the above, then start adding your additional configuration options one at a time to see which one caused it to fail. Let me know and we can take it from there.
        A 1 Reply Last reply
        • A
          anubis273 @j.e.f.f
          @j-e-f-f
          Hey j-e-f-f,
          thanks for clearing up my confusion about MagicMirror versions ;-) And thanks also for the quick feedback!
          So, I double checked the configuration and it doesn’t seem to have any syntax errors:
                  module: "MMM-OpenWeatherForecast",
                  header: "Forecast",
                      apikey: "myAPIKey",        //only string here
                      latitude: 50.748780,        //number works here
                      longitude: 7.137300        //so does a string
          I tried the minimal configuration as you suggested, unfortunately without success. I also checked the Api Key of OpenWeatherMap, this is also correct. The module also seems to work. The problem is that it just doesn’t load any weather data and I don’t understand why.
          If I find a solution to this, I will of course get back to you.
          Many greetings,
          Nubi
          J 1 Reply Last reply
            @anubis273 I just tried the default config with your long/lat settings and the module worked for me. So let’s try digging a little more. Are you seeing any errors in the logs? There are a bunch of places to look:
            If you are running MagicMirror using PM2, run pm2 restart mm && pm2 logs mm. Look for any output prefixed with [MMM-OpenWeatherForecast]. If you are instead running MagicMirror from the command line, any errors will be in the in the console, prefixed like above.
            Also need to check to see if Electron is throwing any errors. start MagicMirror in dev mode npm start dev. Any Electron errors will show in the browser console, usually in red.
            Also, since the basic config isn’t working for you, but is for me, can you double check that your API Key is correct?
            • Jeff
            A 2 Replies Last reply
            • A
              anubis273 @j.e.f.f
              @j-e-f-f
              Hey j-e-f-f,
              thanks for your quick reply. I will investigate every single point you wrote. Give me a little time for that, I will get back to you as soon as possible.
              Regards from Germany,
              Nubi
              • A
                anubis273 @j.e.f.f
                @j-e-f-f
                Hey Jeff,
                just a little update from my side:
                I am using my MagicMirror in a Docker container on a Synology DS718+ NAS. On my physical Mirror is an RPi4 which shows the MagicMirror in fullscreen mode via Browser. It is incredibly hard to get log files this way.
                When I open the log from Docker itself I see entries for the module, but they are all unspectacular.
                I took the API key and put it into a Get command via Postman:
                GET http://api.openweathermap.org/data/3.0/stations?appid=34a2f353f6933ab3b5deletedpart>
                        "id": "5ff1e82e09<deletedpart>",
                        "created_at": "2021-01-03T15:52:14.089Z",
                        "updated_at": "2021-01-03T15:52:14.089Z",
                        "external_id": "IKNVILIC5",
                        "name": "Neu-Vilich Bonn",
                        "longitude": 7.13,
                        "latitude": 50.74,
                        "altitude": 70,
                        "rank": 10
                The result looks good, the API key seems to work.
                I don’t have PM2 in my Docker container unfortunately, so I’ll have to see how to get the appropriate log files. I’ll get back to you when I have new findings on this.
                Many greetings,
                Nubi
                0m4r0 1 Reply Last reply
                  dkhorse74 @j.e.f.f
                  @j-e-f-f This is AWESOME!! SO SO much better than the default weather module… Question, how do I change the current weather header from “Forecast” to “Current”?
                  BKeyportB J 2 Replies Last reply
                  • BKeyportB
                    BKeyport Module Developer @dkhorse74
                    @dkhorse74 That’s the main header… hint…
                    D 1 Reply Last reply
                      shiryu1031
                      thank you so much for the awesome job.
                      however, may I ask how can I change the unit for the wind speed? I can’t seem to find where I can customize this.
                      • 0m4r0
                        0m4r Module Developer @anubis273
                        @anubis273 how do you start your magic mirror?
                        I guess with either npm run start or npm run server
                        In either case, you should be able to see the logs that are generated in the console…
                        you may also want to try to change the log level in your config.js to a more verbose level than “ERORR” (which I believe is the default)
                        https://github.com/0m4r
                        • O
                          OberfragGER
                          Nice Module.
                          But i dont get the german time format (24H) not working. And do you have any idea how to have the germany translation of the warnings?
                          Here is my config:
                          //		header: "Forecast",
                          			apikey: "myKey", //only string here
                          			latitude: 53,            //number works here
                          			longitude: 10,          //so does a string
                          			language: "de",
                          			forecastHeaderText: "Wetter Vorhersage für ....",
                          			iconset: "3c",
                          			label_timeFormat: "k[h]",
                          			label_days: ["So", "Mo", "Di", "Mi", "Do", "Fr", "Sa"]
                          O 1 Reply Last reply
                          • O
                            OberfragGER @OberfragGER
                            @oberfragger ok. Got sunrise working in german. There was a missing config line:
                            label_sunriseTimeFormat: "hh:mm",
                            and also with the time… also a typo (forgot the “hourly”):
                            label_hourlyTimeFormat: "k[h]",
                            I edited this to:
                            label_hourlyTimeFormat: "k[ Uhr]",
                            Still inspecting the storm warning in german…
                            karsten13K 1 Reply Last reply
                            • karsten13K
                              karsten13 @OberfragGER
                              @oberfragger
                              same problem here, saw meanwhile some of this warnings in german but mostly in english. Looks like a problem on the provider side, when inspecting the called url in the browser the retrieved data is in english.
                              So this can’t be solved by the module.
                              • swvalentiS
                                swvalenti Project Sponsor
                                @j-e-f-f Anyway to hide the special weather advisory? Really jacks up my layout, I took a look at config but nothing stood out.
                                  dkhorse74 @BKeyport
                                  @bkeyport said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                                  :thumbs_up: Thank You
                                  • karsten13K
                                    karsten13 @karsten13
                                    so now i catched the situation where the alerts are in english and in german:
                                    the data is coming directly from openweathermap, here the json-part:
                                      j.e.f.f Project Sponsor Module Developer @dkhorse74
                                      @dkhorse74 that’s the main header for the module. Change it like this:
                                          header: "Forecast",  <— here
                                            apikey: "a1b2c3d4e5f6g7h8j9k0", //only string here
                                            latitude: 51.490230,            //number works here
                                            longitude: "-0.258810"          //so does a string
                                        j.e.f.f Project Sponsor Module Developer @shiryu1031
                                        @shiryu1031 you can’t do that independently on the main units setting. OpenWeather returns mph for imperial, and m/s for standard and metric.
                                          j.e.f.f Project Sponsor Module Developer @swvalenti
                                          @swvalenti yes you can. The weather alerts are part of the summary section. OpenWeather returns such a short summary that I didn’t think it necessary to make two separate configure. Two ways to turn off the alerts:
                                          • set summary : false
                                          • if you want the summary but not the alerts, you can hide them in your custom css as follows:
                                          .MMM-OpenWeatherForecast .weather-alert {
                                            display: none;
                                          I think I’ll look at a way to truncate weather alerts so they don’t take up so much space.
                                          swvalentiS 1 Reply Last reply
                                            j.e.f.f Project Sponsor Module Developer @karsten13
                                            @karsten13 I don’t think there is much I can do here. I’ve coded this module to explicitly pass through a language parameter, either whatever is set in your main MM config, or whatever you explicitly set in the module’s config. It seems that OpenWeather doesn’t translate the weather alert, but merely passes them on as-is from whatever source it gets them from. Which is why sometimes you’re getting only English, and other times you’re getting multiple translations.
                                            • 12
                                            • 13
                                            • 2 / 13
