    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 721.5k Views 57 Watching
      j.e.f.f Project Sponsor Module Developer @swvalenti
      @swvalenti said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
      Last thing is it possible to just get the red to display and nothing else?
      Yes, you can do this in your custom.css file.
      To hide the description and alert source:
      .MMM-OpenWeatherForecast .weather-alert .weather-alert-description,
      .MMM-OpenWeatherForecast .weather-alert .weather-alert-source {
          display: none;
      To change the size of the red title text:
      .MMM-OpenWeatherForecast .weather-alert .weather-alert-title {
         font-size: 17px; /* adjust this */
      alternatively, to change the size of the alert icon:
      .MMM-OpenWeatherForecast .weather-alert {
          background-size: 30px 26px;  /* width height */
          background-position: 6px 10px;  /* top left */
      If you change the size of the icon, you may want to adjust the title padding as well:
        padding-left: 36px; /* adjust this */
      EVERYTHING is in this module has a CSS class applied to it so you can tailor every last little bit to your specific needs. Take a look at MMM-OpenWeatherForecast.css for existing CSS rules and mmm-openweather-forecast.njk to see what classes have been applied to which UI elements.
        julien-vancouver
        Just a quick thanks for the module !
          pwalsh2202
          I’m looking to see if I can get just a truncated text-based description of the upcoming weather.
          When I search for a location on the openweathermap.org site, I do see the site gathers this data “Heavy intensity rain. Moderate breeze. The high will be 68°F, the low will be 50°F.”, which is exactly what I’m looking to display on my mirror, but I don’t see how this might be communicated via the API.
          On OWM’s page, I don’t even see this data provided in the sample API calls provided. Is there a way for your module to provide this data or does this require one of the paid APIs? Thank you for all of the effort you’ve put into this.
          J 1 Reply Last reply
            motdog
            So I am working on two mirrors. The first set up this module with no problem I created a new api key for the second mirror and when the forecast shows, its missing a day. Today is Friday but when I use this config, the first date showing up in the forecast is Sunday. Makes no sense.
            Help please
            			  module: "MMM-OpenWeatherMapForecast",
            			  header: "Kansas City Weather",
            			  classes: "default everyone",
            			  disabled: false,
            			    apikey: "xxxxxxxxxxx",
            			    latitude: "39.0997",
            			    longitude: "94.5786",
            			    iconset: "5c",
            		            concise: false,
            			    maxDailiesToShow: 5,
            			    showHourlyForecast: false,
            			    forecastLayout: "table"
              mielu80 @j.e.f.f
              @j-e-f-f
              Big thanks to you,sir !
              Now the module is just perfect for me,everything is exactly as I wished.
              • swvalentiS
                swvalenti Project Sponsor
                @j-e-f-f here is my config and see the picture, I would like to only see the alert in red and the first line “elevated risk of wildfire”. That doable? Sorry for all the questions on this I’m trying to work the problem.
                .MMM-OpenWeatherForecast .weather-alert .weather-alert-description {
                    display: 1;
                    display: none;
                  -webkit-line-clamp: 2; /* adjust this as desired */
                • goldyfruitG
                  goldyfruit Project Sponsor
                  Just starting to use it, changed few settings and I’m all set.
                  Great job!
                  Build smart things with magic and love! | https://smartgic.io
                  • StoffbeuteluweS
                    Stoffbeuteluwe Project Sponsor
                    Great module thank you …Jeff
                      motdog
                      I am finding a weird quirk. For the future forecast days once noon local time hits, the next day forecast disappears
                      Today it showed Friday as a forecast day, after noon hit the next 3 days shown in forecast are sat, sun & Mon.
                      My config is posted above
                        j.e.f.f Project Sponsor Module Developer @motdog
                        @motdog let me look into this. My code assumes the first daily forecast is “today” and starts with the second one in the collection. It’s possible this is something the API does and I just hadn’t noticed before. It would make sense because I’ve typically worked on this module during the morning. Will test later.
                        0m4r0 1 Reply Last reply
                        • 0m4r0
                          0m4r Module Developer @j.e.f.f
                          @j-e-f-f can it be a timezone issue?
                          are the APIs expecting time in UTC? Moment does operates on user timezone (or browser timezone in this case)
                          https://github.com/0m4r
                          J 2 Replies Last reply
                            j.e.f.f Project Sponsor Module Developer @0m4r
                            @0m4r If it is then it’s a bug in the API. The API is supposed to return all data time shifted to the time zone for the long/lat you specify.
                            I should know more soon. Running a test right now and just waiting for the clock to tick past noon.
                              @0m4r Still troubleshooting this. I don’t see this happening when I use my own long/lat. Will try with yours, but I will need to wait until it ticks past 12:00pm your time. (I’m in London, so will need to check later this evening).
                              One thing I did notice, though… the long lat you have in your config is for Shanghai, China, not Kansas City. You forgot the “minus” sign in front of the longitude property. Maybe that fixes it?
                              0m4r0 M 2 Replies Last reply
                              • 0m4r0
                                @j-e-f-f I think you want to mention @motdog, not me :)
                                  motdog @j.e.f.f
                                  @j-e-f-f I think that is the problem. I’ll keep you posted
                                    @0m4r Yes indeed!
                                    @motdog the more I think about it, it makes sense that the issue you’re seeing is a result of the missing minus sign in your longitude. Essentially, you’re shifting what you’re expecting by exactly 12 hours, meaning that when it’s noon in Kansas city, it’s midnight in Shanghai, hence moving to the next day, and explains why your dailies are shifting by one after 12:00 pm for you.
                                    swvalentiS M 2 Replies Last reply
                                    • swvalentiS
                                      swvalenti Project Sponsor @j.e.f.f
                                      @j-e-f-f did you see my previous post is that at all doable?
                                        motdog @j.e.f.f
                                        @j-e-f-f yep the website where i got the coordinates was wrong. Every other one had the minus sign. Thanks for the extra eyes.
                                        B 1 Reply Last reply
                                          blackeaglece @motdog
                                          Hi everyone, I’ve been using this module for more than a year and it’s fine, but since I did the last update of MM I get the {DEGREE} entry after perceived (as you can see from the attached image), I’ve also updated the module but nothing to do. How can I do to remove it? Thank you very much
                                            miniashman
                                            Can someone guide me on how to get the weather icon enabled next to the current temperature, please? Gone through the topic but no one else seems to have this issue.
                                            J StoffbeuteluweS 2 Replies Last reply
                                            • 12
                                            • 13
                                            • 4 / 13
