    42" Full body Mirror
    16 Posts 14 Posters 21.7k Views 13 Watching
    • T
      thoeng
      BACKGROUND
      I came across smart mirror accidentally when browsing for full body mirror design and decided to build one for wife.
      We want to have quality mirror reflection (being mirror in 1st place!) with beautiful quality frame, activated by motion sensor and integrated with GA via USB mic.
      It has been quite journey to design, find materials and actually build it but it is definitely worth it! It adds cool factor to our living room and I am quite proud of it!
      Specs and Cost:
      • Mirror Glass - 120cm L X 60cm W @6mm thick - EUR 145
        We live in UAE and this is the toughest part to deal with! At some point, I almost gave up and go with film!
      • Frame - 160cm L X 80cm W X 8cm D - EUR 290
        An important aspect. The mirror is in living room and must presentable/blend with rest of furniture. We went with custom build solid oak on main & pine on inner frame
      • Rasberry pi 3B + with Motion Sensor & USB Microphone - EUR 48
        Had to buy RPI twice because the the power socket broke on the 1st one :(
      • 42" Old LG TV - Free from friend
        Frame completely detached and side bezel wrapped with black electrical tape. The speakers and IR component also re-arranged to the side of the mirror to save weight and slim down the mirror. Unfortunately, the TV display “no signal” when PIR sensor turn the TV off so I decided to blackout the screen instead of actual off.
      • Modules
        Standard modules plus Globe, Networkscanner, NetworkConnection and AssistantMK2 (Thanks Sean for helping out!)
      Next step:
      1. Properly hang on wall and conceal the cable - The mirror is 27kg and expensive! securely hang it will require effort. Probably via french cleat and toogle bolt.
      2. Find out way to Increase microphone sensitivity as I have to speak closely and louder to interact. Maybe replace small USB Mic with Jabra speak 410?
      3. Revisit modules to add more practicality to the mirror.
      Photos:
      A cowboysdudeC N 3 Replies Last reply Reply Quote 11
        very cool… you give me hope… I have a 50 in tv and want to do the same. glass is about $600 and needs shipping to get to me…
        • WILLIAM_WANDIEW
          WILLIAM_WANDIE
          this is really cool mate… you went all in and it is really worth it. you can intergrate led lights at the back of the frame with the installed sensor… would add a really nice touch … but i really like your work inspired:thumbs_up_medium_skin_tone:
          • A
            AImirror Banned @thoeng
            @thoeng
            Pretty Cool !
              chris1971
              Nice work…
              Is Globe still running? I have problems after the server change…
              • T
                thoeng @chris1971
                @chris1971
                Unfortunately, I have swapped it with MMM-Commute to increase mirror practicality.
                As an update, the mirror is working well but experiencing weird unresponsive blank screen randomly sometime as little as 1 hour to several hour. The menu and everything else working fine only MM is blank.
                to minimise the issue, I created hourly cron job to reload mm.
                Any thoughts?
                • T
                  thoeng
                  UPDATE:
                  1. Added new MMM Travel with my history. It looks much more appealing!
                  2. Sadly, Issue with microphone sensitivity remains. I have to be very close to mic to activate assistant :(
                  https://ibb.co/N3pvt4c
                  https://ibb.co/PctM9v7
                  B S 2 Replies Last reply Reply Quote 2
                    bhepler Module Developer @thoeng
                    @thoeng You’re right, it does look more interesting that way. Looking good.
                    • T
                      theswapmeat
                      @thoeng Where did you get the mirror from? Did you buy it locally in the UAE and if so, from where?
                      • KamiSchamiK
                        KamiSchami
                        Looks great 😁
                        Real programmers never work 9 to 5. If they are around at 9 AM, it’s because they were up all night.
                          duychienvt
                          @thoeng said in 42" Full body Mirror:
                          Can I know your vendor of Mirror glass?
                            Salgado26
                            Thanks for creating it. Looking forward for the solution.
                            • cowboysdudeC
                              cowboysdude Module Developer @thoeng
                              @thoeng Looks amazing!!!
                                PierreSweden @KamiSchami
                                @kamischami Waow, really nice Mirror
                                  SoleLo @thoeng
                                  @thoeng What weather module is it that you are using?
                                  • N
                                    Nneuland @thoeng
                                    I used Bear glass in brooklyn. Very good prices. I payed 150 for a 28"x 17" piece of glass
