    42" Full body Mirror
    16 Posts 14 Posters 21.5k Views 13 Watching
    • WILLIAM_WANDIEW Offline
      WILLIAM_WANDIE
      this is really cool mate… you went all in and it is really worth it. you can intergrate led lights at the back of the frame with the installed sensor… would add a really nice touch … but i really like your work inspired:thumbs_up_medium_skin_tone:
        AImirror Banned @thoeng
        @thoeng
        Pretty Cool !
          chris1971
          Nice work…
          Is Globe still running? I have problems after the server change…
          • T Offline
            thoeng @chris1971
            @chris1971
            Unfortunately, I have swapped it with MMM-Commute to increase mirror practicality.
            As an update, the mirror is working well but experiencing weird unresponsive blank screen randomly sometime as little as 1 hour to several hour. The menu and everything else working fine only MM is blank.
            to minimise the issue, I created hourly cron job to reload mm.
            Any thoughts?
            • T Offline
              thoeng
              UPDATE:
              1. Added new MMM Travel with my history. It looks much more appealing!
              2. Sadly, Issue with microphone sensitivity remains. I have to be very close to mic to activate assistant :(
              https://ibb.co/N3pvt4c
              https://ibb.co/PctM9v7
              B S 2 Replies Last reply Reply Quote 2
                bhepler Module Developer @thoeng
                @thoeng You’re right, it does look more interesting that way. Looking good.
                • T Offline
                  theswapmeat
                  @thoeng Where did you get the mirror from? Did you buy it locally in the UAE and if so, from where?
                  • KamiSchamiK Offline
                    KamiSchami
                    Looks great 😁
                    Real programmers never work 9 to 5. If they are around at 9 AM, it’s because they were up all night.
                      duychienvt
                      @thoeng said in 42" Full body Mirror:
                      Can I know your vendor of Mirror glass?
                        Salgado26
                        Thanks for creating it. Looking forward for the solution.
                        • cowboysdudeC Offline
                          cowboysdude Module Developer @thoeng
                          @thoeng Looks amazing!!!
                            PierreSweden @KamiSchami
                            @kamischami Waow, really nice Mirror
                              SoleLo @thoeng
                              @thoeng What weather module is it that you are using?
                              • N Offline
                                Nneuland @thoeng
                                I used Bear glass in brooklyn. Very good prices. I payed 150 for a 28"x 17" piece of glass
