    42" Full body Mirror
    16 Posts 14 Posters 21.7k Views 13 Watching
      chris1971
      Nice work…
      Is Globe still running? I have problems after the server change…
      • T
        thoeng @chris1971
        @chris1971
        Unfortunately, I have swapped it with MMM-Commute to increase mirror practicality.
        As an update, the mirror is working well but experiencing weird unresponsive blank screen randomly sometime as little as 1 hour to several hour. The menu and everything else working fine only MM is blank.
        to minimise the issue, I created hourly cron job to reload mm.
        Any thoughts?
        • T
          thoeng
          UPDATE:
          1. Added new MMM Travel with my history. It looks much more appealing!
          2. Sadly, Issue with microphone sensitivity remains. I have to be very close to mic to activate assistant :(
          https://ibb.co/N3pvt4c
          https://ibb.co/PctM9v7
          B S 2 Replies Last reply Reply Quote 2
            bhepler Module Developer @thoeng
            @thoeng You’re right, it does look more interesting that way. Looking good.
            • T
              theswapmeat
              @thoeng Where did you get the mirror from? Did you buy it locally in the UAE and if so, from where?
              • KamiSchamiK
                KamiSchami
                Looks great 😁
                Real programmers never work 9 to 5. If they are around at 9 AM, it’s because they were up all night.
                  duychienvt
                  @thoeng said in 42" Full body Mirror:
                  Can I know your vendor of Mirror glass?
                    Salgado26
                    Thanks for creating it. Looking forward for the solution.
                    • cowboysdudeC
                      cowboysdude Module Developer @thoeng
                      @thoeng Looks amazing!!!
                        PierreSweden @KamiSchami
                        @kamischami Waow, really nice Mirror
                          SoleLo @thoeng
                          @thoeng What weather module is it that you are using?
                          • N
                            Nneuland @thoeng
                            I used Bear glass in brooklyn. Very good prices. I payed 150 for a 28"x 17" piece of glass
