    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 721.5k Views 57 Watching
    • StoffbeuteluweS
      Stoffbeuteluwe Project Sponsor @miniashman
      @miniashman
      hi… how can I get the C for Celsius behind the degree, on my mirror I only have the number …
      BKeyportB M 2 Replies Last reply
      • BKeyportB
        BKeyport Module Developer @Stoffbeuteluwe
        Actually, I’d like the F for F#@(%**&@ stupid measurements, for mine too.
          miniashman @Stoffbeuteluwe
          @stoffbeuteluwe In the custom.css i added the following:
          .MMM-OpenWeatherForecast .current-conditions-wrapper .current.temperature:after {
              content: "C";
          .MMM-OpenWeatherForecast .extra-current-conditions-wrapper  . temperature-container . high-temperature:after,
          .MMM-OpenWeatherForecast .extra-current-conditions-wrapper  . temperature-container . low-temperature:after {
              content: "C";
          .MMM-OpenWeatherForecast .forecast-item.daily .high-temperature:after,
          .MMM-OpenWeatherForecast .forecast-item.daily .low-temperature:after {
              content: "C";
          You can change “C” to “F” if needed depending on which units you want to use.
          StoffbeuteluweS J 2 Replies Last reply
          • StoffbeuteluweS
            @miniashman oh thanks 🙏 I will try today …
              j.e.f.f Project Sponsor Module Developer @miniashman
              @miniashman said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                  content: "C";
                  content: "C";
                  content: "C";
              There’s actually a slight bug in this. The CSS should be as follows (notice he removal of the sapce between the period and class names in a few places):
                  content: "C";
              .MMM-OpenWeatherForecast .extra-current-conditions-wrapper  .temperature-container .high-temperature:after,
              .MMM-OpenWeatherForecast .extra-current-conditions-wrapper  .temperature-container .low-temperature:after {
                  content: "C";
                  content: "C";
                Biebermann
                One question about this, how do you get the weather warnings from the DWD displayed in German? The language is set to German “de” but these messages are displayed in English.
                Unfortunately I have not found anything.
                P.S. Sorry for my English :confused_face:
                karsten13K 1 Reply Last reply
                  miniashman
                  @j-e-f-f Thank you. Will correct it
                  • karsten13K
                    karsten13 @Biebermann
                    @biebermann
                    https://forum.magicmirror.builders/post/89463
                    https://forum.magicmirror.builders/post/90002
                    B P 2 Replies Last reply
                      Biebermann @karsten13
                      @karsten13
                      I have already gone through the two posts.
                      But thanks for your answer.
                      P.S. now I also have the double display since today. Let’s wait and see if there will be a solution.
                      J 1 Reply Last reply
                        j.e.f.f Project Sponsor Module Developer @Biebermann
                        @biebermann There isn’t a solution. The alerts come through as-is. There seems to be no logic in place on OpenWeather’s side to return the alerts in the configured language.
                        B 1 Reply Last reply
                          Biebermann @j.e.f.f
                          @j-e-f-f
                          Ok, then there is nothing we can do for the time being.
                          Is that ever fixed?
                          J lavolp3L 2 Replies Last reply
                            @biebermann it’s something I can’t fix. It’s a problem with OpenWeather’s API. Someone previously mentioned that OpenWeather had acknowledged it was an issue and maybe it will be fixed in the future. But the alerts don’t have a language identifier associated with them so it’s not even like I could filter out the duplicates in the wrong language.
                            • lavolp3L
                              lavolp3 Module Developer @Biebermann
                              @biebermann A workaround would be to additionally use MMM-DWD-WarnWeather which works pretty well.
                              Another option could be to run the warning through the google-translate npm module which you could add to the module.
                              https://www.npmjs.com/package/@vitalets/google-translate-api
                              Might be a bit much however.
                              How to troubleshoot modules
                              MMM-soccer v2, MMM-AVStock
                                Biebermann @lavolp3
                                @j.e.f.f
                                Don’t stress, if it’s not possible to correct it (yet) then so be it.
                                @lavolp3
                                I had the module running, thought since it is in this module here, I could save myself another module.
                                Is there then the possibility to turn off the severe weather warnings completely?
                                lavolp3L 1 Reply Last reply
                                • lavolp3L
                                  @Biebermann
                                  I used a css “hack” for that
                                  Add to custom.css
                                  .MMM-OpenWeatherForecast .weather-alert {
                                      display: none;
                                  You can also set showSummary: false in the config but would then lose the whole summary
                                    Biebermann @lavolp3
                                    @lavolp3
                                    Thank you, it can be so simple when you come to it.
                                    O 1 Reply Last reply
                                    • O
                                      OberfragGER @Biebermann
                                      After updating to the newest version and MagicMirror 2.15 too, the UV-index produces an extra line.
                                      How is that possible to have every icon in the same line?
                                        A Former User @blackeaglece
                                          PH1TCH @karsten13
                                          @karsten13 & @Biebermann
                                          Probably not the most elegant solution ever, but I added the following jquery code to the index.html located in the MagicMirror folder which will check every 30 seconds for the text “There” in elements of the class "weather-alert-description " and will hide the parent element (so the whole thing) if found.
                                          Since the English alerts usually start with “There” I can hide them this way and only leave the German ones
                                          <script src="https://ajax.googleapis.com/ajax/libs/jquery/2.1.3/jquery.min.js"></script>
                                          <script>
                                          	setInterval(function(){
                                          		$('.weather-alert-description').each(function () {
                                          			  if ($(this).text().includes('There')) {
                                          				$(this).parent().hide();
                                          	}, 30000);
                                          </script>
                                          • F
                                            fillilutten
                                            I’m sorry if this is stupid - but I’m currently showing extraCurrentConditions - high/low + precipitation. And precipitation shows in “mm” and I’d prefer if it could show in % how likely it is to rain/snow that day. So I know if I should bring an umbrella or not.
                                            Is this possible? I tried using hourly forecast + extras and set that to 12 hours interval and only show one daily. But it didn’t work.
                                            Thanks!
                                            • 12
                                            • 13
                                            • 5 / 13
