    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 692.4k Views 57 Watching
    • karsten13K Offline
      karsten13 @Biebermann
      @biebermann
      Unfortunately I have not found anything.
      https://forum.magicmirror.builders/post/89463
      https://forum.magicmirror.builders/post/90002
      B P 2 Replies Last reply Reply Quote 0
        Biebermann @karsten13
        @karsten13
        I have already gone through the two posts.
        But thanks for your answer.
        P.S. now I also have the double display since today. Let’s wait and see if there will be a solution.
          j.e.f.f Project Sponsor Module Developer @Biebermann
          @biebermann There isn’t a solution. The alerts come through as-is. There seems to be no logic in place on OpenWeather’s side to return the alerts in the configured language.
            Biebermann @j.e.f.f
            @j-e-f-f
            Ok, then there is nothing we can do for the time being.
            Is that ever fixed?
            J lavolp3L 2 Replies Last reply Reply Quote 0
              @biebermann it’s something I can’t fix. It’s a problem with OpenWeather’s API. Someone previously mentioned that OpenWeather had acknowledged it was an issue and maybe it will be fixed in the future. But the alerts don’t have a language identifier associated with them so it’s not even like I could filter out the duplicates in the wrong language.
              • lavolp3L Offline
                lavolp3 Module Developer @Biebermann
                @biebermann A workaround would be to additionally use MMM-DWD-WarnWeather which works pretty well.
                Another option could be to run the warning through the google-translate npm module which you could add to the module.
                https://www.npmjs.com/package/@vitalets/google-translate-api
                Might be a bit much however.
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
                  Biebermann @lavolp3
                  @j.e.f.f
                  Don’t stress, if it’s not possible to correct it (yet) then so be it.
                  @lavolp3
                  I had the module running, thought since it is in this module here, I could save myself another module.
                  Is there then the possibility to turn off the severe weather warnings completely?
                  • lavolp3L Offline
                    @Biebermann
                    I used a css “hack” for that
                    Add to custom.css
                    .MMM-OpenWeatherForecast .weather-alert {
                        display: none;
                    You can also set showSummary: false in the config but would then lose the whole summary
                      Biebermann @lavolp3
                      @lavolp3
                      Thank you, it can be so simple when you come to it.
                      • O Offline
                        OberfragGER @Biebermann
                        After updating to the newest version and MagicMirror 2.15 too, the UV-index produces an extra line.
                        How is that possible to have every icon in the same line?
                          [[global:former-user]] @blackeaglece
                            PH1TCH @karsten13
                            @karsten13 & @Biebermann
                            Probably not the most elegant solution ever, but I added the following jquery code to the index.html located in the MagicMirror folder which will check every 30 seconds for the text “There” in elements of the class "weather-alert-description " and will hide the parent element (so the whole thing) if found.
                            Since the English alerts usually start with “There” I can hide them this way and only leave the German ones
                            <script src="https://ajax.googleapis.com/ajax/libs/jquery/2.1.3/jquery.min.js"></script>
                            <script>
                            	setInterval(function(){
                            		$('.weather-alert-description').each(function () {
                            			  if ($(this).text().includes('There')) {
                            				$(this).parent().hide();
                            	}, 30000);
                            </script>
                            • F Offline
                              fillilutten
                              I’m sorry if this is stupid - but I’m currently showing extraCurrentConditions - high/low + precipitation. And precipitation shows in “mm” and I’d prefer if it could show in % how likely it is to rain/snow that day. So I know if I should bring an umbrella or not.
                              Is this possible? I tried using hourly forecast + extras and set that to 12 hours interval and only show one daily. But it didn’t work.
                              Thanks!
                                rcberg3
                                @j-e-f-f any way to hide the wind units in the hourly and daily forecasts? I’m finding that they’re pushing onto a second line when the wind speed is greater than 2 digits. I’d be happy just to show the number and not the units.
                                  j.e.f.f Project Sponsor Module Developer @rcberg3
                                  @rcberg3 sorry, the code doesn’t currently allow for this, nor do the units have their own CSS class that you can use to hide them.
                                  You could instead increase the width of the module in order to give the forecast a bit more space to stop the wind units from wrapping to a second line. Instructions to do so are included in the readme.
                                    rcberg3 @j.e.f.f
                                    @j-e-f-f Appreciate it! I added the nowrap to the css for now and it’s better.
                                      MMuser
                                      Hi is it possible to swap warnings and extra weather info, like shown below ?
                                        cwong79
                                        I am a complete newbie. I followed the instructions exactly, I even did it multiple times to ensure it was done correctly. As during installation process, some warnings around vulnerability kicked up and I attempted to resolve. I removed the copy and reinstalled MMM-OpenWeatherForecast. I have the default weather module commented out and just running this module. I cannot get it working, not sure why. I copied the sample configuration and inserted the appropriate API key and Long/Lat. What am I doing wrong?
                                        			module: "MMM-OpenWeatherForecast",
                                        			header: "Forecast",
                                        						apikey: "??????????", //SUPER SECRET
                                        						latitude: 26.124161,
                                        						longitude: -80.143593,
                                        						units: "imperial",
                                        						iconset: "3c",
                                        						colored: true,
                                        						concise: true,
                                        						requestDelay: "2000",
                                        						showFeelsLikeTemp: true,
                                        						showCurrentConditions: true,
                                        						showSummary: true,
                                        						showExtraCurrentConditions: true,
                                        						extraCurrentConditions: {
                                        													highLowTemp: true,
                                        													precipitation: true,
                                        													sunrise: true,
                                        													sunset: true,
                                        													wind: true,
                                        													barometricPressure: false,
                                        													humidity: true,
                                        													dewPoint: false,
                                        													uvIndex: true,
                                        													visibility: false
                                        						forecastLayout: "table",
                                        						forecastHeaderText: "",
                                        						hourlyForecastTableHeaderText: "By the hour",
                                        						showHourlyForecast: true,
                                        						showHourlyTableHeaderRow: true,
                                        						hourlyForecastInterval: 1,
                                        						maxHourliesToShow: 10,
                                        						hourlyExtras: {
                                        											wind: true,
                                        											humidity: false,
                                        											dewPoint: false,
                                        											uvIndex: false,
                                        											visibility: false
                                        						dailyForecastTableHeaderText: "Throughout the week",
                                        						showDailyForecast: true,
                                        						showDailyTableHeaderRow: true,
                                        						maxDailiesToShow: 5,
                                        						dailyExtras: {
                                        										sunrise: false,
                                        										sunset: false,
                                        										wind: true,
                                        										humidity: false,
                                        										dewPoint: false,
                                        										uvIndex: false
                                          sdetweil @cwong79
                                          @cwong79 I added the code wrapper around your config info
                                          to do this
                                          paste your text.
                                          select it
                                          then push the button </>
                                          above the editor window
                                            cwong79 @sdetweil
                                            @sdetweil thank you. Sorry, its my first post.
                                            • 12
                                            • 13
                                            • 6 / 13
