    New Weather module
    16 Posts 6 Posters 3.9k Views 5 Watching
      A Former User
        A Former User
          DJBOOB66 @Guest
          @hango where do I add the disable: true? a few more instructions would be good I’m new
          ? cowboysdudeC 2 Replies Last reply Reply Quote 0
            A Former User @DJBOOB66
              DJBOOB66 @Guest
              @hango
              still not working getting syntax error
              S A 2 Replies Last reply Reply Quote 0
                sdetweil @DJBOOB66
                @djboob66 and a new line will require a trailing comma, yes?, more to follow
                • cowboysdudeC
                  cowboysdude Module Developer @DJBOOB66
                  @djboob66 anywhere outside the config section ie…
                          module: "Alerts",
                            css: "2",
                            sec: true
                          disabled: false,
                          position: "middle_center"
                  OR
                          disabled: false,
                          module: "Alerts",
                          order: "1",
                            css: "2",
                            sec: true
                  Either way works ;)
                  • A
                    Alloc @DJBOOB66
                    @djboob66 You spelled True wrong in your config
                      A Former User
                        sdetweil @Guest
                        @hango this is the doc on the attributes for a module, independent of the module specific config
                        https://docs.magicmirror.builders/modules/configuration.html
                        ? 1 Reply Last reply Reply Quote 1
                          A Former User @sdetweil
                          S Mykle1M 2 Replies Last reply Reply Quote 0
                            sdetweil @Guest
                            @hango helping others, by linking to the definitions
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @Guest
                                @hango said in New Weather module:
                                yes I know. what is the point of this remark?
                                Uhhhh, having a bad day?
                                  A Former User @Mykle1
                                    DJBOOB66
                                    Thanks, i give it another try,
