    New Weather module
    16 Posts 6 Posters 3.9k Views 5 Watching
      A Former User
        DJBOOB66 @Guest
        @hango where do I add the disable: true? a few more instructions would be good I’m new
        ? cowboysdudeC 2 Replies Last reply Reply Quote 0
          A Former User @DJBOOB66
            DJBOOB66 @Guest
            @hango
            still not working getting syntax error
            S A 2 Replies Last reply Reply Quote 0
              sdetweil @DJBOOB66
              @djboob66 and a new line will require a trailing comma, yes?, more to follow
              • cowboysdudeC
                cowboysdude Module Developer @DJBOOB66
                @djboob66 anywhere outside the config section ie…
                        module: "Alerts",
                          css: "2",
                          sec: true
                        disabled: false,
                        position: "middle_center"
                OR
                        disabled: false,
                        module: "Alerts",
                        order: "1",
                          css: "2",
                          sec: true
                Either way works ;)
                • A
                  Alloc @DJBOOB66
                  @djboob66 You spelled True wrong in your config
                    A Former User
                      sdetweil @Guest
                      @hango this is the doc on the attributes for a module, independent of the module specific config
                      https://docs.magicmirror.builders/modules/configuration.html
                      ? 1 Reply Last reply Reply Quote 1
                        A Former User @sdetweil
                        S Mykle1M 2 Replies Last reply Reply Quote 0
                          sdetweil @Guest
                          @hango helping others, by linking to the definitions
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @Guest
                              @hango said in New Weather module:
                              yes I know. what is the point of this remark?
                              Uhhhh, having a bad day?
                                A Former User @Mykle1
                                  DJBOOB66
                                  Thanks, i give it another try,
