    New Weather module
    16 Posts 6 Posters 3.2k Views 5 Watching
      DJBOOB66 @Guest
      @hango
      still not working getting syntax error
      S A 2 Replies Last reply Reply Quote 0
        sdetweil @DJBOOB66
        @djboob66 and a new line will require a trailing comma, yes?, more to follow
        • cowboysdudeC Offline
          cowboysdude Module Developer @DJBOOB66
          @djboob66 anywhere outside the config section ie…
                  module: "Alerts",
                    css: "2",
                    sec: true
                  disabled: false,
                  position: "middle_center"
          OR
                  disabled: false,
                  module: "Alerts",
                  order: "1",
                    css: "2",
                    sec: true
          Either way works ;)
            Alloc @DJBOOB66
            @djboob66 You spelled True wrong in your config
              A Former User
                sdetweil @Guest
                @hango this is the doc on the attributes for a module, independent of the module specific config
                https://docs.magicmirror.builders/modules/configuration.html
                ? 1 Reply Last reply Reply Quote 1
                  A Former User @sdetweil
                  S Mykle1M 2 Replies Last reply Reply Quote 0
                    sdetweil @Guest
                    @hango helping others, by linking to the definitions
                        Mykle1 Project Sponsor Module Developer @Guest
                        @hango said in New Weather module:
                        yes I know. what is the point of this remark?
                        Uhhhh, having a bad day?
