    MMM-NewsAPI
    103 Posts 10 Posters 92.5k Views 8 Watching
    • swvalentiS
      swvalenti Project Sponsor @mumblebaj
      @mumblebaj @bugsounet MMM-News still works for me when you say you will delete it does that mean it will stop working? If so NBD I will use my man @mumblebaj module
      mumblebajM 1 Reply Last reply
      • mumblebajM
        mumblebaj Module Developer @swvalenti
        @swvalenti The module will not stop working.
        swvalentiS 1 Reply Last reply
        • swvalentiS
          @mumblebaj Whatever you do don’t update the module, mmm remote control showed update I just did that and it deprecated the module and no longer works!
          • mumblebajM
            @swvalenti You can clone the module from here:
            MMM-News
            The config should still work.
            • swvalentiS
              @mumblebaj gave yours a try but get this error?
              MMM-NewsAPI.js:129 Uncaught TypeError: Cannot read property 'sourceId' of undefined
                  at Class.draw (MMM-NewsAPI.js:129)
                  at Class.socketNotificationReceived (MMM-NewsAPI.js:96)
                  at module.js:245
                  at Socket.<anonymous> (socketclient.js:38)
                  at Socket../node_modules/component-emitter/index.js.Emitter.emit (index.js:145)
                  at Socket.emit (typed-events.js:46)
                  at Socket.emitEvent (socket.js:263)
                  at Socket.onevent (socket.js:250)
                  at Socket.MMSocket.socket.onevent (socketclient.js:32)
                  at Socket.onpacket (socket.js:214)
              Config
                              module: "MMM-NewsAPI",
                              header: "news",
                              position: "bottom_bar",
                                      apiKey: "super duper secret",
                                      type: "horizontal",
                                      choice: "headlines",
                                      pageSize: 9,
                                      className: "NEWS",
                                      drawInterval: 1000*30,
                                      templateFile: "template.html",
                                      fetchInterval: 1000*60*60,
                                      query: {
                                              country: "us",
                                              //category: "",
                                              //q: "covid",
                                              //qInTitle: "",
                                              sources: "Fox News",
                                              domains: "foxnews.com",
                                              //excludeDomains: "",
                                              language: "en"
              • mumblebajM
                @swvalenti said in MMM-NewsAPI:
                The issue is with sources “Fox News”. That is not a valid source. Remove it and it should work fine with just the domain of foxnews.com
                • swvalentiS
                  @mumblebaj said in MMM-NewsAPI:
                  Understood, works great now. Nice module good job!!!
                  bugsounetB 1 Reply Last reply
                  • bugsounetB
                    bugsounet Banned @swvalenti
                    @mumblebaj, perfect, that i see Transfert is now done ;)
                    Happy coding,
                    @bugsounet
                    • mumblebajM
                      mumblebaj Module Developer @bugsounet
                      @bugsounet Thank you. I have received.
                      • swvalentiS
                        @mumblebaj Module stopped working you working on it?
                        • swvalentiS
                          swvalenti Project Sponsor @swvalenti
                          No errors just doesn’t show in region
                          mumblebajM S 2 Replies Last reply
                          • mumblebajM
                            @swvalenti I will have a look shortly. It is running just fine on my mirror. Will start another instance and see
                            • swvalentiS
                              sorry I meant to say MMM-News but also NewsAPI just shows gray line and News heading and nothing else
                              • mumblebajM
                                @swvalenti MMM-News can be cloned from the following repo:
                                MMM-News
                                I have made a change to MMM-NewsAPI which resolves CSS conflicts and it should now work when running MMM-News at the same time.
                                • swvalentiS
                                  @mumblebaj sent you a pm chat
                                    sdetweil @swvalenti
                                    @swvalenti if u look in the developers window, console tab, are there any errors?
                                    is the module listed in the sources list, and is the content in the elements tab, but maybe marked display:none?
                                    • swvalentiS
                                      swvalenti Project Sponsor @sdetweil
                                      @sdetweil I got it all squared away thanks Sam!
                                        mwm341
                                        Will MMM-NewsAPI allow displaying full articles in an iFrame?
                                          mwm341 @mwm341
                                          @mwm341 said in MMM-NewsAPI:
                                          Maybe an answer:
                                          Gonna try splicing template.html into a responsive iFrame.
                                          Wish me luck!
                                          • mumblebajM
                                            mumblebaj Module Developer @mwm341
                                            @mwm341 It is not setup for that at the moment but, you are more than welcome to make a PR. :winking_face:
                                            • 1 / 6
