    MMM-NewsAPI
    103 Posts 10 Posters 90.3k Views 8 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @swvalenti
      @swvalenti You can clone the module from here:
      MMM-News
      The config should still work.
      swvalentiS 1 Reply Last reply Reply Quote 0
      • swvalentiS Offline
        swvalenti Project Sponsor @mumblebaj
        @mumblebaj gave yours a try but get this error?
        MMM-NewsAPI.js:129 Uncaught TypeError: Cannot read property 'sourceId' of undefined
            at Class.draw (MMM-NewsAPI.js:129)
            at Class.socketNotificationReceived (MMM-NewsAPI.js:96)
            at module.js:245
            at Socket.<anonymous> (socketclient.js:38)
            at Socket../node_modules/component-emitter/index.js.Emitter.emit (index.js:145)
            at Socket.emit (typed-events.js:46)
            at Socket.emitEvent (socket.js:263)
            at Socket.onevent (socket.js:250)
            at Socket.MMSocket.socket.onevent (socketclient.js:32)
            at Socket.onpacket (socket.js:214)
        Config
                        module: "MMM-NewsAPI",
                        header: "news",
                        position: "bottom_bar",
                                apiKey: "super duper secret",
                                type: "horizontal",
                                choice: "headlines",
                                pageSize: 9,
                                className: "NEWS",
                                drawInterval: 1000*30,
                                templateFile: "template.html",
                                fetchInterval: 1000*60*60,
                                query: {
                                        country: "us",
                                        //category: "",
                                        //q: "covid",
                                        //qInTitle: "",
                                        sources: "Fox News",
                                        domains: "foxnews.com",
                                        //excludeDomains: "",
                                        language: "en"
          @swvalenti said in MMM-NewsAPI:
          The issue is with sources “Fox News”. That is not a valid source. Remove it and it should work fine with just the domain of foxnews.com
            @mumblebaj said in MMM-NewsAPI:
            Understood, works great now. Nice module good job!!!
            bugsounetB 1 Reply Last reply Reply Quote 0
            • bugsounetB Offline
              bugsounet Banned @swvalenti
              @mumblebaj, perfect, that i see Transfert is now done ;)
              Happy coding,
              @bugsounet
                mumblebaj Module Developer @bugsounet
                @bugsounet Thank you. I have received.
                  @mumblebaj Module stopped working you working on it?
                    swvalenti Project Sponsor @swvalenti
                    No errors just doesn’t show in region
                    mumblebajM S 2 Replies Last reply Reply Quote 0
                      @swvalenti I will have a look shortly. It is running just fine on my mirror. Will start another instance and see
                        sorry I meant to say MMM-News but also NewsAPI just shows gray line and News heading and nothing else
                          @swvalenti MMM-News can be cloned from the following repo:
                          MMM-News
                          I have made a change to MMM-NewsAPI which resolves CSS conflicts and it should now work when running MMM-News at the same time.
                            @mumblebaj sent you a pm chat
                              sdetweil @swvalenti
                              @swvalenti if u look in the developers window, console tab, are there any errors?
                              is the module listed in the sources list, and is the content in the elements tab, but maybe marked display:none?
                                swvalenti Project Sponsor @sdetweil
                                @sdetweil I got it all squared away thanks Sam!
                                  mwm341
                                  Will MMM-NewsAPI allow displaying full articles in an iFrame?
                                    mwm341 @mwm341
                                    @mwm341 said in MMM-NewsAPI:
                                    Maybe an answer:
                                    Gonna try splicing template.html into a responsive iFrame.
                                    Wish me luck!
                                      mumblebaj Module Developer @mwm341
                                      @mwm341 It is not setup for that at the moment but, you are more than welcome to make a PR. :winking_face:
                                        mumblebaj Module Developer @mumblebaj
                                        The following updates have been made to the module. Please feel free to do a git pull and then an npm install in the module directory.
                                        • Removed the request module and replaced with node-fetch due to request being deprecated.
                                        • Update to the config.js. You have to remove the following line from you config.js.
                                        className: "News"
                                        • The CSS has been changed to avoid conflicts with other modules. Hence the above className is no longer required and must be removed from the config.js.
                                        • MZ-BERM Offline
                                          MZ-BER
                                          Hey there - thanks for offering this module (NewsAPI). It works so far really well.
                                          But I noticed that the module doesn’t refresh the news as I am forcing it based on my config.
                                          The fetchInterval: is set to 1800*1000 // 30 minutes, but I still receive news that are 5 days old.
                                          Only if I restart the MM (npm start) it is pulling the recent news.
                                          And as you can see in the screenshot below, the NewsAPI doesn’t receive requests, as I’m actually expecting all 30min.
                                            mumblebaj Module Developer @MZ-BER
                                            @mz-ber Hi. I just had a look and mine is running fine and has the latest articles. Can you set debug: true in the config to see if it pulls new articles or if an error is returned? I have not run my mirror the past few days due to power issues hence my stats are low but I have been running it all day today and will check back on the stats. Let me know if you see anything in debug mode please.
                                            MZ-BERM 1 Reply Last reply Reply Quote 0
                                            • 2 / 6
