    MMM-NewsAPI
    103 Posts 10 Posters 90.3k Views 8 Watching
    • swvalentiS Offline
      swvalenti Project Sponsor @mumblebaj
      @mumblebaj said in MMM-NewsAPI:
      @swvalenti said in MMM-NewsAPI:
      The issue is with sources “Fox News”. That is not a valid source. Remove it and it should work fine with just the domain of foxnews.com
      Understood, works great now. Nice module good job!!!
      bugsounetB 1 Reply Last reply Reply Quote 0
      • bugsounetB Offline
        bugsounet Banned @swvalenti
        @mumblebaj, perfect, that i see Transfert is now done ;)
        Happy coding,
        @bugsounet
        • mumblebajM Offline
          mumblebaj Module Developer @bugsounet
          @bugsounet Thank you. I have received.
          swvalentiS 1 Reply Last reply Reply Quote 0
            @mumblebaj Module stopped working you working on it?
              swvalenti Project Sponsor @swvalenti
              No errors just doesn’t show in region
              mumblebajM S 2 Replies Last reply Reply Quote 0
                mumblebaj Module Developer @swvalenti
                @swvalenti I will have a look shortly. It is running just fine on my mirror. Will start another instance and see
                  sorry I meant to say MMM-News but also NewsAPI just shows gray line and News heading and nothing else
                    @swvalenti MMM-News can be cloned from the following repo:
                    MMM-News
                    I have made a change to MMM-NewsAPI which resolves CSS conflicts and it should now work when running MMM-News at the same time.
                      @mumblebaj sent you a pm chat
                        sdetweil @swvalenti
                        @swvalenti if u look in the developers window, console tab, are there any errors?
                        is the module listed in the sources list, and is the content in the elements tab, but maybe marked display:none?
                          swvalenti Project Sponsor @sdetweil
                          @sdetweil I got it all squared away thanks Sam!
                            mwm341
                            Will MMM-NewsAPI allow displaying full articles in an iFrame?
                              mwm341 @mwm341
                              @mwm341 said in MMM-NewsAPI:
                              Maybe an answer:
                              Gonna try splicing template.html into a responsive iFrame.
                              Wish me luck!
                                mumblebaj Module Developer @mwm341
                                @mwm341 It is not setup for that at the moment but, you are more than welcome to make a PR. :winking_face:
                                  mumblebaj Module Developer @mumblebaj
                                  The following updates have been made to the module. Please feel free to do a git pull and then an npm install in the module directory.
                                  • Removed the request module and replaced with node-fetch due to request being deprecated.
                                  • Update to the config.js. You have to remove the following line from you config.js.
                                  className: "News"
                                  • The CSS has been changed to avoid conflicts with other modules. Hence the above className is no longer required and must be removed from the config.js.
                                  • MZ-BERM Offline
                                    MZ-BER
                                    Hey there - thanks for offering this module (NewsAPI). It works so far really well.
                                    But I noticed that the module doesn’t refresh the news as I am forcing it based on my config.
                                    The fetchInterval: is set to 1800*1000 // 30 minutes, but I still receive news that are 5 days old.
                                    Only if I restart the MM (npm start) it is pulling the recent news.
                                    And as you can see in the screenshot below, the NewsAPI doesn’t receive requests, as I’m actually expecting all 30min.
                                      mumblebaj Module Developer @MZ-BER
                                      @mz-ber Hi. I just had a look and mine is running fine and has the latest articles. Can you set debug: true in the config to see if it pulls new articles or if an error is returned? I have not run my mirror the past few days due to power issues hence my stats are low but I have been running it all day today and will check back on the stats. Let me know if you see anything in debug mode please.
                                      MZ-BERM 1 Reply Last reply Reply Quote 0
                                      • MZ-BERM Offline
                                        MZ-BER @mumblebaj
                                        Thanks for getting back. I set debug: true in the config and it is indeed pulling recent articles.
                                          @mz-ber Thanks for the confirmation. Can you lave the debug running and check if it pulls new data when it refresh?
                                          • MZ-BERM Offline
                                            MZ-BER @mumblebaj
                                            Hello @mumblebaj :waving_hand:
                                            Would it be possible if you have a look? Thank you very much in advance :-)
                                            pi@raspberrypi:~/Dashboard/MagicMirror $ npm start
                                            > magicmirror@2.17.1 start
                                            [11.11.2021 09:35.56.157] [LOG]   Starting MagicMirror: v2.17.1
                                            [11.11.2021 09:35.56.164] [LOG]   Loading config ...
                                            [11.11.2021 09:35.56.170] [LOG]   Loading module helpers ...
                                            [11.11.2021 09:35.56.544] [LOG]   Initializing new module helper ...
                                            [11.11.2021 09:35.56.545] [LOG]   Module helper loaded: MMM-Wallpaper
                                            [11.11.2021 09:35.56.548] [LOG]   No helper found for module: clock.
                                            [11.11.2021 09:35.56.551] [LOG]   No helper found for module: MMM-CountDown.
                                            [11.11.2021 09:35.56.633] [LOG]   Initializing new module helper ...
                                            [11.11.2021 09:35.56.635] [LOG]   Module helper loaded: MMM-OpenWeatherForecast
                                            [11.11.2021 09:35.57.072] [LOG]   Initializing new module helper ...
                                            [11.11.2021 09:35.57.073] [LOG]   Module helper loaded: MMM-MyCalendar
                                            [11.11.2021 09:35.57.155] [LOG]   Initializing new module helper ...
                                            [11.11.2021 09:35.57.156] [LOG]   Module helper loaded: MMM-NINA
                                            [11.11.2021 09:35.57.623] [LOG]   Initializing new module helper ...
                                            [11.11.2021 09:35.57.624] [LOG]   Module helper loaded: MMM-PublicTransportBerlin
                                            [11.11.2021 09:35.57.715] [LOG]   Initializing new module helper ...
                                            [11.11.2021 09:35.57.716] [LOG]   Module helper loaded: MMM-Fuel
                                            [11.11.2021 09:35.58.018] [LOG]   Initializing new module helper ...
                                            [11.11.2021 09:35.58.018] [LOG]   Module helper loaded: MMM-Todoist
                                            [11.11.2021 09:35.58.400] [LOG]   Initializing new module helper ...
                                            [11.11.2021 09:35.58.401] [LOG]   Module helper loaded: MMM-NowPlayingOnSpotify
                                            [11.11.2021 09:35.58.404] [LOG]   Initializing new module helper ...
                                            [11.11.2021 09:35.58.404] [LOG]   Module helper loaded: MMM-GoogleSheets
                                            [11.11.2021 09:35.58.427] [LOG]   Initializing new module helper ...
                                            [11.11.2021 09:35.58.428] [LOG]   Module helper loaded: MMM-NewsAPI
                                            [11.11.2021 09:35.58.429] [LOG]   No helper found for module: alert.
                                            [11.11.2021 09:35.58.450] [LOG]   Initializing new module helper ...
                                            [11.11.2021 09:35.58.451] [LOG]   Module helper loaded: updatenotification
                                            [11.11.2021 09:35.58.638] [LOG]   Initializing new module helper ...
                                            [11.11.2021 09:35.58.638] [LOG]   Module helper loaded: MMM-Remote-Control
                                            [11.11.2021 09:35.58.639] [LOG]   All module helpers loaded.
                                            [11.11.2021 09:35.58.729] [LOG]   Starting server on port 8080 ...
                                            [11.11.2021 09:35.58.735] [WARN]  You're using a full whitelist configuration to allow for all IPs
                                            [11.11.2021 09:35.58.742] [LOG]   Server started ...
                                            [11.11.2021 09:35.58.743] [LOG]   Connecting socket for: MMM-Wallpaper
                                            [11.11.2021 09:35.58.744] [LOG]   Starting node helper for: MMM-Wallpaper
                                            [11.11.2021 09:35.58.748] [LOG]   Connecting socket for: MMM-OpenWeatherForecast
                                            [11.11.2021 09:35.58.749] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherForecast]
                                            [11.11.2021 09:35.58.749] [LOG]   Connecting socket for: MMM-MyCalendar
                                            [11.11.2021 09:35.58.750] [LOG]   Starting node helper for: MMM-MyCalendar
                                            [11.11.2021 09:35.58.751] [LOG]   Connecting socket for: MMM-NINA
                                            [11.11.2021 09:35.58.751] [LOG]   MMM-NINA helper method started...
                                            [11.11.2021 09:35.58.752] [LOG]   Connecting socket for: MMM-PublicTransportBerlin
                                            [11.11.2021 09:35.58.753] [LOG]   Connecting socket for: MMM-Fuel
                                            [11.11.2021 09:35.58.753] [LOG]   Starting module helper: MMM-Fuel
                                            [11.11.2021 09:35.58.754] [LOG]   Connecting socket for: MMM-Todoist
                                            [11.11.2021 09:35.58.755] [LOG]   Starting node helper for: MMM-Todoist
                                            [11.11.2021 09:35.58.755] [LOG]   Connecting socket for: MMM-NowPlayingOnSpotify
                                            [11.11.2021 09:35.58.756] [LOG]   Connecting socket for: MMM-GoogleSheets
                                            [11.11.2021 09:35.58.757] [LOG]   ====================== Starting node_helper for module [MMM-GoogleSheets]
                                            [11.11.2021 09:35.58.757] [LOG]   Connecting socket for: MMM-NewsAPI
                                            [11.11.2021 09:35.58.758] [LOG]   Starting node_helper for module: MMM-NewsAPI
                                            [11.11.2021 09:35.58.759] [LOG]   Connecting socket for: updatenotification
                                            [11.11.2021 09:35.58.760] [LOG]   Connecting socket for: MMM-Remote-Control
                                            [11.11.2021 09:35.58.761] [LOG]   Starting node helper for: MMM-Remote-Control
                                            [11.11.2021 09:35.58.841] [LOG]   Sockets connected & modules started ...
                                            [11.11.2021 09:35.59.134] [LOG]   Launching application.
                                            [11.11.2021 09:35.59.972] [ERROR] ERROR! Could not validate main module js file.
                                            [11.11.2021 09:35.59.975] [ERROR] ReferenceError: Log is not defined
                                                at Object.<anonymous> (/home/pi/Dashboard/MagicMirror/modules/MMM-NINA/MMM-NINA.js:14:1229)
                                                at Module._compile (internal/modules/cjs/loader.js:1078:30)
                                                at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10)
                                                at Module.load (internal/modules/cjs/loader.js:935:32)
                                                at Module._load (internal/modules/cjs/loader.js:776:14)
                                                at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
                                                at Module.require (internal/modules/cjs/loader.js:959:19)
                                                at require (internal/modules/cjs/helpers.js:88:18)
                                                at Class.loadModuleDefaultConfig (/home/pi/Dashboard/MagicMirror/modules/MMM-Remote-Control/node_helper.js:313:30)
                                                at /home/pi/Dashboard/MagicMirror/modules/MMM-Remote-Control/node_helper.js:267:26
                                            [11.11.2021 09:36.00.032] [ERROR] ERROR! Could not find main module js file for MMM-NINA2
                                            [11.11.2021 09:36.03.598] [LOG]   Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/sXXXXX.ics - Interval: 300000
                                            [11.11.2021 09:36.03.663] [LOG]   [MMM-NEWSAPI] Invalid Option specified. Country not allowed with 'everything'!
                                            [11.11.2021 09:36.03.665] [LOG]   everything callscript:  https://newsapi.org/v2/everything?domains=berliner-zeitung.de%2Cmorgenpost.de%2Ctagesschau.de&pageSize=3&apiKey=XXXXXXX
                                            [11.11.2021 09:36.03.678] [INFO]  Checking git for module: default
                                            [11.11.2021 09:36.03.716] [INFO]  Checking git for module: MMM-Wallpaper
                                            [11.11.2021 09:36.03.757] [INFO]  Checking git for module: MMM-CountDown
                                            [11.11.2021 09:36.03.794] [INFO]  Checking git for module: MMM-OpenWeatherForecast
                                            [11.11.2021 09:36.03.828] [INFO]  Checking git for module: MMM-MyCalendar
                                            [11.11.2021 09:36.03.858] [INFO]  Checking git for module: MMM-NINA
                                            [11.11.2021 09:36.03.899] [INFO]  Checking git for module: MMM-PublicTransportBerlin
                                            [11.11.2021 09:36.03.939] [INFO]  Checking git for module: MMM-Fuel
                                            [11.11.2021 09:36.03.980] [INFO]  Checking git for module: MMM-Todoist
                                            [11.11.2021 09:36.04.023] [INFO]  Checking git for module: MMM-NowPlayingOnSpotify
                                            [11.11.2021 09:36.04.058] [INFO]  Checking git for module: MMM-GoogleSheets
                                            [11.11.2021 09:36.04.097] [INFO]  Checking git for module: MMM-NewsAPI
                                            [11.11.2021 09:36.04.127] [INFO]  Checking git for module: MMM-Remote-Control
                                            [11.11.2021 09:36.04.171] [ERROR] (node:3286) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                                            (Use `electron --trace-deprecation ...` to show where the warning was created)
                                            [11.11.2021 09:36.05.079] [LOG]   Refreshed access token because it has expired. Expired at: 09:36:03 now is: 09:36:05
                                            [11.11.2021 09:36.05.089] [LOG]   Refreshed access token because it has expired. Expired at: 10:36:05 now is: 09:36:05
                                            [11.11.2021 09:36.05.162] [LOG]   response received:  {"status":"ok","totalResults":7435,"articles":[{"source":{"id":null,"name":"Berliner Morgenpost"},"author":"dpa","title":"Gewerkschaften: Beschäftigte an Kitas und Schulen sind im Warnstreik","description":"Zahlreiche Beschäftigte an Kitas und Schulen in Berlin haben am Donnerstagmorgen einen ganztägigen Warnstreik begonnen. Dazu aufgerufen hatte die Gewerkschaft...","url":"https://www.morgenpost.de/berlin/article233810097/Beschaeftigte-an-Kitas-und-Schulen-sind-im-Warnstreik.html","urlToImage":"https://img.morgenpost.de/img/incoming/crop233810095/400260911-w820-cv16_9-q85/Warnstreik-steht-auf-einem-Schild.jpg","publishedAt":"2021-11-11T08:06:57Z","content":"Berlin. Zahlreiche Beschäftigte an Kitas und Schulen in Berlin haben am Donnerstagmorgen einen ganztägigen Warnstreik begonnen. Dazu aufgerufen hatte die Gewerkschaft Erziehung und Wissenschaft (GEW)… [+1166 chars]"},{"source":{"id":null,"name":"tagesschau.de"},"author":"tagesschau","title":"Belarus: Tausende Geflüchtete warten weiter auf Hilfe","description":"Sie haben eine weitere Nacht bei eisigen Temperaturen in provisorischen Camps verbracht: An der belarusisch-polnischen Grenze harren weiter Tausende Flüchtlinge aus. Bislang ist keine Hilfe für sie in Sicht.","url":"https://www.tagesschau.de/ausland/europa/belarus-polen-migranten-103.html","urlToImage":"https://www.tagesschau.de/multimedia/bilder/belarus-gefluechtete-101~_v-original.jpg","publishedAt":"2021-11-11T07:56:59Z","content":"Sie haben eine weitere Nacht bei eisigen Temperaturen in provisorischen Camps verbracht: An der belarusisch-polnischen Grenze harren weiter Tausende Flüchtlinge aus. Bislang ist keine Hilfe für sie i… [+3150 chars]"},{"source":{"id":null,"name":"tagesschau.de"},"author":"tagesschau","title":"Nach Ausfällen: 110 und 112 vielerorts wieder erreichbar","description":"Die großflächigen Störungen bei den Notrufnummern 110 und 112 sind in vielen Regionen wieder behoben. Die Ursache für den Ausfall werde derzeit noch untersucht, teilte das Bundesamt für Bevölkerungsschutz und Katastrophenhilfe mit.","url":"https://www.tagesschau.de/inland/notruf-ausfall-103.html","urlToImage":"https://www.tagesschau.de/multimedia/bilder/polizei-255~_v-original.jpg","publishedAt":"2021-11-11T07:46:58Z","content":"Die großflächigen Störungen bei den Notrufnummern 110 und 112 sind in vielen Regionen wieder behoben. Die Ursache für den Ausfall werde derzeit noch untersucht, teilte das Bundesamt für Bevölkerungss… [+1871 chars]"}]}
                                            [11.11.2021 09:36.05.277] [LOG]   sending articles:  [{"source":{"id":null,"name":"Berliner Morgenpost"},"author":"dpa","title":"Gewerkschaften: Beschäftigte an Kitas und Schulen sind im Warnstreik","description":"Zahlreiche Beschäftigte an Kitas und Schulen in Berlin haben am Donnerstagmorgen einen ganztägigen Warnstreik begonnen. Dazu aufgerufen hatte die Gewerkschaft...","url":"https://www.morgenpost.de/berlin/article233810097/Beschaeftigte-an-Kitas-und-Schulen-sind-im-Warnstreik.html","urlToImage":"https://img.morgenpost.de/img/incoming/crop233810095/400260911-w820-cv16_9-q85/Warnstreik-steht-auf-einem-Schild.jpg","publishedAt":"29 minutes ago","content":"Berlin. Zahlreiche Beschäftigte an Kitas und Schulen in Berlin haben am Donnerstagmorgen einen ganztägigen Warnstreik begonnen. Dazu aufgerufen hatte die Gewerkschaft Erziehung und Wissenschaft (GEW)… [+1166 chars]","sourceName":"Berliner Morgenpost"},{"source":{"id":null,"name":"tagesschau.de"},"author":"tagesschau","title":"Belarus: Tausende Geflüchtete warten weiter auf Hilfe","description":"Sie haben eine weitere Nacht bei eisigen Temperaturen in provisorischen Camps verbracht: An der belarusisch-polnischen Grenze harren weiter Tausende Flüchtlinge aus. Bislang ist keine Hilfe für sie in Sicht.","url":"https://www.tagesschau.de/ausland/europa/belarus-polen-migranten-103.html","urlToImage":"https://www.tagesschau.de/multimedia/bilder/belarus-gefluechtete-101~_v-original.jpg","publishedAt":"39 minutes ago","content":"Sie haben eine weitere Nacht bei eisigen Temperaturen in provisorischen Camps verbracht: An der belarusisch-polnischen Grenze harren weiter Tausende Flüchtlinge aus. Bislang ist keine Hilfe für sie i… [+3150 chars]","sourceName":"tagesschau.de"},{"source":{"id":null,"name":"tagesschau.de"},"author":"tagesschau","title":"Nach Ausfällen: 110 und 112 vielerorts wieder erreichbar","description":"Die großflächigen Störungen bei den Notrufnummern 110 und 112 sind in vielen Regionen wieder behoben. Die Ursache für den Ausfall werde derzeit noch untersucht, teilte das Bundesamt für Bevölkerungsschutz und Katastrophenhilfe mit.","url":"https://www.tagesschau.de/inland/notruf-ausfall-103.html","urlToImage":"https://www.tagesschau.de/multimedia/bilder/polizei-255~_v-original.jpg","publishedAt":"49 minutes ago","content":"Die großflächigen Störungen bei den Notrufnummern 110 und 112 sind in vielen Regionen wieder behoben. Die Ursache für den Ausfall werde derzeit noch untersucht, teilte das Bundesamt für Bevölkerungss… [+1871 chars]","sourceName":"tagesschau.de"}]
                                            [11.11.2021 09:36.06.497] [LOG]   Refreshed access token because it has expired. Expired at: 10:36:05 now is: 09:36:06
                                            [11.11.2021 09:36.07.033] [LOG]   Created transportation fetcher for station Albertinenstr. (toward all directions). (Station ID: 900000140005, Direction ID: undefined)
                                            [11.11.2021 10:36.07.407] [LOG]   Refreshed access token because it has expired. Expired at: 10:36:06 now is: 10:36:07
                                            [11.11.2021 11:36.08.386] [LOG]   Refreshed access token because it has expired. Expired at: 11:36:07 now is: 11:36:08
                                            [11.11.2021 12:36.09.138] [LOG]   Refreshed access token because it has expired. Expired at: 12:36:08 now is: 12:36:09
                                            [11.11.2021 13:36.10.367] [LOG]   Refreshed access token because it has expired. Expired at: 13:36:09 now is: 13:36:10
                                            [11.11.2021 14:36.11.153] [LOG]   Refreshed access token because it has expired. Expired at: 14:36:10 now is: 14:36:11
                                            [11.11.2021 14:54.36.340] [ERROR] Can’t retrieve current song. Reason:
                                            [11.11.2021 14:54.36.350] [ERROR] RequestError: Error: Client network socket disconnected before secure TLS connection was established
                                                at new RequestError (/home/pi/Dashboard/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request-promise-core/lib/errors.js:14:15)
                                                at Request.plumbing.callback (/home/pi/Dashboard/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request-promise-core/lib/plumbing.js:87:29)
                                                at Request.RP$callback [as _callback] (/home/pi/Dashboard/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request-promise-core/lib/plumbing.js:46:31)
                                                at self.callback (/home/pi/Dashboard/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request/request.js:185:22)
                                                at Request.emit (events.js:315:20)
                                                at Request.onRequestError (/home/pi/Dashboard/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request/request.js:877:8)
                                                at ClientRequest.emit (events.js:315:20)
                                                at TLSSocket.socketErrorListener (_http_client.js:469:9)
                                                at TLSSocket.emit (events.js:315:20)
                                                at emitErrorNT (internal/streams/destroy.js:106:8) {
                                              cause: Error: Client network socket disconnected before secure TLS connection was established
                                                  at connResetException (internal/errors.js:607:14)
                                                  at TLSSocket.onConnectEnd (_tls_wrap.js:1544:19)
                                                  at TLSSocket.emit (events.js:327:22)
                                                  at endReadableNT (internal/streams/readable.js:1327:12)
                                                  at processTicksAndRejections (internal/process/task_queues.js:80:21) {
                                                code: 'ECONNRESET',
                                                path: null,
                                                host: 'api.spotify.com',
                                                port: 443,
                                                localAddress: undefined
                                              error: Error: Client network socket disconnected before secure TLS connection was established
                                                code: 'ECONNRESET',
                                                path: null,
                                                port: 443,
                                              options: {
                                                url: 'https://api.spotify.com/v1/me/player',
                                                headers: {
                                                  Authorization: 'XXXXX'
                                                json: true,
                                                method: 'GET',
                                                callback: [Function: RP$callback],
                                                transform: undefined,
                                                simple: true,
                                                resolveWithFullResponse: false,
                                                transform2xxOnly: false
                                              response: undefined
                                            [11.11.2021 15:36.12.131] [LOG]   Refreshed access token because it has expired. Expired at: 15:36:11 now is: 15:36:12
                                            [11.11.2021 16:24.43.352] [LOG]   Shutting down server...
                                            [11.11.2021 16:24.43.358] [LOG]   Stopping module helper: MMM-Wallpaper
                                            [11.11.2021 16:24.43.359] [LOG]   Stopping module helper: MMM-OpenWeatherForecast
                                            [11.11.2021 16:24.43.360] [LOG]   Stopping module helper: MMM-MyCalendar
                                            [11.11.2021 16:24.43.361] [LOG]   Stopping module helper: MMM-NINA
                                            [11.11.2021 16:24.43.361] [LOG]   Stopping module helper: MMM-PublicTransportBerlin
                                            [11.11.2021 16:24.43.363] [LOG]   Stopping module helper: MMM-Fuel
                                            [11.11.2021 16:24.43.364] [LOG]   Stopping module helper: MMM-Todoist
                                            [11.11.2021 16:24.43.365] [LOG]   Stopping module helper: MMM-NowPlayingOnSpotify
                                            [11.11.2021 16:24.43.368] [LOG]   Stopping module helper: MMM-GoogleSheets
                                            [11.11.2021 16:24.43.370] [LOG]   Stopping module helper: MMM-NewsAPI
                                            [11.11.2021 16:24.43.377] [LOG]   Stopping module helper: updatenotification
                                            • 2 / 6
