    MMM-EARTH-Live & MMM-ISS-Live
    Scheduled Pinned Locked Moved Education
    47 Posts 13 Posters 31.7k Views 14 Watching
      runny
      Currently I struggle with a problem that already seems to be know but I somehow can not fix it. MMM-EARTH-LIVE is not autoplaying for me.
      I have already tried adding :
      app.commandLine.appendSwitch(‘autoplay-policy’, ‘no-user-gesture-required’); //< -------- added
      to the recommended place in MagicMirror/js/electron.js but without any results. Further I have tried to update to the latest version of the electron browser with “npm install electron@latest” but that has also not helped me with the autoplay problem.
      Is there further thins that I can try or any possibility that I did something wrong above?
      Thanks for any help!
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @runny
        @runny
        I also had some issues with the autostart but upgrading my electron seems to have fixed the issue with both modules. As long and you followed the “workaround” directions in the readme. it should work.
        Please try letting the modules run and see if they eventually start. I have seen this behavior. It may have to do with the feed being blacked out for periods of time at the source.
        So, please verify the workaround was done and that you are running the newest electron. My electron is at 11.3.
        Peace!
          ruskythegreat
          Can anyone help please, I can’t get the feed to autoplay with Electron 15.3.0 even after adding the following
          This is how the line looks in electron.js
          function createWindow() {
          let electronSwitchesDefaults = [“autoplay-policy”, “no-user-gesture-required”];
          app.commandLine.appendSwitch(…new Set(electronSwitchesDefaults, config.electronSwitches));
          let electronOptionsDefaults = {
            sdetweil @ruskythegreat
            @ruskythegreat autoplay is now part of the webPreferences config
            https://www.electronjs.org/docs/latest/api/browser-window
            but, I have heard others say this setting also doesn’t work
            (I did the change request to set it as it is now)
            also, your electron should be 13.5.1 (on MM version 2.17.1)
            R 1 Reply Last reply
              ruskythegreat @sdetweil
              @sdetweil I did run npm install electron@latest but yes, I am running MM 2.17.1
                @ruskythegreat we haven’t tested above 13.5.1
                  @sdetweil I just downgraded to 13.5.1 but still no auto play.
                    @ruskythegreat i understand… did u try to change the code to the new webPreferences object parm?
                    in general they are stopping autoplay because customers are screaming at them (I hate it too in general purpose use)…
                      @sdetweil No, Sorry, I’m not familiar with the webPreferences object param Can I trouble you to ELI5 :)
                        @ruskythegreat there is already a WebPreferences object in the electron.js file, just down a few lines from your change.
                        line 30
                        look at the doc link for autoplay, to get the right syntax/spelling
                        and add the key and value to the WebPreferences object
                          @sdetweil Thanks for all your help with this.
                          It’s still not autoplaying :(
                          I tried with the autoplayPolicy with the no-user-gesture-required so: -
                          autoplayPolicy: no-user-gesture-required,
                          C&P to eliminate typos!
                          So now the whole webpreferences entry reads: -
                                      webPreferences: {
                                              contextIsolation: true,
                                              nodeIntegration: false,
                                              zoomFactor: config.zoom
                          But MM doesn’t start!
                            @ruskythegreat that string needs quotes
                            in JavaScript
                            the thing to the left of : does not need quotes
                            if the thing to the right is a number or true/false
                            no quotes
                            if the thing to the right is a symbol { or [ no quotes
                            otherwise
                            if it contains letters, it needs quotes.
                            single or double does matter as long as they are the same on both ends
                              Sorry, I did try that but forgot to update the post!
                              It currently reads: -
                              autoplayPolicy: “no-user-gesture-required”
                              But still doesn’t autoplay
                                @ruskythegreat yes, I mentioned that others had found the same issue…
                                try this one thing, (I don’t think it will help but)
                                clear the Electron config folder, will be recreated on next electron startup
                                (zoom setting is saved here somewhere)
                                stop MagicMirror
                                rm .rf ~/.config/Electron
                                start MagicMirror
                                  @sdetweil No change ;(
                                    @ruskythegreat yes, and the doc says it defaults
                                     Defaults to no-user-gesture-required.
                                    it would be interesting if you used chromium instead , if your config says
                                    address:"0.0.0.0",
                                    then try from any other system
                                    http://pi_address:MM_port
                                      ruskythegreat
                                      @sdetweil It doesn’t work from Chrome 95.0.4638.54
                                        @ruskythegreat boooooo
                                        • 2 / 3
