    MMM-EARTH-Live & MMM-ISS-Live
    Scheduled Pinned Locked Moved Education
    47 Posts 13 Posters 31.7k Views 14 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Egnos
      @Egnos said in MMM-EARTH-Live & MMM-ISS-Live:
      Do I have to enable the mouse pointer or do I have to be on t the module?
      I used the mouse to click the close box on the message windows
      E 1 Reply Last reply
      • E
        Egnos @Mykle1
        @Mykle1
        The problem is in the location of the form.
        If the module is positioned in the “upper_third” region it is not possible to interact with the mouse.
        To close the message I had to:
        • temporarily change the position to the MM-Earth Live module,
        • close the message,
        • and finally reposition it in its original position.
        Now it’s okay.
        Could you also check if it is not possible to interact with the module in the “upper_third” region?
        Thanks.
        Mykle1M 1 Reply Last reply
        • Mykle1M
          I moved mine to the upper third position (both modules) and they both respond to mouse clicks
            Peter Leemon
            Hi all I have just installed this module on my MM and when I run it I have the following message on the screen “Your browser is out of date” how do i update this?
            Cheers
            Pete.
            S Mykle1M 2 Replies Last reply
              sdetweil @Peter Leemon
              @Peter-Leemon what type hardware are u running on? pi 0?
              on one system here *pi 0" I got ‘could not update chrome’ but there was a button
              normally one would apply updates
              open a terminal or ssh window , do
              sudo apt-get update
              sudo apt-get upgrade
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @Peter Leemon
                @Peter-Leemon
                In the meantime, if you have the ability to click the close box that is also present, you can close the message and the module will work as expected until you restart MM again. That message does not always reappear after restart but it can.
                  Peter Leemon
                  Thank you all yes I did that got it working now its showing a red screen?
                  • Mykle1M
                    @Peter-Leemon
                    The module is showing red or the entire MM?
                      Peter Leemon
                      was weird just he Module then after about 6 hours and a few reboots came good however the live feed on my mac was perfect atm its working fine, must have been a gremlin lol
                        runny
                        Currently I struggle with a problem that already seems to be know but I somehow can not fix it. MMM-EARTH-LIVE is not autoplaying for me.
                        I have already tried adding :
                        app.commandLine.appendSwitch(‘autoplay-policy’, ‘no-user-gesture-required’); //< -------- added
                        to the recommended place in MagicMirror/js/electron.js but without any results. Further I have tried to update to the latest version of the electron browser with “npm install electron@latest” but that has also not helped me with the autoplay problem.
                        Is there further thins that I can try or any possibility that I did something wrong above?
                        Thanks for any help!
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @runny
                          @runny
                          I also had some issues with the autostart but upgrading my electron seems to have fixed the issue with both modules. As long and you followed the “workaround” directions in the readme. it should work.
                          Please try letting the modules run and see if they eventually start. I have seen this behavior. It may have to do with the feed being blacked out for periods of time at the source.
                          So, please verify the workaround was done and that you are running the newest electron. My electron is at 11.3.
                          Peace!
                            ruskythegreat
                            Can anyone help please, I can’t get the feed to autoplay with Electron 15.3.0 even after adding the following
                            This is how the line looks in electron.js
                            function createWindow() {
                            let electronSwitchesDefaults = [“autoplay-policy”, “no-user-gesture-required”];
                            app.commandLine.appendSwitch(…new Set(electronSwitchesDefaults, config.electronSwitches));
                            let electronOptionsDefaults = {
                              sdetweil @ruskythegreat
                              @ruskythegreat autoplay is now part of the webPreferences config
                              https://www.electronjs.org/docs/latest/api/browser-window
                              but, I have heard others say this setting also doesn’t work
                              (I did the change request to set it as it is now)
                              also, your electron should be 13.5.1 (on MM version 2.17.1)
                              R 1 Reply Last reply
                                ruskythegreat @sdetweil
                                @sdetweil I did run npm install electron@latest but yes, I am running MM 2.17.1
                                  @ruskythegreat we haven’t tested above 13.5.1
                                    @sdetweil I just downgraded to 13.5.1 but still no auto play.
                                      @ruskythegreat i understand… did u try to change the code to the new webPreferences object parm?
                                      in general they are stopping autoplay because customers are screaming at them (I hate it too in general purpose use)…
                                        @sdetweil No, Sorry, I’m not familiar with the webPreferences object param Can I trouble you to ELI5 :)
                                          @ruskythegreat there is already a WebPreferences object in the electron.js file, just down a few lines from your change.
                                          line 30
                                          look at the doc link for autoplay, to get the right syntax/spelling
                                          and add the key and value to the WebPreferences object
                                            @sdetweil Thanks for all your help with this.
                                            It’s still not autoplaying :(
                                            I tried with the autoplayPolicy with the no-user-gesture-required so: -
                                            autoplayPolicy: no-user-gesture-required,
                                            C&P to eliminate typos!
                                            So now the whole webpreferences entry reads: -
                                                        webPreferences: {
        contextIsolation: true,
        nodeIntegration: false,
        zoomFactor: config.zoom
                                            But MM doesn’t start!
                                            • 2 / 3
