    MMM-EARTH-Live & MMM-ISS-Live
    Scheduled Pinned Locked Moved Education
    47 Posts 13 Posters 29.5k Views 14 Watching
      starting with one of the newer electron builds, (and chrome, and mozilla) they have implemented a new ’ no autoplay’ policy.
      they require a user to click on the web page somewhere to enable autoplay…
      there is a workaround
      edit mm/js/electron.js
      and change the code like this
      function createWindow() {
          app.commandLine.appendSwitch('autoplay-policy', 'no-user-gesture-required');  //< -------- added
          var electronOptionsDefaults = {
      then restart MM… autoplay will work now
      • T Offline
        TamP
        Thanks for that, It does as you say and starts without the playbutton
          @sdetweil said in MMM-EARTH-Live & MMM-ISS-Live:
          I did not know this. Thank you, Sam. :thumbsup:
          • F Offline
            fulmik Project Sponsor
            I’ll be checking this out after work today, thank you
            • V Offline
              Vauxdvihl
              @Mykle1
              hi Mykle1
              Thanks for this great module
              I am receiving the following message:
              Do you have an idea?
              Thanks a lot
              Best Regards
              • rudibaraniR Offline
                rudibarani Project Sponsor
                Hi @Vauxdvihl,
                I had the same problem with another module. You can find what worked for me here: https://forum.magicmirror.builders/topic/11185/electron-browser-outdated
                Good luck!
                  sdetweil @rudibarani
                  @rudibarani i submitted a change request to upgrade to 6.0.12 on the next update
                  • E Offline
                    Egnos
                    Hi @Mykle1,
                    After lunartic I also installed these two modules: MMM-ISS Live and MMM-Earth Live. I’m your fan …:grinning_face_with_smiling_eyes:
                    I have the problem mentioned by @Vauxdvihl and @rudibarani, but for the ISS Live module I was able to close the message with the mouse, for the Earth Live module it is not possible … the pointer has no effect!
                    Could you help me?
                    2020-04-02-162749-1920x1080-scrot
                    fotoonline
                    Thanks for your interesting modules.
                    @Mykle1 PS: do you like my “Astronomy” page? :smiling_face_with_open_mouth_cold_sweat:
                      Mykle1 Project Sponsor Module Developer @Egnos
                      @Egnos said in MMM-EARTH-Live & MMM-ISS-Live:
                      I do. I like all things related to the cosmos. :thumbsup:
                      I just loaded up both modules and was able to close both warning messages. The modules are both working as expected, as you can see from the screenshot. Can you please try again?
                      • E Offline
                        Egnos @Mykle1
                        @Mykle1 said in MMM-EARTH-Live & MMM-ISS-Live:
                        Do I have to enable the mouse pointer or do I have to be on t the module?
                          I used the mouse to click the close box on the message windows
                          • E Offline
                            Egnos @Mykle1
                            @Mykle1
                            The problem is in the location of the form.
                            If the module is positioned in the “upper_third” region it is not possible to interact with the mouse.
                            To close the message I had to:
                            • temporarily change the position to the MM-Earth Live module,
                            • close the message,
                            • and finally reposition it in its original position.
                            Now it’s okay.
                            Could you also check if it is not possible to interact with the module in the “upper_third” region?
                            Thanks.
                              I moved mine to the upper third position (both modules) and they both respond to mouse clicks
                                Peter Leemon
                                Hi all I have just installed this module on my MM and when I run it I have the following message on the screen “Your browser is out of date” how do i update this?
                                Cheers
                                Pete.
                                S Mykle1M 2 Replies Last reply Reply Quote 0
                                  sdetweil @Peter Leemon
                                  @Peter-Leemon what type hardware are u running on? pi 0?
                                  on one system here *pi 0" I got ‘could not update chrome’ but there was a button
                                  normally one would apply updates
                                  open a terminal or ssh window , do
                                  sudo apt-get update
                                  sudo apt-get upgrade
                                    Mykle1 Project Sponsor Module Developer @Peter Leemon
                                    @Peter-Leemon
                                    In the meantime, if you have the ability to click the close box that is also present, you can close the message and the module will work as expected until you restart MM again. That message does not always reappear after restart but it can.
                                      Peter Leemon
                                      Thank you all yes I did that got it working now its showing a red screen?
                                        @Peter-Leemon
                                        The module is showing red or the entire MM?
                                          Peter Leemon
                                          was weird just he Module then after about 6 hours and a few reboots came good however the live feed on my mac was perfect atm its working fine, must have been a gremlin lol
                                            runny
                                            Currently I struggle with a problem that already seems to be know but I somehow can not fix it. MMM-EARTH-LIVE is not autoplaying for me.
                                            I have already tried adding :
                                            app.commandLine.appendSwitch(‘autoplay-policy’, ‘no-user-gesture-required’); //< -------- added
                                            to the recommended place in MagicMirror/js/electron.js but without any results. Further I have tried to update to the latest version of the electron browser with “npm install electron@latest” but that has also not helped me with the autoplay problem.
                                            Is there further thins that I can try or any possibility that I did something wrong above?
                                            Thanks for any help!
