    MMM-EARTH-Live & MMM-ISS-Live
    Scheduled Pinned Locked Moved Education
    47 Posts 13 Posters 31.1k Views 14 Watching
    • T
      TamP
      When my MagicMirror starts, the ISS module appears, but I have to click a play button on it, to start the app. Is this as should be, or is there a way to get the live stream, when the mirror starts without any interaction.
      Great module though
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @TamP
        @TamP said in MMM-EARTH-Live & MMM-ISS-Live:
        Great module though
        It absolutely should start without clicking a play button. When did you clone the repo? My initial upload to the repo required you to click a play button but a later upload/update included the fix for that.
        Have you modified anything?
        Line 38 of the MMM-ISS-Live.js file should look like this:
        iframe.src="https://www.ustream.tv/embed/9408562?html5ui?autoplay=1";
        If it does not you should do a git pull in the MMM-ISS-Live directory
        • T
          TamP @Mykle1
          @Mykle1 line 38 is correct but I did a git pull anyway but to no avail
            starting with one of the newer electron builds, (and chrome, and mozilla) they have implemented a new ’ no autoplay’ policy.
            they require a user to click on the web page somewhere to enable autoplay…
            there is a workaround
            edit mm/js/electron.js
            and change the code like this
            function createWindow() {
                app.commandLine.appendSwitch('autoplay-policy', 'no-user-gesture-required');  //< -------- added
                var electronOptionsDefaults = {
            then restart MM… autoplay will work now
            • T
              TamP
              Thanks for that, It does as you say and starts without the playbutton
              • Mykle1M
                @sdetweil said in MMM-EARTH-Live & MMM-ISS-Live:
                I did not know this. Thank you, Sam. :thumbsup:
                • F
                  fulmik Project Sponsor
                  I’ll be checking this out after work today, thank you
                  • V
                    Vauxdvihl
                    @Mykle1
                    hi Mykle1
                    Thanks for this great module
                    I am receiving the following message:
                    Do you have an idea?
                    Thanks a lot
                    Best Regards
                    • rudibaraniR
                      rudibarani Project Sponsor
                      Hi @Vauxdvihl,
                      I had the same problem with another module. You can find what worked for me here: https://forum.magicmirror.builders/topic/11185/electron-browser-outdated
                      Good luck!
                        sdetweil @rudibarani
                        @rudibarani i submitted a change request to upgrade to 6.0.12 on the next update
                        • E
                          Egnos
                          Hi @Mykle1,
                          After lunartic I also installed these two modules: MMM-ISS Live and MMM-Earth Live. I’m your fan …:grinning_face_with_smiling_eyes:
                          I have the problem mentioned by @Vauxdvihl and @rudibarani, but for the ISS Live module I was able to close the message with the mouse, for the Earth Live module it is not possible … the pointer has no effect!
                          Could you help me?
                          2020-04-02-162749-1920x1080-scrot
                          fotoonline
                          Thanks for your interesting modules.
                          @Mykle1 PS: do you like my “Astronomy” page? :smiling_face_with_open_mouth_cold_sweat:
                          • Mykle1M
                            Mykle1 Project Sponsor Module Developer @Egnos
                            @Egnos said in MMM-EARTH-Live & MMM-ISS-Live:
                            I do. I like all things related to the cosmos. :thumbsup:
                            I just loaded up both modules and was able to close both warning messages. The modules are both working as expected, as you can see from the screenshot. Can you please try again?
                            • E
                              Egnos @Mykle1
                              @Mykle1 said in MMM-EARTH-Live & MMM-ISS-Live:
                              Do I have to enable the mouse pointer or do I have to be on t the module?
                              • Mykle1M
                                I used the mouse to click the close box on the message windows
                                • E
                                  Egnos @Mykle1
                                  @Mykle1
                                  The problem is in the location of the form.
                                  If the module is positioned in the “upper_third” region it is not possible to interact with the mouse.
                                  To close the message I had to:
                                  • temporarily change the position to the MM-Earth Live module,
                                  • close the message,
                                  • and finally reposition it in its original position.
                                  Now it’s okay.
                                  Could you also check if it is not possible to interact with the module in the “upper_third” region?
                                  Thanks.
                                  • Mykle1M
                                    I moved mine to the upper third position (both modules) and they both respond to mouse clicks
                                      Peter Leemon
                                      Hi all I have just installed this module on my MM and when I run it I have the following message on the screen “Your browser is out of date” how do i update this?
                                      Cheers
                                      Pete.
                                      S Mykle1M 2 Replies Last reply Reply Quote 0
                                        sdetweil @Peter Leemon
                                        @Peter-Leemon what type hardware are u running on? pi 0?
                                        on one system here *pi 0" I got ‘could not update chrome’ but there was a button
                                        normally one would apply updates
                                        open a terminal or ssh window , do
                                        sudo apt-get update
                                        sudo apt-get upgrade
                                        • Mykle1M
                                          Mykle1 Project Sponsor Module Developer @Peter Leemon
                                          @Peter-Leemon
                                          In the meantime, if you have the ability to click the close box that is also present, you can close the message and the module will work as expected until you restart MM again. That message does not always reappear after restart but it can.
                                            Peter Leemon
                                            Thank you all yes I did that got it working now its showing a red screen?
