    [MMM-GmailFeed] - Simple Gmail unread messages list/notification
    20 Posts 14 Posters 9.8k Views 15 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Plainbroke 0
      @Plainbroke-0 said in [MMM-GmailFeed] - Simple Gmail unread messages list/notification:
      is there a way to make the font Bigger on the header or just get rid of it.
      In your custom.css file
      To modify the header font
      .MMM-GmailFeed .module-header {
        color: yellow;
        text-align: center;
        font-size: 28px;
      To make the header “underline” go away
        border-bottom: none;
        Plainbroke 0
        Mykle1
        Thank you so much I spent probably 3 hrs trying to find it on my own…
        The only way I can learn this stuff.
        Mykle1M 1 Reply Last reply
        • Mykle1M
          @Plainbroke-0
          Been there, my friend. Don’t sweat it. It takes time but it is rewarding. :thumbsup:
          • L
            Lagmin
            I am getting: Error: [null].
            I’m 100% sure my email and password are correct. Do you know what can be the problem, please?
            Arek
            B 1 Reply Last reply
              RhodanBull
              I got the same error and are searching for a solution
              • E
                eyebee
                I think it is to do with Google’s security settings. See if you got an email saying you had a blocked access attempt. You can change the settings under ‘security’ to allow less secure apps though it is not recommended.
                On the github it says you can set up an app specific password, again look under security settings in your google account, you need two factor authentication on…
                  bdf @Lagmin
                  @Lagmin , as the boss explain : “Your gmail password. If you are using 2 factor auth, you’ll need to generate a unique “App Password”. Go to your google account settings page, look in the “security” section on the left menu. You should find where to add an App Password there.” For me i’m not using 2 factor auth and i have the “null” message and have to allow less security App, maybe it 's the http and not https. I hope it will work for you.
                    bdf @shaneapowell
                    @shaneapowell, Thanks a lot, work great.
                      shaneapowell
                      Hey Guys… sorry I’ve not been in here to respond to questions. My MagicMirror has been working so well… I totally forgot about this thread. :) I updated the Readme on the github with a brief explination of how to work with Google 2FA. Hope that helps future users.
                      • A
                        aarish
                        After updating MM to the latest version, every time I have Gmailfeed in the config I get this error when I launch MM.
                        [22.12.2021 18:26.44.188] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'request'
                        Require stack:
                        - /home/pi/MagicMirror/modules/MMM-GmailFeed/node_helper.js
                        and …
                        Require stack:
                            at Module._resolveFilename (internal/modules/cjs/loader.js:887:15)
                            at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128)
                            at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                            at Module._load (internal/modules/cjs/loader.js:732:27)
                            at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
                            at Module.require (internal/modules/cjs/loader.js:959:19)
                            at require (internal/modules/cjs/helpers.js:88:18)
                            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-GmailFeed/node_helper.js:2:15)
                            at Module._compile (internal/modules/cjs/loader.js:1078:30)
                            at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10)
                        [22.12.2021 18:26.44.219] [ERROR] Whoops! There was an uncaught exception...
                        [22.12.2021 18:26.44.225] [ERROR] Error: Cannot find module 'request'
                        Require stack:
                            at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10) {
                          code: 'MODULE_NOT_FOUND',
                          requireStack: [
                            '/home/pi/MagicMirror/modules/MMM-GmailFeed/node_helper.js',
                            '/home/pi/MagicMirror/js/app.js',
                            '/home/pi/MagicMirror/js/electron.js',
                            '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                            undefined
                        Any ideas on how to fix this?
                        S J 2 Replies Last reply
                          sdetweil @aarish
                          @aarish see
                          plainbrokeP 1 Reply Last reply
                            Jo4K @aarish
                            @aarish said in [MMM-GmailFeed] - Simple Gmail unread messages list/notification:
                            Cannot find module ‘request’
                            Ecrite noire sur blanc l’erreur : Cannot find module ‘request’
                            -> Faut juste installer le module demandé (request)
                            “npm install request” et le tour est joué
                            • plainbrokeP
                              plainbroke @sdetweil
                              @sdetweil said in [MMM-GmailFeed] - Simple Gmail unread messages list/notification:
                              @aarish see
                              Sam,
                              This did not work for me I could not find anywhere it showed which dependency
                              my MM needed to run the GmailFeed, but A nice person pointed out to me to run
                              npm install request in the MagicMirror/modules directory. Reinstalled the MMM-GmailFeed and then ran the npm install request in the modules directory and it WORKS again. Thank you to Kristjan ESPERANTO!
                                sdetweil @plainbroke
                                @plainbroke module install instructions
                                git clone https://github.com/shaneapowell/MMM-GmailFeed.git
                                cd MMM-GmailFeed
                                npm install
                                the GitHub page is the README.MD file
                                also, if the module has a package.json you need to npm install ( in the new module folder), even if they don’t say so
                                  Ray
                                  I am having an unusual problem with it. It is preventing Googleassistant from bugsounet from loading
                                  I tested this 3 times by disabling the update and another one disabling the module and finally I reinstalled the previous version and everything worked perfectly, so I don’t understand what’s going on here
                                    DarrenHill
                                    Also just came across a clash between GmailFeed and both MMM-News and MMM-NewsAPI.
                                    Seems my GmailFeed was a little out of date as a git pull updated stuff there and now they are playing nicely together. Must be something quite recent though as I’m sure I did a full mirror update not so long ago…?
                                    • plainbrokeP
                                      cd MMM-GmailFeed
                                      npm install
                                      I did all the npm install and it still did not work until I did the “npm install request” in the MagicMirror/modules folder, that alone fixed almost all my install issues… Could hardly believe something so simple fixed so much… And yes I have been running npm install in all my modules folders just to be safe. That pm2 restart mm && pm2 log lines=50 ( i think that is correct) really made life easier… Thanks to all whom helped with my issue…
                                        @plainbroke said in [MMM-GmailFeed] - Simple Gmail unread messages list/notification:
                                        this is because the author didn’t record request being used in his package.json, cause it ‘worked’ without it…, because MM supplied it…
                                        but MM removed it because the library has been discontinued) (deprecate) and is exposed the security issues.
                                        oops… module didn’t declare, and its not there anymore… boom
