    [MMM-GmailFeed] - Simple Gmail unread messages list/notification
    20 Posts 14 Posters 8.1k Views 15 Watching
      Mykle1 Project Sponsor Module Developer @Plainbroke 0
      @Plainbroke-0
      Been there, my friend. Don’t sweat it. It takes time but it is rewarding. :thumbsup:
      • L Offline
        Lagmin
        I am getting: Error: [null].
        I’m 100% sure my email and password are correct. Do you know what can be the problem, please?
        Arek
          RhodanBull
          I got the same error and are searching for a solution
          • E Offline
            eyebee
            I think it is to do with Google’s security settings. See if you got an email saying you had a blocked access attempt. You can change the settings under ‘security’ to allow less secure apps though it is not recommended.
            On the github it says you can set up an app specific password, again look under security settings in your google account, you need two factor authentication on…
              bdf @Lagmin
              @Lagmin , as the boss explain : “Your gmail password. If you are using 2 factor auth, you’ll need to generate a unique “App Password”. Go to your google account settings page, look in the “security” section on the left menu. You should find where to add an App Password there.” For me i’m not using 2 factor auth and i have the “null” message and have to allow less security App, maybe it 's the http and not https. I hope it will work for you.
                bdf @shaneapowell
                @shaneapowell, Thanks a lot, work great.
                  shaneapowell
                  Hey Guys… sorry I’ve not been in here to respond to questions. My MagicMirror has been working so well… I totally forgot about this thread. :) I updated the Readme on the github with a brief explination of how to work with Google 2FA. Hope that helps future users.
                    aarish
                    After updating MM to the latest version, every time I have Gmailfeed in the config I get this error when I launch MM.
                    [22.12.2021 18:26.44.188] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'request'
                    Require stack:
                    - /home/pi/MagicMirror/modules/MMM-GmailFeed/node_helper.js
                    and …
                    Require stack:
                        at Module._resolveFilename (internal/modules/cjs/loader.js:887:15)
                        at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128)
                        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                        at Module._load (internal/modules/cjs/loader.js:732:27)
                        at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
                        at Module.require (internal/modules/cjs/loader.js:959:19)
                        at require (internal/modules/cjs/helpers.js:88:18)
                        at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-GmailFeed/node_helper.js:2:15)
                        at Module._compile (internal/modules/cjs/loader.js:1078:30)
                        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10)
                    [22.12.2021 18:26.44.219] [ERROR] Whoops! There was an uncaught exception...
                    [22.12.2021 18:26.44.225] [ERROR] Error: Cannot find module 'request'
                    Require stack:
                        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10) {
                      code: 'MODULE_NOT_FOUND',
                      requireStack: [
                        '/home/pi/MagicMirror/modules/MMM-GmailFeed/node_helper.js',
                        '/home/pi/MagicMirror/js/app.js',
                        '/home/pi/MagicMirror/js/electron.js',
                        '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                        undefined
                    Any ideas on how to fix this?
                    S J 2 Replies Last reply Reply Quote 0
                      sdetweil @aarish
                      @aarish see
                        Jo4K @aarish
                        @aarish said in [MMM-GmailFeed] - Simple Gmail unread messages list/notification:
                        Cannot find module ‘request’
                        Ecrite noire sur blanc l’erreur : Cannot find module ‘request’
                        -> Faut juste installer le module demandé (request)
                        “npm install request” et le tour est joué
