    My Bathroom Mirror
    16 Posts 12 Posters 9.6k Views 16 Watching
    • O Offline
      OberfragGER
      Last year i decided to start the project.
      Now its finished. Maybe some extra modules but …its finished.
      The goal was i big mirror in the bathroom. It should look like a regular mirror an no PIR e.g. in sight and the outer frame should not be visible. It also should have background lights as well! So lets start.
      I build a new frame, completly by myself. I did some woodwork in my workshop.!
      IMG_5982.jpeg 108B81E9-DB34-45FD-9F70-8B1574064145.jpg 9F1F81FE-F74D-4158-9302-3700D424211A.jpg
      I createt with the saw a bevel to fit the LED-Stripe. I also have some experience with Hyperion… so i tought… okay… its anice idea to use the leftover LEDs for this project (in the end… i had 3 LEDs over ;), 1872 pieces mountet).
      Here you see the old mirror which was there for some time (i had this always in my mind). And do you see the Alexa? I didnt want to see Alexa anymore but want to hera the music.
      To mount it i decided to use a french cleat. Pretty easy to build, install and very reliable.
      I didnt have nice Wifi… so i decided a few week ago to make some hole in the wall and install a LAN-cable and also a wall plug.
      Then go for the paint jobs. I tried different things. Paintbrush, paint roll and spray can. With the brush and roller i had a lot of blobs in the surface, so i used the spray can. Not perfect… i want that glossy surface. But as an amateur- its okay. The color is RAL 7016. Same color like the closet.
      I mounted a plywood in it an cut the monitor out. You already see the hanger from the french cleat an the monitor - 27" QHD! On top of the plywood i placed black paperboard.
      First of all i brought for the mirror the Mirastar Chrome Spy. I was very brown and dark, so i brought an extra one from the forum from @Goldjunge_Chriz . Its okay…but still a bit dark.
      Lets see the cables and stuff. Here is the nearly finished version. The cables für the LED-stripes are o the top.IMG_9417A.jpeg
      After a time testing with the MagicMirror Alexa i realized that it pretty hard to get the microfone in a good quality and als that its no longer possible to stream music to non Alexa-devices. So i 3Dprinted a mounting for the Echo Dot 3.
      The are 2 PSU- One 12V (the white one) for the Echo Dot to have a slim fit in back and also a 5V for the LED stripe and the Raspberry Pi4. I also added a StepUp converter to have stable 5v for the RPI to prevent errors. You also see the PIR-Sensor case. Created and 3D printed by myself.
      I also created a smal bracket to hold the RPI in place. But noch back-picture yet.
      I use the following modules with very small customisations:
      Tada! Here is the mirror:
      Now to hyperion and smart home:
      I also have an ioBroker instace with MQTT. I installed behind the regular double switch in the bathroom a Shelly in detached mode. So i get the information when the switch is pressed. The other switch is for the regular light. So i can switch the mirror on/of (MMM-Remote-Control) with the switch…and also the backlight goes on/off with a small effect.
      When the PIR is starting -> MQTT-Message -> Knight rider effect starts for 10 Seconds. Just for fun and because its possible ;)
      Last but not least- when motion in the camera is detected- the videostream from MMM-Motioneye is displayed automatically for 1 minute (when i brush my teeth… i see before when the doorbell rings.
      I hope you like it. Feel free to ask.
      N6NGN D FoziF 3 Replies Last reply Reply Quote 8
      • N6NGN Offline
        N6NG @OberfragGER
        @oberfragger I think it looks great… nice job… well done…
        • Z Offline
          Zoltan
          Nice, looks good
          • kusselinK Offline
            kusselin
            Hi, can you put here the config from your mmm-pages please.
            StoffbeuteluweS O 2 Replies Last reply Reply Quote 0
            • StoffbeuteluweS Offline
              Stoffbeuteluwe Project Sponsor @kusselin
              Hi does the Globe update …for me the module does not update automatically only when I restart the mirror .
              • L Offline
                lxne Project Sponsor
                Pretty cool.
                I am working on a similar bath mirror project and will definitely test some of the modules you are using.
                Maybe for some inspiration here are the modules I am currently using besides clock, calendar and newsfeed:
                MMM-pages
                MMM-UpdateNotification
                MMM-TelegramBot
                MMM-Volume
                MMM-Tools
                MMM-Detector
                MMM-GoogleAssistant
                MMM-DWD-WarnWeather
                MMM-MplayerRadio
                MMM-DarkSkyForecast
                MMM-DWD-Pollen
                MMM-bergfex
                MMM-GroveGestures
                • O Offline
                  OberfragGER @kusselin
                  @kusselin sure. My MMM_page config:
                        module: 'MMM-pages',
                        disabled: false,
                              'newsfeed',
                              'MMM-OpenWeatherForecast',
                              'calendar',
                              'calendar_monthly',
                              'MMM-WiFiPassword'
                              'compliments',
                              'MMM-Globe',
                              'MMM-DWD-Pollen',
                              'MMM-DWD-WarnWeather',
                              'MMM-WeatherChart',
                              'MMM-OpenmapWeather',
                  			'MMM-SystemStats',
                              'weatherforecast',
                          fixed: [
                            'updatenotification',
                            'MMM-page-indicator',
                            'alert',
                            'clock',
                            'MMM-MotionEye',
                  		  'MMM-GoogleBirthdaysProvider',
                  		  'MMM-NewPIR',
                  		  'MMM-UserPresenceToMQTT',
                            'MMM-Remote-Control'
                          animationTime: 2500,
                          rotationTime: 60000
                  @Stoffbeuteluwe Yes. It updates. But i use pages do i have a refresh every 2 minutes. Maybe thats the key
                    DigiDadbod @OberfragGER
                    @oberfragger nice. So can you read everything when it gets fogged up?
                    • O Offline
                      OberfragGER @DigiDadbod
                      @digidadbod We dont have any fog inside the bathroom. Only the window gets foggy sometimes.
                      The bathroom is always warm enoug and so the mirror too. We have floor heating. Maybei thats why…
                      • FoziF Offline
                        Fozi Project Sponsor @OberfragGER
                        @oberfragger Congrats to your wonderful built! It’s very impressive how much effort you put into that! Wished I had knew a few years earlier about MM…that would have saved me lots of discussion with my better half about which mirror should have been installed in our new bathroom. :grinning_face_with_sweat:
                        • bigschucksB Offline
                          bigschucks
                          Just a stunning mirror. Genuinely emotional over how brilliant this looks. I really like it and can try to do the same.
                            sil3ntstorm
                            at the top right, is that one weather module or two? And what are these called exactly? Could you post the config entry here?
                            • lavolp3L Offline
                              lavolp3 Module Developer @sil3ntstorm
                              @sil3ntstorm That should be MMM-OpenWeatherForecast
                              https://github.com/jclarke0000/MMM-OpenWeatherForecast
                              How to troubleshoot modules
                              MMM-soccer v2, MMM-AVStock
                              O 1 Reply Last reply Reply Quote 1
                              • O Offline
                                OberfragGER @lavolp3
                                @lavolp3 Youre right!
                                • BerkSmash1984B Offline
                                  BerkSmash1984
                                  BerkSmash1984B 1 Reply Last reply Reply Quote 0
                                    BerkSmash1984 @BerkSmash1984
