Solved updated installer script available for testing
@swvalenti this is not an update, it is a NEW install…
so you have to copy from the old mm folder to the new…
if u wanted to UPDATE then u should run the UPDATE script
https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
@sdetweil Well I am an idiot, so I can just delete the new MagicMirror folder and then run the update in the other?
@swvalenti yes… UPDATE just gets you the new MagicMirror version. currently 2.9.0
Thanks Sam
Huh. I just tried it on a fresh Buster install on a RPI 3B+ and PM2 failed to install correctly. It seems to be a permissions issue.
@bhepler show me the log please
~/install.log
It’s not terribly illuminating.
install and setup pm2 pm2 not installed, installing pm2 install result get the pm2 platform specific startup command startup command = pm2 startup command done configure the pm2 config file for MagicMirror start MagicMirror via pm2 now save MagicMirror pm2 config now disable screensaver via lxsession
@sdetweil I already went through the installation procedure to get pm2 installed. That required the npm command to install pm2.
After the initial script run,
pm2 start MagicMirror
returned a “bash: pm2: command not found” error. Once I got pm2 installed, getting the script monitored by pm2 was easy enough. At a guess, it’s a problem with using sudo to install pm2, but I’m afraid I don’t have the exact error message. -
@bhepler what did u have to do for the pm2 install?
