    updated installer script available for testing
    211 Posts 18 Posters 311.3k Views 19 Watching
      @sdetweil this installer script is now the script in 2.10…
      I will close/lock this topic in a couple days
        jorgnyg
        Should I install electron with --arch=armv7l ?
          jorgnyg @jorgnyg
          @jorgnyg Yea guess so. Installation fails on rpi zero. So I deleted the electron folder from node_modules, and ran npm install --arch=armv7l electron@3.0.13
            sdetweil @jorgnyg
            @jorgnyg doesn’t fail on my pi 0.
            Can u send me the install.log
            S J 2 Replies Last reply Reply Quote 0
              @sdetweil note that we made electron optional. There is no armv6l at node 10
              So we will run in split mode use chromium
                jorgnyg @sdetweil
                @sdetweil sure thing. Guess this is the most relevant error
                26380 verbose stack Error: electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
                26380 verbose stack Exit status 1
                26380 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                26380 verbose stack     at EventEmitter.emit (events.js:198:13)
                26380 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                26380 verbose stack     at ChildProcess.emit (events.js:198:13)
                26380 verbose stack     at maybeClose (internal/child_process.js:982:16)
                26380 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                26381 verbose pkgid electron-chromedriver@1.8.0
                26382 verbose cwd /home/pi/MagicMirror
                26383 verbose Linux 4.19.75+
                26384 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install"
                26385 verbose node v10.18.1
                26386 verbose npm  v6.13.4
                26387 error code ELIFECYCLE
                26388 error errno 1
                26389 error electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
                26389 error Exit status 1
                26390 error Failed at the electron-chromedriver@1.8.0 install script.
                26390 error This is probably not a problem with npm. There is likely additional logging output above.
                26391 verbose exit [ 1, true ]
                  sdetweil @jorgnyg
                  @jorgnyg the run-start.sh script now handles this problem and launches chromium instead of electron to connect to mm in serveronly mode
                    jorgnyg @sdetweil
                    @sdetweil got it!
                      jthirasilpa
                      Hi - firstly thanks for putting together this installer!
                      I am running Raspbian on RP3b+ as a fresh install using the command
                      curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh | bash
                      Installer indicated successful install of MagicMirror.
                      Using SSH DISPLAY=:0 npm start gives the following error:
                      magicmirror@2.10.1 start /home/jojo/MagicMirror
                      ./run-start.sh
                      No protocol specified
                      (electron:17801): Gtk-WARNING **: 18:36:26.218: cannot open display: :0
                      npm ERR! code ELIFECYCLE
                      npm ERR! errno 1
                      npm ERR! magicmirror@2.10.1 start: ./run-start.sh
                      npm ERR! Exit status 1
                      npm ERR!
                      npm ERR! Failed at the magicmirror@2.10.1 start script.
                      npm ERR! /home/jojo/.npm/_logs/2020-01-25T18_36_26_308Z-debug.log
                      Debug log contents are as follows:
                      1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
                      2 info using npm@6.13.4
                      3 info using node@v10.18.1
                      4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                      5 info lifecycle magicmirror@2.10.1~prestart: magicmirror@2.10.1
                      6 info lifecycle magicmirror@2.10.1~start: magicmirror@2.10.1
                      7 verbose lifecycle magicmirror@2.10.1~start: unsafe-perm in lifecycle true
                      8 verbose lifecycle magicmirror@2.10.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/jojo/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                      9 verbose lifecycle magicmirror@2.10.1~start: CWD: /home/jojo/MagicMirror
                      10 silly lifecycle magicmirror@2.10.1~start: Args: [ ‘-c’, ‘./run-start.sh’ ]
                      11 silly lifecycle magicmirror@2.10.1~start: Returned: code: 1 signal: null
                      12 info lifecycle magicmirror@2.10.1~start: Failed to exec start script
                      13 verbose stack Error: magicmirror@2.10.1 start: ./run-start.sh
                      13 verbose stack Exit status 1
                      13 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                      13 verbose stack at EventEmitter.emit (events.js:198:13)
                      13 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                      13 verbose stack at ChildProcess.emit (events.js:198:13)
                      13 verbose stack at maybeClose (internal/child_process.js:982:16)
                      13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                      14 verbose pkgid magicmirror@2.10.1
                      15 verbose cwd /home/jojo/MagicMirror
                      16 verbose Linux 4.19.75-v7+
                      17 verbose argv “/usr/bin/node” “/usr/bin/npm” “start”
                      18 verbose node v10.18.1
                      19 verbose npm v6.13.4
                      20 error code ELIFECYCLE
                      21 error errno 1
                      22 error magicmirror@2.10.1 start: ./run-start.sh
                      22 error Exit status 1
                      23 error Failed at the magicmirror@2.10.1 start script.
                      23 error This is probably not a problem with npm. There is likely additional logging output above.
                      24 verbose exit [ 1, true ]
                      Any thoughts on how to troubleshoot? Many thanks.
                        sdetweil @jthirasilpa
                        @jthirasilpa seems like you are running in console mode, instead of graphical mode.
                        Mm requires the full desktop.
                          jthirasilpa @sdetweil
                          @sdetweil Thanks. The RP is running a full desktop - if I run npm start directly from the RP, the debug log gives the following output:
                          21 error errno 1
                            @jthirasilpa change line 1 of run-start.sh to be
                            #~/bin/bash -x
                            then do the npm start again…
                            also do
                             which chromium-browser
                            my system returns
                            /usr/bin/chromium-browser
                            can u send me the MagicMirror/installers/upgrade.log via email
                            same userid as here, at gmail
                            thanks
                              @sdetweil sorry, typo on run-start
                              #!/bin/bash -x
                              • N Offline
                                Neebotol
                                Hello there!
                                Thank you for this script, it has worked better than the original one for me. But I still really unlucky and have an issue.
                                Here it is :
                                pi@raspberrypi:~ $ curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirr  or_scripts/master/raspberry.sh | bash
                                $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                          $$  __$$\
                                $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$  $\   $$$$$$\   $$$$$$\  \__/  $$ |
                                $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __  $$\ $$  __$$\ $$  __$$\  $$$$$$  |
                                $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |    \__|$$ /  $$ |$$ |  \__|$$  ____/
                                $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |        $$ |  $$ |$$ |      $$ |
                                $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |        \$$$$$$  |$$ |      $$$$$$$$\
                                \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|         \______/ \__|      \________|
                                                        \______/
                                install log being saved to /home/pi/install.log
                                Updating packages ...
                                Installing helper tools ...
                                Lecture des listes de paquets... Fait
                                Construction de l'arbre des dépendances
                                Lecture des informations d'état... Fait
                                build-essential est déjà la version la plus récente (12.6).
                                curl est déjà la version la plus récente (7.64.0-4).
                                unzip est déjà la version la plus récente (6.0-23+deb10u1).
                                wget est déjà la version la plus récente (1.20.1-1.1).
                                wget passé en « installé manuellement ».
                                Paquets suggérés :
                                  git-daemon-run | git-daemon-sysvinit git-doc git-el git-email git-gui gitk gitwe
                                Les paquets suivants seront mis à jour :
                                  git
                                1 mis à jour, 0 nouvellement installés, 0 à enlever et 166 non mis à jour.
                                Il est nécessaire de prendre 4 203 ko dans les archives.
                                Après cette opération, 33,8 ko d'espace disque supplémentaires seront utilisés.
                                Réception de :1 http://mirrors.ircam.fr/pub/raspbian/raspbian buster/main armhf gi
                                4 203 ko réceptionnés en 2s (2 281 ko/s)
                                apt-listchanges : Lecture des fichiers de modifications (« changelog »)...
                                (Lecture de la base de données... 93835 fichiers et répertoires déjà installés.)
                                Préparation du dépaquetage de .../git_1%3a2.20.1-2+deb10u1_armhf.deb ...
                                Dépaquetage de git (1:2.20.1-2+deb10u1) sur (1:2.20.1-2) ...
                                Paramétrage de git (1:2.20.1-2+deb10u1) ...
                                Check current Node installation ...
                                Node.js is not installed.
                                Installing Node.js ...
                                Warning: apt-key output should not be parsed (stdout is not a terminal)
                                Les NOUVEAUX paquets suivants seront installés :
                                  nodejs
                                0 mis à jour, 1 nouvellement installés, 0 à enlever et 166 non mis à jour.
                                Il est nécessaire de prendre 14,6 Mo dans les archives.
                                Après cette opération, 77,3 Mo d'espace disque supplémentaires seront utilisés.
                                Réception de :1 https://deb.nodesource.com/node_10.x buster/main armhf nodejs armhf 10.18.1-1nodesource1 [14,6 MB]
                                14,6 Mo réceptionnés en 11s (1 365 ko/s)
                                Sélection du paquet nodejs précédemment désélectionné.
                                (Lecture de la base de données... 93842 fichiers et répertoires déjà installés.)
                                Préparation du dépaquetage de .../nodejs_10.18.1-1nodesource1_armhf.deb ...
                                Dépaquetage de nodejs (10.18.1-1nodesource1) ...
                                Paramétrage de nodejs (10.18.1-1nodesource1) ...
                                Traitement des actions différées (« triggers ») pour man-db (2.8.5-2) ...
                                node version is
                                Node.js installation Done! version=v10.18.1
                                Check current NPM installation ...
                                NPM currently installed. Checking version number.
                                internal/modules/cjs/loader.js:638
                                    throw err;
                                Error: Cannot find module 'rimraf'
                                    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                                    at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                                    at Module.require (internal/modules/cjs/loader.js:692:17)
                                    at require (internal/modules/cjs/helpers.js:25:18)
                                    at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/fs-vacuum/vacuum.js:6:14)
                                    at Module._compile (internal/modules/cjs/loader.js:778:30)
                                    at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                                    at Module.load (internal/modules/cjs/loader.js:653:32)
                                    at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                    at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                                Minimum npm version: V6.0.0
                                Installed npm version: V
                                npm should be upgraded.
                                Installing npm ...
                                E: Impossible de corriger les problèmes, des paquets défectueux sont en mode « garder en l'état ».
                                    throw err;
                                    throw err;
                                npm installation Done! version=V
                                Cloning MagicMirror ...
                                Clonage dans 'MagicMirror'...
                                remote: Enumerating objects: 331, done.
                                remote: Counting objects: 100% (331/331), done.
                                remote: Compressing objects: 100% (295/295), done.
                                remote: Total 331 (delta 42), reused 193 (delta 23), pack-reused 0
                                Réception d'objets: 100% (331/331), 676.44 KiB | 1.57 MiB/s, fait.
                                Résolution des deltas: 100% (42/42), fait.
                                Cloning MagicMirror Done!
                                Installing dependencies ...
                                    throw err;
                                Any idea please? Honnestly I have spent so much time on this project, all my past weekend and some hours in the week. I tried many things, with several tutorials, raspian stretch, buster… I’m a little desperate, but I’m not giving up!
                                S Mykle1M 2 Replies Last reply Reply Quote 0
                                  sdetweil @Neebotol
                                  @Neebotol looks like npm is not able to run after the node upgrade…
                                  do this
                                  rm -rf MagicMirror
                                  npm clean cache
                                  then start the installer script again
                                    Mykle1 Project Sponsor Module Developer @Neebotol
                                    @Neebotol said in updated installer script available for testing:
                                    We’ve all been there.
                                    :thumbsup:
                                      @sdetweil Thanks for your help in getting my installation sorted out Sam.
                                      • N Offline
                                        Neebotol @Mykle1
                                        @Mykle1 said in updated installer script available for testing:
                                        :thumbsup:
                                        Yep! :handshake:
                                          sdetweil @Neebotol
                                          @Neebotol is MM working ok now?
                                          • N Offline
                                            Neebotol @sdetweil
                                            @sdetweil Hello! thank you for the way you’re helping people in this project.
                                            I just solved the problem tonight after more than 20 hours on it! It was really stupid, I used another SD card and it just worked. (I don’t understand too much because the SD card I was using until now was of good quality)
                                            Have a good day!
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 9 / 11
