    Distance between two modules
    9 Posts 5 Posters 3.8k Views 4 Watching
    • P Offline
      Peter
      After trying several hours I have to ask for help.
      NOAA3 on the right side of the new mirror I am making, was not aligned to the right.
      So I changed custom css to change that.
      But now the header of the next module (Football Leagues) is too high (mixed with the text of NOAA).
      And I would like to have some space between these two modules.
      How can I change this?
      I hope I am clear enough!
      Peter
        motdog @Peter
        @Peter is location bottom right?
        • P Offline
          Peter
          Both are top_right.
          Peter
            Mykle1 Project Sponsor Module Developer @Peter
            @Peter
            Try this in custom.css:
            .MMM-SportsModuleName {
              margin-top: 50px;
            Adjust accordingly
            • P Offline
              Peter
              Unfortunately it did not work, Mykle.
              I tried values from 10-150.
              The only thing that happened was that Noaa3 and Football Leagues both were placed lower but still the header of Football Leagues is mixed up with the text of Noaa3.
              Peter
                Maybe the other way around works…
                .MMM-NOAA3 {
                margin-bottom: 50px;
                Can you post your custom.css? Maybe it interferes with this in some way.
                  @Peter
                  I assume you changed the name of the module in the example I gave you?
                  .MMM-SportsModuleName needs to be changed to the sports module name that you are using
                  • P Offline
                    Peter
                    @retroflex: this partely solved my problem: there is an extra empty line between the modules now: good thing.
                    But the headers are still mixed up: bad thing, I think I just remove the header.
                    @Mykle: sure I changed the name !!!
                    • brobergB Offline
                      broberg Project Sponsor @Peter
                      @Peter We need to see your custom.css if we will have any chance at all to help you.
