    MMM-EasyBack no autostart Video
    35 Posts 4 Posters 20.4k Views 4 Watching
    • D
      Darkmx-6 @sdetweil
      I am trying a clean install now
      • D
        Darkmx-6 @sdetweil
        is this the start file you are talking about?
        pi@raspberrypi:~ $ ls
        chromium_start.sh  mmstart.sh                  package-lock.json
        MagicMirror        node-v10.16.0-linux-armv6l
        pi@raspberrypi:~ $
        mmstart.sh?
        pi@raspberrypi:~ $ sudo nano mmstart.sh
          GNU nano 3.2                       mmstart.sh
        #!/bin/bash
        cd ~/MagicMirror
        node serveronly &
        sleep 30
        xinit /home/pi/chromium_start.sh
        npm start dev
        Is that where it goes?
        Man doing this project makes me feel so dumb I need to learn more, any suggestions?
        • D
          Darkmx-6
          Oh an just to update with the clean install I had the same issue.
          • D
            Darkmx-6
            I am also now using a Raspberry Pi 3 B+
            • D
              Darkmx-6
              Well I ended up going to a static picture because I can’t think of what else to do.
                sdetweil @Darkmx-6
                @Darkmx-6 i don’t know where mmstart.sh came from… it is not part of the base MagicMirror solution.
                the MagicMirror start script is ~/MagicMirror/installers/mm.sh
                it does not run serveronly… it assumes you are running the mirror user experience ON the same machine.
                i don’t know if EasyBack works on the remote client of serveronly… THAT browser would have to enable autoplay… our fix was for the electron browser running ON the same machine
                edit:
                ok, i see what you are doing… using chromium for the browser for some reason…
                so u have to disable the autoplay blocker there , from
                https://developers.google.com/web/updates/2017/09/autoplay-policy-changes
                You can decide to disable entirely the autoplay policy by setting the
                Chrome flag "Autoplay Policy" to "No user gesture is required" at chrome://flags/#autoplay-policy.
                This allows you to test your website as if user were strongly engaged with your site and playback autoplay would be always allowed.
                Reply Quote 2
                • D
                  Darkmx-6
                  Ah I see! It works THANK YOU!
                  Must be because of the pre-made image I installed MagicMirror with.
                  Here is the link:
                  http://emmanuelcontreras.com/how-to/how-to-create-a-magic-mirror-2-with-pi-zero-w/
                  Here is the fix:
                  I edited the file chromium_start.sh found here:
                  chromium_start.sh  MagicMirror  mmstart.sh  node-v10.16.0-linux-armv6l  package-lock.json
                  and added
                  --autoplay-policy=no-user-gesture-required
                  Example:
                    GNU nano 3.2                          chromium_start.sh
                  #!/bin/sh
                  unclutter &
                  xset -dpms # disable DPMS (Energy Star) features.
                  xset s off # disable screen saver
                  xset s noblank # don’t blank the video device
                  matchbox-window-manager &
                  #midori -e Fullscreen -a http://localhost:8080
                  chromium-browser --autoplay-policy=no-user-gesture-required --incognito --kiosk http://localhost:8080/
                  S Mykle1M 2 Replies Last reply
                  Reply Quote 1
                    sdetweil @Darkmx-6
                    @Darkmx-6 cool!.. great feedback, thanks we missed that this was a pi0, and that you were running split mode…
                    • D
                      Darkmx-6
                      @sdetweil said in MMM-EasyBack no autostart Video:
                      what is split mode? If I am I didn’t mean to, I have it directly connected to a TV that I am using as a Bulletin board.
                        sdetweil @Darkmx-6
                        @Darkmx-6 there are two ways to run Magic Mirror
                        all in one(all in one application) , uses electron, npm start.
                        we’ve solved the pi 0 problem… my installer handles it
                        split mode (two applications)
                        start serverOnly
                        then view with some other browser (chrome, firefox, ie, …) either locally or from another machine/phone…
                        Mykle1M 1 Reply Last reply
                        Reply Quote 1
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @Darkmx-6
                          @Darkmx-6 said in MMM-EasyBack no autostart Video:
                          Here is the fix:
                          I added your fix for Chromium to the readme. Many thanks, Mate. :thumbsup:
                          https://github.com/mykle1/MMM-EasyBack/blob/master/README.md
                          Reply Quote 1
                          • Mykle1M
                            And Sam, my thanks, again. :-)
                            D 1 Reply Last reply
                            Reply Quote 1
                            • D
                              Darkmx-6
                              No, I thank you! I took a bit, but I’m happy with this!
                              Reply Quote 1
                              • D
                                Darkmx-6 @Mykle1
                                @Mykle1
                                In the readme you should really give the thanks to sdetweil , he’s the one who basically gave me the answer.
                                Reply Quote 1
                                • Mykle1M
                                  In the readme you should really give the thanks to @sdetweil
                                  Ahh, him again? :-)
                                  Done!
