    new update/upgrade script, ready for testing
    328 Posts 27 Posters 706.0k Views 24 Watching
    • C Offline
      ChrizZz @sdetweil
      @sdetweil said in new update/upgrade script, ready for testing:
      @surger13 ok, looks like we have to fight the manual way
      do
      cd ~/MagicMirror
      git stash
      git merge
      npm install
      took the manual way too because of the same probs. Now my Pi is downloading the electron v3.1.13 version with 3.01 kB/s. can I stop the installation process to update electron manually?
      S evroomE 2 Replies Last reply Reply Quote 0
        sdetweil @ChrizZz
        @ChrizZz I do not know
          surger13 Project Sponsor @sdetweil
          do
          cd ~/MagicMirror
          git stash
          git merge
          npm install
          the fight was an easy one. everything worked. just had to restore the custom.css from a backup.
          thanks again Sam
          • evroomE Offline
            evroom @ChrizZz
            @ChrizZz said in new update/upgrade script, ready for testing:
            It looks like github has problems. I also cannot download other stuff from it with proper speed or without running into a timeout. Perhaps local or depends on your ISP region.
            MagicMirror version: 2.37.0
            • C Offline
              ChrizZz @evroom
              @evroom said in new update/upgrade script, ready for testing:
              I started installing electron in a new terminal session and it is downloading now with 16 kB/s. Maybe a stupid decission, maybe not.
              Current status: 45% downloaded in the new terminal session, 18.5% downloaded as part of the MM update.
              //edit: I stopped the inital installation, downloaded the right electron file from a mirror and placed the zip file in the /home/pi/.cache/electron folder. After that I updated electron manually. It worked well and after that I started npm install of the new MM version again. Now everything is updated without waiting years to download the zip from Github.
                bdream
                @sdetweil Hi Sam, after weeks being off I saw availability of v2.10.0 :slightly_smiling_face:
                I run your script ```
                bash -c “$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)” apply
                Do I need to stop MM first or 'only' run the script in MagicMirror folder?
                cheers, bdream
                  Mykle1 Project Sponsor Module Developer @bdream
                  @bdream
                  Just open a new terminal and run the script. MM should not be running, I believe.
                  • P Offline
                    panos
                    Guys, I’m little confused.
                    I currently running at v2.9 and I wish to upgrade to v2.10
                    If I run the command:
                    bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/upgrade-script.sh)” apply
                    MM won’t update to v2.10
                    If I try the ‘traditional’ way 'git pull && npm install’ and ignore any changes that I make I receive the error:
                    The following untracked working tree files would be overwritten by merge: installers/dumpactivemodules.js
                    see here:
                    https://forum.magicmirror.builders/topic/11912/problem-with-updating-to-2-10-0-from-2-9-0-using-update-script/2
                    Any suggestion on how to update to 2.10?
                      sdetweil @panos
                      @panos the official script has a bug. Erase that file and use the updated version.
                      See
                      https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
                        bdream
                        See
                        Sam, your link is looping or I’m wrong.
                        Can you please provide the link to the right script again? Sorry I’m confused and not able to update the MM.
                        cheers, bdream
                          sdetweil @bdream
                          @bdream the 1st post of this topic has the commands
                            bdream
                            it works :thumbs_up:
                            Many thanks AGAIN Sam!
                            cheers, bdream
                            • spitzlbergerjS Offline
                              spitzlbergerj Project Sponsor Module Developer
                              @sdetweil thanks for your great work. Unfortunately it does not work for me with the script.
                              When I execute the script I get the following messages:
                              bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                              the log will be /home/pi/MagicMirror/installers/upgrade.log
                              No LSB modules are available.
                              doing test run = true
                              update log will be in /home/pi/MagicMirror/installers/upgrade.log
                              saving custom.css
                              upgrading from version 2.9.0 to 2.10.0
                              fetching latest revisions
                              fatal: Couldn't find remote ref origin
                              MagicMirror git fetch failed
                              restoring custom.css
                              The log file also contains the following:
                              not english or locale not set, set git alias
                              alias git='LC_ALL=en_US.UTF-8 git'
                              remote name = github-desktop-darkniki origin
                              git fetch rc=128
                              Should I update manually or is there another way with the script?
                              Sepp
                              Regards
                              Josef
                              http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
                                sdetweil @spitzlbergerj
                                @spitzlbergerj well, thats a new one…
                                i try to find the upstream git repo this installation came from, and then get the changes from there,
                                cause I want to be able to test the application of the changes without breaking the local system.
                                can u do
                                git remote
                                and
                                git remote -v
                                thanks… it should be one word, but it looks like two on your system
                                  @spitzlbergerj could u try this little script to see if I got it right?
                                  curl -sL https://www.dropbox.com/s/80fevh39jme3iig/testlang.sh?dl=0 | bash
                                  it will check the status of the 3 lang settings,
                                  LANG=
                                  LANGUAGE=
                                  and LC_ALL=
                                    @sdetweil thanks for your Help. Here are the results
                                    git remote
                                    origin
                                    git remote -v
                                    github-desktop-darkniki https://github.com/darkniki/MagicMirror.git (fetch)
                                    github-desktop-darkniki https://github.com/darkniki/MagicMirror.git (push)
                                    origin  https://github.com/MichMich/MagicMirror.git (fetch)
                                    origin  https://github.com/MichMich/MagicMirror.git (push)
                                    and for the second post:
                                    Auf Branch master
                                    Ihr Branch ist zu 'origin/master' um 117 Commits hinterher, und kann vorgespult werden.
                                      (benutzen Sie "git pull", um Ihren lokalen Branch zu aktualisieren)
                                    Unversionierte Dateien:
                                      (benutzen Sie "git add <Datei>...", um die Änderungen zum Commit vorzumerken)
                                            core
                                    nichts zum Commit vorgemerkt, aber es gibt unversionierte Dateien (benutzen Sie "git add" zum Versionieren)
                                    I hope this helps
                                    Regards
                                    Sepp
                                    Regards
                                    Josef
                                      @spitzlbergerj thx. Can u try the last command again
                                        Good Morning @sdetweil
                                        Here are the results from the just newly started command:
                                        alias git='LANG=en_US.UTF-8 git'
                                        Auf Branch master
                                                core
                                        The result is the same as last night, right?
                                        Regards
                                        Sepp
                                        Regards
                                        Josef
                                        evroomE S 2 Replies Last reply Reply Quote 0
                                        • evroomE Offline
                                          evroom @spitzlbergerj
                                          @spitzlbergerj
                                          Hi there, I do not want to interfere, as Sam is most capable, but can you give the output of this command?
                                          locale -a
                                          And tell if you see English or German output for those 2 commands?
                                          LC_ALL=C git status
                                          LC_MESSAGES=C git status
                                          S spitzlbergerjS 2 Replies Last reply Reply Quote 0
                                            sdetweil @evroom
                                            @evroom i remove the alias so, the output will not tell us anything…
                                            I was hoping there was some priority of the settings…
                                            LC_ALL doers override LANGUAGE…
                                            but LANG doesn’t appear to be dynamically changeable per command
                                            try the testlang script again, the locale doc says this should work…
                                            evroomE 1 Reply Last reply Reply Quote 0
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
