    new update/upgrade script, ready for testing
    328 Posts 27 Posters 702.0k Views 24 Watching
      sdetweil @gonzonia
      @gonzonia yes, the upgrade script from the master github site has a bug,
      please erase that one file
      ~/MagicMirror/installers/dumpactivemodules.js
      and then use the link to the script from this topic page1
      https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing?page=1
      evroomE G 2 Replies Last reply Reply Quote 0
      • evroomE Offline
        evroom @sdetweil
        Hi Sam, updating MM to 2.10.0 using your script. At the end the test run says:
        any *-lock.json files do not need to be saved
        do you want to save these files for later   (Y/n)?Y
        git: 'git_user_name' is not a git command. See 'git --help'.
        no modules found needing npm refresh
        restoring custom.css
        test run, restoring files stashed
        The upgrade.log file does not give a clue as to what exact command was used.
        I am not into git, so cannot give you anything more than the git version
        pi@MagicPi:~ $ git --version
        git version 2.11.0
        Any ideas ?
        Best regards,
        E.J.
        MagicMirror version: 2.36.0
          sdetweil @evroom
          @evroom great find!..
          give it another try please…
          git wants all operations to be tagged with the users email address and name.
          but if you haven’t provided one, I use a temporary approach…
          • evroomE Offline
            evroom
            Latest run:
            here are 1 local files that are different than the master repo
               css/custom.css
            error: Your local changes to the following files would be overwritten by merge:
            	css/custom.css
            Please commit your changes or stash them before you merge.
            Aborting
            I can of course save and restore during the apply, but I do not know if this is what you want /expect.
              sdetweil @evroom
              @evroom said in new update/upgrade script, ready for testing:
              css/custom.css
              hmm… custom.css was taken out of distribution on the 2.9 release…
              let me examine… hang on 30 mins
                @sdetweil can u tell me what MM version you are running?
                grep version ~/MagicMirror/package.json
                thanks
                • evroomE Offline
                  evroom
                  @sdetweil said in new update/upgrade script, ready for testing:
                  This MM install has
                  pi@MagicPi:~ $ grep version ~/MagicMirror/package.json
                    "version": "2.8.0",
                  Apparently I did not upgrade to 2.9.0. :-)
                  In parallel I am upgrading an 2.9.0 install (using the ‘old’ apply script). I got the same git: 'git_user_name' is not a git command.error there, but decided to do the apply anyway.
                  Currently Downloading tmp-27972-0-electron-v3.1.13-linux-armv7l.zip which takes forever for some reason (approx. 700 B/s).
                  Btw, I know it can be solved by other means, but I would like you to be able to tweak your script.
                  • G Offline
                    gonzonia @sdetweil
                    @sdetweil Thanks! I thought I’d tried that as well. Guess not. All good now!
                      sdetweil @evroom
                      @evroom >In parallel I am upgrading an 2.9.0 install (using the ‘old’ apply script).
                      old? I updated the dropbox file so, it should have been fixed…
                      the install script is now part of the base.
                      “version”: “2.8.0”,
                      actually the upgrade log should have said, upgrading from 2.8 to 2.10,
                      also shown on the screen
                      the upgrade.log is located in the MagicMirror/installers folder
                      • evroomE Offline
                        evroom
                        I mean before you said “give it another try please…”.
                        Old is always relative :-)
                        The upgrade log did say```
                        upgrading from version 2.8.0 to 2.10.0
                        The upgrade that I still running says```
                        upgrading from version 2.9.0 to 2.10.0
                        The test run on the 2.8.0 install currently outputs this:
                        pi@MagicPi:~ $ date; bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)"
                        Fri Jan  3 15:34:42 CET 2020
                        the log will be /home/pi/MagicMirror/installers/upgrade.log
                        No LSB modules are available.
                        doing test run = true
                        update log will be in /home/pi/MagicMirror/installers/upgrade.log
                        saving custom.css
                        fetching latest revisions
                        there are 1 local files that are different than the master repo
                           css/custom.css
                        processing dependency changes for active modules with package.json files
                        processing for module MMM-PublicTransportHafas please wait
                        skipped processing for MMM-PublicTransportHafas, doing test run
                        processing complete for module MMM-PublicTransportHafas
                        processing for module MMM-soccer please wait
                        skipped processing for MMM-soccer, doing test run
                        processing complete for module MMM-soccer
                        	css/custom.css
                        Aborting
                          sdetweil @evroom
                          @evroom yeh, thats because of the test run against 2.8
                          on apply this will be fixed…
                            surger13 Project Sponsor
                            i have tried the script now to upgrade MM to the new version. but nothing changes in the version.
                            in upgrade.log are the following errors:
                            test merge result rc='' , if empty, no conflicts
                            executing merge, apply specified
                            merge result rc= 1
                             error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge überschrieben werden: 	css/custom.css 	package-lock.json 	vendor/package-lock.json Bitte committen oder stashen Sie Ihre Änderungen, bevor sie mergen. Abbruch Aktualisiere b508a62..b595cdd
                            there were merge errors
                            you should examine and resolve them
                              sdetweil @surger13
                              @surger13 did u save the changed files when prompted?
                              what version are u on? 2.8?
                              do
                                surger13 Project Sponsor @sdetweil
                                pi@MagicMirrorPi:~/MagicMirror $ grep version ~/MagicMirror/package.json
                                  "version": "2.7.1",
                                  sdetweil @surger13
                                  can u show me the log , ~/MagicMirror/installers/upgrade.log
                                  thx
                                    there was no request to save the files?!
                                    I will send you the logfile by mail.
                                    • evroomE Offline
                                      evroom
                                      Sam, the 2.9.0 threw an error on the electron update, but then continued.
                                      I am apparently on 2.10.0 now, but probably I am not running the latest electron version.
                                      pi@raspberrypi:~ $ grep version ~/MagicMirror/package.json
                                        "version": "2.10.0",
                                      This was the part where the error occured:
                                      > electron@3.1.13 postinstall /home/pi/MagicMirror/node_modules/electron
                                      > node install.js
                                      Error: read ECONNRESET
                                      /home/pi/MagicMirror/node_modules/electron/install.js:49
                                        throw err
                                          at TLSWrap.onStreamRead (internal/stream_base_commons.js:111:27)
                                      What would be the correct command to update electron and from which directory?
                                        sdetweil @evroom
                                        yeh, the website with the file broke the download…
                                        u can try
                                        cd ~/MagicMirror
                                        npm install electron@3.0.13
                                        evroomE 1 Reply Last reply Reply Quote 0
                                          sdetweil @surger13
                                          @surger13 thanks for the log…
                                          can u do
                                          echo $LC_ALL
                                          and
                                          locale | grep LANGUAGE
                                          thx
                                            both empty.
                                            pi@MagicMirrorPi:~/MagicMirror $ echo $LC_ALL
                                            pi@MagicMirrorPi:~/MagicMirror $ locale | grep LANGUAGE
                                            LANGUAGE=
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
